Roll pin replacement - Polaris RZR Forum - RZR Forums.net
post #1 of 3 Old May 29th, 2012, 08:21 PM Thread Starter
niarb's Avatar
My RZR: Rzr4
Member #18281
View niarb's Photo Gallery(0)
I have a 2011 rzr4 eps and have to replace the center bearing at only 180 miles.also just had to do the control arm bushings.Thanks Polaris.My question is I want to replace the roll pin with a bolt what size of bolt do I need and is a grade 8 bolt fine to use.And as always thanks for all the great info you guys and gals provide.
niarb is offline
post #2 of 3 Old May 29th, 2012, 08:27 PM
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
Re: Roll pin replacement
center bearing of what? trying to learn. what is the purpose of the roll pin near this bearing?
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #3 of 3 Old May 29th, 2012, 08:34 PM Thread Starter
niarb's Avatar
My RZR: Rzr4
Member #18281
The rzr4 and the xp900 have a 2 piece drive shaft so that requires a bearing in the center to support the two shafts like a carrier bearing in a extra cab truck. The roll pin is used in the front and rear to lock the prop shafts to the splines of the diffs.
niarb is offline
Oem hid replacement kit azrockzuk Lighting, Stereo and Electrical 3 March 20th, 2011 08:23 PM
Tie Rod Replacement Kit (+6) Triel RT PRO UTV 6 February 10th, 2011 07:00 PM
Considering RZR as a replacement for a... L8Apex Member Introductions 39 November 9th, 2009 06:37 AM
Roll cage Roll Call papaglock Roll Cages and Safety Equipment 0 April 29th, 2008 12:36 PM
