Rear diff or Transmission ? - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 26th, 2012, 12:21 PM Thread Starter
rzrstoy's Avatar
First Name: mike
Member #13597
View rzrstoy's Photo Gallery(3)
Just purchased a 2010 rzr s and went to ride it last weekend and noticed it was real jerky pulling out and stayin at real low speeds so I put it back in the garage tore it apart and realized that both tear hubs were broke so I ordered new ones put them on today and that wasn't the problem and i tore the clutch cover off and every thing seems to be good in there so now I'm kinda frustrated any help would be greatly appreciated thanks
rzrstoy is offline
post #2 of 9 Old May 26th, 2012, 12:46 PM
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
Re: Rear diff or Transmission ?
The belt may look ok but could be wore out or hour glass shaped. You can measure it out with calipers of try a new belt. It is good to have a spare belt anyway. Just scrub the new belt with soap and water then scuff the clutch sheathes with scotch brite and clean them with some type of cleaner like alcohol or brake cleaner. Blowing the clutch out with compressed air is also a good idea. The get packed full of dust. Sounds allot like the clutch not engaging smooth.
crazywatson is offline
post #3 of 9 Old May 26th, 2012, 02:20 PM Thread Starter
rzrstoy's Avatar
First Name: mike
Member #13597
I was drivin it around with the clutch cover off and every looked to movin smoothly on that side the tranny side was the side jerkin around is almost like the rear diff is locked permantly or somethin cause when I turn a lil bit it's real bad I'm orrery sure this this was really ran hard and beat pretty bad. I found it on here it was the one with the lambo in all the pics
rzrstoy is offline
post #4 of 9 Old May 26th, 2012, 02:26 PM
Just kidding!
First Name: steve
Member #3534
Could be something in the secondary. Does the clutch look the same way when its in neutral and you rev it up? So when you bought the rzr it came with these problems? Did the owner tell you about the problems it had?
post #5 of 9 Old May 26th, 2012, 03:07 PM
ROCK-N-RZR's Avatar
First Name: Jeremy
My RZR: 2012 RZR-S White & Orange
Member #30007
View ROCK-N-RZR's Photo Gallery(9)
Originally Posted by rzrstoy View Post
.....the side jerkin around is almost like the rear diff is locked permantly or somethin cause when I turn a lil bit it's real bad
If you are driving on pavement it will be jerky because the diff is locked solid. You dont feel it much when in the dirt
ROCK-N-RZR is offline
post #6 of 9 Old May 26th, 2012, 03:20 PM
Pirate's Avatar
First Name: Stuart
Member #3677
ROCK-N-RZR is correct. If you're on asphalt or concrete its going to be jerky in turns. If you get the new international rear differential, it has a spool and solenoid locker that will allow the rear wheels to turn at different speeds...like an automobile.
Tell us more about how you knew the rear hubs were broken? Are these the hubs in the rear differential? The bearing carriers at the brake calipers? Need more info to provide you with items to look at.
Pirate
Pirate is offline
post #7 of 9 Old May 26th, 2012, 03:25 PM
Just kidding!
First Name: steve
Member #3534
Yup that could be it. Locked rear diff.
post #8 of 9 Old May 26th, 2012, 03:51 PM Thread Starter
rzrstoy's Avatar
First Name: mike
Member #13597
Yeah it was like that when I bought it and didn't realize since it was on on a black top parking lot when I took it for the little test ride I realized wheel hubs were broke when I took it apart to see if mabe a cv joint was snapped cause thats kinda what it felt like and both wheel hubs were snapped where it slides into to wheel barring I understand that it is locked diff but my 09 stealth black didn't do this that's kinda why I even noticed it
rzrstoy is offline
post #9 of 9 Old May 26th, 2012, 04:02 PM
Kymedic's Avatar
First Name: Brad
My RZR: 2011 RANGER RZRŪ 800 Boardwalk Blue/White LE
Member #18622
View Kymedic's Photo Gallery(0)
I would bet its a bad belt. You can't go by looks.
Sent from my Desire HD using Tapatalk 2
Kymedic is offline
RZR trans/rear diff/front diff for sale dpcustomfab Polaris RZR Parts For Sale 30 September 9th, 2014 01:14 PM
Transmission/Rear Diff Clunk? CraigTard RZR XP 900 8 April 7th, 2013 09:13 AM
Dried mud in rear diff and transmission vent lines 37Driver General RZR Discussion 0 February 19th, 2011 06:01 PM
Transmission/Front and Rear Diff for 2008 RZR, 2nd gen promotowerks Polaris RZR Parts For Sale 2 July 2nd, 2010 04:44 PM
RZR 800 OEM REAR Transmission GIFF-TURBO Engine and Drivetrain 0 May 25th, 2010 02:11 PM
