Drain plug for cvt cover!!!! - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 27th, 2012, 05:34 PM Thread Starter
MulishatroopRzR's Avatar
My RZR: 2012 RZR S 800 LE ORANGE MADNESS, PRO ARMOUR DOORS, POLARIS 3500LB WINCH,SPORT ROOF,SSV WORKS
Member #40095
View MulishatroopRzR's Photo Gallery(0)
So I discovered there is no drain in the cvt cover for my 2012 Rzr s 800 le, what is using or putting in the cover for a drain and be able to access it?
MulishatroopRzR is offline
post #2 of 9 Old May 27th, 2012, 05:39 PM
depayton's Avatar
First Name: Daniel
My RZR: 2008 800 5'' lift, 29.5 ol2's, jstrong top, epi mudder clutch, big gun exhaust and efi controller,
Member #39040
View depayton's Photo Gallery(0)
Re: Drain plug for cvt cover!!!!
I pulled mine off and drilled a 1/2 hole at the lowest point and put a boat type plug in it. I also put rtv sealant around the cover where the gasket is. I havent had any water intrusions again...
Here is the plug i used, west marine, bass pro shop and academy carry them.
2 Bailer 1/2 inch boat baitwell livewell drain plugs .5 in brass rubber test pr 013893521842 | eBay
depayton is offline
post #3 of 9 Old May 27th, 2012, 05:59 PM
2011 RZR 800's Avatar
First Name: Kerry
My RZR: 2011 800 RZR 50
Member #23427
Thumbs up Re: Drain plug for cvt cover!!!!
Use a tire valve and take the valve stem out and screw cap back on and drain as needed.
Racer Tech 2" Lift and Springs,Super ATV Winch,Polaris Sport Roof,Polaris Brush Guards,Super Daves Shock Bushings, Polaris 14" Wrec Wheels, ITP TERRACROSS Tires,Super ATV Harnesses,Polaris S fender flares
2011 RZR 800 is offline
post #4 of 9 Old May 27th, 2012, 06:20 PM Thread Starter
Member #40095
Great idea! Thanks I think that's what I will go with
post #5 of 9 Old May 28th, 2012, 05:38 PM
Dusty05's Avatar
Member #39443
View Dusty05's Photo Gallery(0)
I used a tire valve stem also..i had the covers off sealing the inner cover to where it bolts to engine and added a bolt in style valve stem to the lowest part of outer cover by primary and used di-electric grease inbetween the covers and i have let mine idle for 10min+ in seat deep water and its water tight now!
Dusty05 is offline
post #6 of 9 Old May 28th, 2012, 05:57 PM
Richie rich
04chevy2500's Avatar
First Name: Richie rich
My RZR: 08 rzr 6 inch lift
Member #25044
View 04chevy2500's Photo Gallery(1)
same here,,i used a tire valve stem
04chevy2500 is offline
post #7 of 9 Old May 28th, 2012, 07:42 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
What size drill do you use for the stem install... Is it just a rubber base on the stem that snaps and seals into the outer clutch cover?
FunRide is offline
post #8 of 9 Old May 28th, 2012, 08:01 PM
Dusty05's Avatar
Member #39443
I dont know the size i had a stepped bit and i just drilled until it fit,i used the bolt in style so i dont have to worry about it ever popping out or anything!
Dusty05 is offline
post #9 of 9 Old May 29th, 2012, 10:19 AM
jll4lee's Avatar
First Name: Lee
My RZR: 2008
Member #8373
View jll4lee's Photo Gallery(0)
iI can't believe they have not added on yet, That was like the first thin i did back in 2008. Is the CVT cover still a pain to make water tight?
jll4lee is offline
drain plug for belt cover lose mjonesy758 Engine and Drivetrain 0 May 3rd, 2012 02:50 PM
oil drain plug Aden Engine and Drivetrain 11 March 8th, 2012 06:29 PM
Oil drain plug DEERHUNTERBOB General RZR Discussion 16 January 14th, 2011 02:58 PM
Drain Plug In Clutch Cover Stroker General RZR Discussion 13 August 10th, 2008 09:41 PM
CVT Drain Plug. benard Engine and Drivetrain 0 June 25th, 2008 05:50 PM
