Belt cover - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 26th, 2012, 07:49 PM Thread Starter
tomymind's Avatar
First Name: Wade
My RZR: 11-50"
Member #27322
View tomymind's Photo Gallery(0)
Belt cover
I snorkeled my rzr a wile back and I went to try it out and I know it's all water tight but I was wondering if anyone else has problems sealing there belt cover because I know mine is letting water in
Thanks for any help.
tomymind is offline
post #2 of 9 Old May 26th, 2012, 07:54 PM
BlairW's Avatar
My RZR: 2011 RZR-S LE Orange Madness
Member #16164
View BlairW's Photo Gallery(0)
Re: Belt cover
11's are known to leak on the back cover. pull it off and re-seal it. Also check the clamps on the rubber cvt intake boot. Mine were all very loose when i pulled it off to reseal it. Polaris uses garbage hose clamps
BlairW is offline
post #3 of 9 Old May 26th, 2012, 07:57 PM
King of crash!
Member #787
Re: Belt cover
X2 the back cover seems to leak and use a spray bottle it helps find leaks
johnnycat8 is offline
post #4 of 9 Old May 26th, 2012, 08:53 PM Thread Starter
tomymind's Avatar
First Name: Wade
My RZR: 11-50"
Member #27322
Re: Belt cover
Do I need any special tools to tear my rear cover off. I know I have to remove the primary and the secondary. Do I need a puller? Also what are the breather lines that have to be also relocated ? I never dd that yet. And that hose on top of the motor with the slit in it just replace it?
tomymind is offline
post #5 of 9 Old May 26th, 2012, 09:46 PM
BlairW's Avatar
Member #16164
Re: Belt cover
You will need a puller for the primary, or you can use a some deep sockets and a 4 inch long 3/4 fine thread bolt. Do a search. Its easy. Secondary just slides off. All the vents should be extended, or use bellows. Rear diff, transmission, tcase, fuel tank, front diff, and the breather hose up top with the slit you can repalce or put a tee in it and run new hose up. Some guys are plugging the water pump weep hole too. also there is a vent hole in back of speedo that needs to be sealed up if you plan on going that deep.
Clutch puller https://www.rzrforums.net/projects-ho...ch-puller.html
https://www.rzrforums.net/general-rzr...79-clutch.html
BlairW is offline
post #6 of 9 Old May 26th, 2012, 09:56 PM
BlairW's Avatar
Member #16164
Re: Belt cover
If you dont want to go the homemade route, HPD ( forum Vendor ) and others sell a 2 piece puller. Much easier to use. The long ones are a pain.
Hpd Tools
BlairW is offline
post #7 of 9 Old May 26th, 2012, 10:31 PM Thread Starter
tomymind's Avatar
First Name: Wade
My RZR: 11-50"
Member #27322
Re: Belt cover
That's awsome, hey thank u for all the pointers. I hate how cramped everything is around the clutch cover but no big deal. How dose the cover seal against the rear housing from factory dose it leak or just the back ?
tomymind is offline
post #8 of 9 Old May 26th, 2012, 10:43 PM
BlairW's Avatar
Member #16164
Re: Belt cover
well mine seems to seal just fine with just the factory gasket. some guys are putting a little marine grease or dielectric grease on for some extra peace of mind. others are sealing it up with silicone. Ive often thought of doing that, but it will be a huge pain next time cover needs to come off.
BlairW is offline
post #9 of 9 Old May 27th, 2012, 12:01 AM Thread Starter
tomymind's Avatar
First Name: Wade
My RZR: 11-50"
Member #27322
Re: Belt cover
Ic that's good to know. My outlander's cover never sealed thas why I was wondering. But yeah on my next days off I'll clutch my rzr and try to make it completely water proof. Thanks for the help.
tomymind is offline
Grease all of belt cover KJD RZR XP 900 2 May 13th, 2012 07:16 AM
weber belt cover?? teamrandy Forced Induction 22 May 19th, 2011 02:27 AM
Belt cover drain canuk Engine and Drivetrain 7 January 24th, 2011 05:48 PM
What belt cover will fix my rzr? rzrivy General RZR Discussion 7 January 9th, 2011 05:41 PM
08 RZR Belt Cover HivoltageRZR Want to Buy 1 September 6th, 2010 09:35 AM
