Orange madness went for a swim! NEED HELP! - Polaris RZR Forum - RZR Forums.net
post #1 of 22 Old May 27th, 2012, 01:04 PM Thread Starter
MulishatroopRzR's Avatar
My RZR: 2012 RZR S 800 LE ORANGE MADNESS, PRO ARMOUR DOORS, POLARIS 3500LB WINCH,SPORT ROOF,SSV WORKS
Member #40095
View MulishatroopRzR's Photo Gallery(0)
My new Rzr S orange madness went for a swim like I said, going down a river and went into a unexpected deep hole, the machine shut off, so I immediately jumped out and got her onto dry land engine was only under water for about 45 seconds or so, but after getting it home and tearing it apart I pulled off air filter which was soaked, removed cvt cover there was little water in there but there was and pulled plugs, and drained engine oil,transmission, and transfer case, didn't seem to have any water in any of the oils but did have water in my Cyclinders, I cranked it over and had some water shot out my plug holes, I have had it in my heated garage and a dehumidifier running next to it for two days and it has taken a good bit of water from it, any thing anyone can tell me to help me fix this right would be greatly appreciated, I am mechanically inclined so shoot away! Thanks
MulishatroopRzR is offline
post #2 of 22 Old May 27th, 2012, 01:12 PM
teamhog's Avatar
My RZR: 2009 LE
Member #8136
Feedback Score: 5 reviews
Re: Orange madness went for a swim! NEED HELP!
Fill and drain several times to make certain the water is out.
There are several explanations of how to do this on the site...
When you do start it the 1st time, run it for a bit and then do one final drain and fill.
If the drain is clean, fill and keep moving....
Stay dry my friend....
Chris Dierkens
teamhog is offline
post #3 of 22 Old May 27th, 2012, 01:23 PM Thread Starter
Member #40095
Ok thanks alot I'm going to do a few flushes of the engine oil before starting, I'm hoping I have no bent valves the machine only has 85 miles on it! Lol
post #4 of 22 Old May 27th, 2012, 01:48 PM
hobbz's Avatar
My RZR: 2010 Walker Evans
Member #17774
View hobbz's Photo Gallery(5)
don't forget to drain your gas tank. it might not hurt to fog your cylinders while it is sitting to keep them from rusting. you can get the fogger oil in the boat section at walmart
2010 RZR 50" Walker Evans
+6 Long Travel,
15" MSA M12 Wheels, 28" Moto MTCs
Snorkeled, Doors, 5k Winch, HID's, Vertex 2 Way Radio,
Parking Brake, Gas Tank Shield, 1/4" Aluminum Skidplate, Rackzilla Rack
Redneck Ridge Riders - Kentucky Atv Club
hobbz is offline
post #5 of 22 Old May 27th, 2012, 02:26 PM Thread Starter
Member #40095
Is it just engine fogging? Is it spray? Or liquid?
post #6 of 22 Old May 27th, 2012, 02:27 PM Thread Starter
Member #40095
What can I use for the front and rear diffs instead of Polaris stuff? Is it 75w 90 gear oil?
post #7 of 22 Old May 27th, 2012, 02:47 PM
olddognewtrick's Avatar
First Name: Jim
Member #18785
Never considered adding pole holders to my rzr, until now..
2011 Pursuit Camo
olddognewtrick is offline
post #8 of 22 Old May 27th, 2012, 02:50 PM
King of crash!
Member #787
Front diff takes a special fluid get at dealer .... Your ex will be full of crud to clean muff out now befor it drys hard. Spark arrester might also plug up
johnnycat8 is offline
post #9 of 22 Old May 27th, 2012, 02:51 PM
kingpitcher700's Avatar
First Name: Keith
Member #15701
View kingpitcher700's Photo Gallery(0)
Not sure on the back I believe some run mobile 1 synthetic gear oil but the front is very finicky with the electronic awd. I recommend the Polaris oil on the front.
Sent from my DROIDX using Tapatalk 2
kingpitcher700 is offline
post #10 of 22 Old May 27th, 2012, 03:21 PM Thread Starter
Member #40095
Ok I will get from dealer! I took mid pipe off nothing in that! The exhaust muffler had a good bit of water in it but I couldn't get it completely out of the frame! I could move it around enough to get pretty well all the water out! Removed the spark arrestor and that seemed to catch any crud the tried to get in. Cleaned that, I am wondering where it was not in the water very long did much get in The diffs? Also coolant I don't think much would of went in there either? Any thoughts?
post #11 of 22 Old May 27th, 2012, 03:28 PM
RZR Junky.....
DBlank72's Avatar
First Name: Drew
My RZR: 2009 rzr s
Member #20937
View DBlank72's Photo Gallery(3)
Just keep flushing the oil in the engine. Go buy some cheap oil and do it over and over. You will only need 2-3 filters. But get enough oil to change it upto 8-10 times. Good luck it'll be fine.
Drew
Once again I'm on my phone instead of riding!!!
2009 RZR S
"A world without women would be a pain in the azz"
KCCO
DBlank72 is offline
post #12 of 22 Old May 27th, 2012, 03:47 PM
First Name: Keith
Member #15701
If it went over the hood then more then likely it could have gotten water through the vent hole on the cap for overflow bottle. I would just flush All fluids real good and ride it some. Also diesel fuel is good at getting water out of the riffs a d tranny and alot cheaper then oil. Id run a few flushes of diesel then fill it back up with polarize oil. Just keep a look on the fluids
post #13 of 22 Old May 27th, 2012, 04:18 PM Thread Starter
Member #40095
No it didn't go over hood just for a moment, the engine was under for about 45 seconds I jumped out immediately and got it to dry land it was hard but me and my brother managed somehow! So I should put drain plugs Back in fill to proper level then drain everything and do this a few times? After a few times try and get it running?
post #14 of 22 Old May 27th, 2012, 04:19 PM Thread Starter
Member #40095
And put a little drop of oil on top of pistons and maybe rotate primary clutch to work the pistons up and down?
post #15 of 22 Old May 27th, 2012, 05:09 PM
First Name: Keith
Member #15701
Yes your gonna wanna change the fluids a couple times.
Orange Madness Wolfdog RZR-S Specific Discussion 13 May 27th, 2012 07:56 AM
From Orange Madness to Razor Madness RINO CRASHER RZRForums Members' Rides 8 August 23rd, 2011 04:41 PM
my 11 orange madness s!!! highroller1901 General RZR Discussion 9 September 3rd, 2010 05:31 PM
Orange Madness no More RINO CRASHER RZR-S Specific Discussion 27 February 19th, 2010 07:37 PM
