Max tire size - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old May 29th, 2012, 02:22 AM Thread Starter
chillboy's Avatar
Member #40804
View chillboy's Photo Gallery(0)
Canada Max tire size
I have installed a 2 inch lift kit on my 2012 800 RZR. What is the largest tire I would be able to run? Appreciate responses.
chillboy is offline
post #2 of 12 Old May 29th, 2012, 02:26 AM
BlairW's Avatar
My RZR: 2011 RZR-S LE Orange Madness
Member #16164
View BlairW's Photo Gallery(0)
Re: Max tire size
Should be able to run 30's no prob
BlairW is offline
post #3 of 12 Old May 29th, 2012, 04:39 AM
Officially Addicted
BamaRZR's Avatar
First Name: Michael
My RZR: 2015 Black Pearl 900S
Member #30950
View BamaRZR's Photo Gallery(3)
Re: Max tire size
28". 30's would be in the floorboard
BamaRZR is offline
post #4 of 12 Old May 29th, 2012, 05:31 AM
Bluestreak06's Avatar
First Name: Ben
My RZR: 2012 800 LE
Member #32479
View Bluestreak06's Photo Gallery(0)
Re: Max tire size
I have 27's and I rub when the suspension flexes
Ben
"Young enough to play, old enough to pay"
2012 RZR LE EPS - Snorkeled//Outkast conversion//33" BKT 171's on 18" MSA M12's//ATV-GURU brush guard//PA doors//SidexSide Audio stereo//EMP Top//Custom whip lights
Bluestreak06 is offline
post #5 of 12 Old May 29th, 2012, 06:19 AM
fordman1620's Avatar
First Name: Tyler
My RZR: 2010 RZR
Member #37404
View fordman1620's Photo Gallery(0)
I have 27s on mine with a 2in lift and they rub at full turn.
fordman1620 is offline
post #6 of 12 Old May 29th, 2012, 06:28 AM
BlairW's Avatar
Member #16164
Re: Max tire size
I stand corrected. I guess you need the satv forward arms
BlairW is offline
post #7 of 12 Old May 29th, 2012, 09:38 AM
Pirate's Avatar
First Name: Stuart
Member #3677
Re: Max tire size
But with 27's the rub is just in very tight turns, and only lasts as long as you have the wheel at full turn. Doesn't seem to do any damage.
I have found that my 27.5" Growlers just rub the Vent Racing air canister in a hard bump. So I've purchased a set of Starting Line Products 7/8" spacers, which fixes that problem.
Pirate
Pirate is offline
post #8 of 12 Old May 29th, 2012, 10:06 AM
VtecGSR95's Avatar
First Name: Frank
My RZR: 2011 RZR XP 900
Member #1482
View VtecGSR95's Photo Gallery(0)
Re: Max tire size
I have 28" terms on my RZR S and with a racertech 2" lift they damn near rub when turning and compressing the suspension.
2011 RZR XP 900:Alba Stage 2~SLP Muffler~Holz Mounts~PCV~28" Gators
VtecGSR95 is offline
post #9 of 12 Old June 4th, 2012, 02:47 AM Thread Starter
chillboy's Avatar
Member #40804
Re: Max tire size
Thanks. Do you have 12 or 14" rims?
chillboy is offline
post #10 of 12 Old June 5th, 2012, 10:47 AM
Thom's Avatar
First Name: Thom
My RZR: 2011 LE
Member #20304
View Thom's Photo Gallery(0)
Re: Max tire size
Running 28" Swamplites with 2" racertech lift and no rub or issues at all Wish I went 29.5
Thom is offline
post #11 of 12 Old June 5th, 2012, 11:00 AM
flash800's Avatar
Member #32313
View flash800's Photo Gallery(0)
Re: Max tire size
Is that a standard RZR? with 28s you have no issues?
flash800 is offline
post #12 of 12 Old June 5th, 2012, 02:44 PM Thread Starter
chillboy's Avatar
Member #40804
Re: Max tire size
What is the spec's of your tires, front and rear. I assume you are using 12" rims. Appreciate your response.
chillboy is offline
best tire and size longbow Wheels and Tires 19 March 10th, 2011 10:55 AM
actual tire size vs. advertised size crawlrinny Wheels and Tires 1 July 7th, 2010 08:12 PM
tire size blown 455 RZR 4 Specific Discussion 0 May 16th, 2010 08:22 PM
Wheel Size to Tire Size Chart? user_name Wheels and Tires 4 May 12th, 2010 01:55 PM
TIRE SIZE DEERHUNTERBOB General RZR Discussion 0 July 16th, 2009 05:55 PM
