Orange madness went for a swim! NEED HELP! - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 22 Old May 27th, 2012, 05:10 PM
kingpitcher700's Avatar
First Name: Keith
Member #15701
View kingpitcher700's Photo Gallery(0)
As stated above id drop some marvel mystery oil in the top of each cylinder just to be sure
Sent from my DROIDX using Tapatalk 2
kingpitcher700 is offline
post #17 of 22 Old May 27th, 2012, 05:16 PM Thread Starter
MulishatroopRzR's Avatar
My RZR: 2012 RZR S 800 LE ORANGE MADNESS, PRO ARMOUR DOORS, POLARIS 3500LB WINCH,SPORT ROOF,SSV WORKS
Member #40095
View MulishatroopRzR's Photo Gallery(0)
Re: Orange madness went for a swim! NEED HELP!
I've looked everywhere for that stuff I can't seem to find it anywhere! I'm in Canada anyone tell where to get this marvel mystery oil? Thanks
MulishatroopRzR is offline
post #18 of 22 Old May 27th, 2012, 05:23 PM
First Name: Keith
Member #15701
Ohhh best guess for you would be offline.
post #19 of 22 Old May 27th, 2012, 05:59 PM
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
If you didnt get it that deep and didnt see anything in the trans or diff . i would just drain and refill them i doubt seriously that any water got in them if you didnt get any in your cvt. Drain the engine oil refill with any regular engine oil. Make sure there is no water in your gas tank.A few drops of any oil in the cylinders will be fine. with the plugs out spin it over a few times. replace plugs and start engine . Only run it for a minute or so. drain oil and inspect it. If it shows any indication of milkyness refill with regular oil and start again. If the oil was ver milky start and run another minute. Drain and inspect. If it is only slightly milky run a couple of minutes then drain. Its nearly impossible to get it all out. A very small amount will evoporate with heat but try to get it all. After it looks clean drain and refill with polaris oil and ride it for awhile. maybe 30 minutes or so. Drain and inspect. Should look perfect. Drain change filter and refill should be go from there. I have seen many drain refill and go. I'm not that brave.better to be over cautious.
Magicmantx is offline
post #20 of 22 Old May 27th, 2012, 06:18 PM Thread Starter
Member #40095
I did have a small amount of water in my cvt cover, and when.I drained engine oil and transmission/transfer case it seemed to have very little to no oil in it! I'm more concerned about the water that's gotten into my cylinders, I cranked it a few times with plugs out and hot out what I could and have had my furnace on for two days aswell as a dehumidifier going! I'm going to try a few flushes of engine oil, flush and replace transmission /transfer case and hopefully try and start when I think all water is gone out of cylinder area!
post #21 of 22 Old May 27th, 2012, 06:19 PM
RZR Junky.....
DBlank72's Avatar
First Name: Drew
My RZR: 2009 rzr s
Member #20937
View DBlank72's Photo Gallery(3)
This is perfect example of what you should do. Follow this guide and you will be riding again in no time.
Drew
Once again I'm on my phone instead of riding!!!
2009 RZR S
"A world without women would be a pain in the azz"
KCCO
DBlank72 is offline
post #22 of 22 Old May 27th, 2012, 08:29 PM
Magicmantx's Avatar
First Name: Bruce
Member #20584
Actually waiting is worse than getting it started asap. If there is moisture in the cylinders it will start to rust. Need to get it running or at least spin it over a few times. Dont let it sit too long with the plugs out. You need lubrication in the cylinders . I have seen several totally drowned with everything full of water,even the gas tank. Drained and flushed good and on their way. Hopefully it didnt hygralock and bend a valve or damage a rod or piston. You'll know soon enough. It can happen but usually theyre ok as long as there wasnt alot of water you should be fine.
Orange Madness Wolfdog RZR-S Specific Discussion 13 May 27th, 2012 07:56 AM
From Orange Madness to Razor Madness RINO CRASHER RZRForums Members' Rides 8 August 23rd, 2011 04:41 PM
my 11 orange madness s!!! highroller1901 General RZR Discussion 9 September 3rd, 2010 05:31 PM
Orange Madness no More RINO CRASHER RZR-S Specific Discussion 27 February 19th, 2010 07:37 PM
