Low Gear - Polaris RZR Forum - RZR Forums.net
post #1 of 23 Old May 25th, 2012, 10:43 AM Thread Starter
Bad Company
Cajun_RZR's Avatar
First Name: Jim
My RZR: 2010 800 "SS"
Member #39002
View Cajun_RZR's Photo Gallery(4)
Low Gear
Who uses Low Gear and when do you find it really necessary?
Cajun_RZR is offline
post #2 of 23 Old May 25th, 2012, 10:52 AM
depayton's Avatar
First Name: Daniel
My RZR: 2008 800 5'' lift, 29.5 ol2's, jstrong top, epi mudder clutch, big gun exhaust and efi controller,
Member #39040
View depayton's Photo Gallery(0)
Re: Low Gear
Some say at all speeds lower than 11mph. I have noticed myself at speeds lower than 11mph in high gear trail/light mud riding the belt will get extremely hot and slip. Their is less heat and wear in you use low gear in situations that require less than 11mph and the belt wont slip, kinda a pain in the butt, its just part of rzr ownership.
depayton is offline
post #3 of 23 Old May 25th, 2012, 11:12 AM
gussys's Avatar
First Name: David
My RZR: 570
Member #29738
View gussys's Photo Gallery(0)
I ride a lot of SLOW trails in the mountains where 50" RZR just barely fits. I use low gear alot
gussys is offline
post #4 of 23 Old May 25th, 2012, 11:27 AM
mudslinginfool's Avatar
My RZR: 2011 graphite LE 50"
Member #28650
View mudslinginfool's Photo Gallery(0)
Re: Low Gear
Towing, low speed, hauling heavy cargo(elk,wood,ect...)rock crwawling, things along them lines. Use best judgement.
mudslinginfool is offline
post #5 of 23 Old May 25th, 2012, 12:03 PM
medik418's Avatar
First Name: Tom
My RZR: 2009 RZR
Member #14212
Texas Re: Low Gear
Only when climbing cause mine won't go 11 miles an hour
medik418 is offline
post #6 of 23 Old May 25th, 2012, 12:08 PM
BigJoel's Avatar
First Name: Joel
My RZR: 2012 800 S LE
Member #39171
View BigJoel's Photo Gallery(0)
Re: Low Gear
I'm running larger tires, so i run mine in low majority of the time. I only put it in high when going fast like running down a gravel road or sand bar..
2012 800 S LE
BigJoel is offline
post #7 of 23 Old May 25th, 2012, 02:25 PM
dsmracing1's Avatar
First Name: Cameron
My RZR: 2011 RZR 800 Walker Evans Edition
Member #27601
View dsmracing1's Photo Gallery(8)
Re: Low Gear
x2 on the larger tires and mostly mud riding so LOw get's used the majority of my ride.
Your Not Having Fun Til Your Rolled Or Stuck!
Warn RT40 4000lb Winch, 30" Gorilla Silverback Tires on STI HD2 SE Rims, Rhino Axles On All 4 Corners, Arctic Thunder Snorkel, Racer Tech 2" Lift/Progresssive Springs, EMP Gas Tank Guard and Outback Bumper, Pro Armor Doors, FUTV A-Arm Guards, SSV Marine Stereo, 30" Totron Light Bar, Dalton Clutch, Cooter Brown Skid, SATV Power Steering
BRAAAAAAP!
dsmracing1 is offline
post #8 of 23 Old May 25th, 2012, 02:55 PM Thread Starter
Bad Company
Cajun_RZR's Avatar
First Name: Jim
Member #39002
Re: Low Gear
Interesting...cause except for towing I had'nt realized the need to use low.
post #9 of 23 Old May 25th, 2012, 03:04 PM
dumplin's Avatar
First Name: Aaron
My RZR: 2011s Orange Madness
Member #38579
View dumplin's Photo Gallery(0)
I use it when I'm coming off pretty good hills , feathering the gas to keep the clutch from freewheeling in low seems to help save on brakes too .
Sent from my iPhone using My Thumbs .
dumplin is offline
post #10 of 23 Old May 25th, 2012, 03:41 PM
RY86's Avatar
First Name: Ryan
My RZR: 2013 RZR XP900 evasive green
Member #30699
View RY86's Photo Gallery(1)
Re: Low Gear
In deep tacky mud I always use low gear. Way less strain on the belt.
RY86 is offline
post #11 of 23 Old May 25th, 2012, 04:57 PM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Re: Low Gear
Originally Posted by mudslinginfool View Post
..............Use best judgement.
LOL; in general, a notoriously rare commodity among RZR riders.
Cheers
BarRZR is offline
post #12 of 23 Old May 25th, 2012, 06:06 PM
KEN1's Avatar
First Name: Ken
My RZR: 2011 RZR S LE
Member #21675
View KEN1's Photo Gallery(0)
Re: Low Gear
I'm paranoid and as per the manual any speed under 10mph.My friends who follow behind me bitch all the time when after a rock crawl or technical section I stop and put it in high.Oh well........sucks to be them on a quad cause i'm on a RZR.:rzrs:
KEN1 is offline
post #13 of 23 Old May 25th, 2012, 09:51 PM
tomymind's Avatar
First Name: Wade
My RZR: 11-50"
Member #27322
View tomymind's Photo Gallery(0)
Re: Low Gear
I ride mine in low lots of the time in the skeg. Easyer on the belt for sure.
tomymind is offline
post #14 of 23 Old May 26th, 2012, 03:25 PM
Pirate's Avatar
First Name: Stuart
Member #3677
Re: Low Gear
Out on the trail I'll leave my RZR in low gear up to 15 mph. If the trail comes to an open spot that I can run, I'll shift to high. But I spend a lot of time in low, helps save the belt and keeps the RPMs in the range where the power is.
Pirate
Pirate is offline
post #15 of 23 Old May 26th, 2012, 04:04 PM
Kymedic's Avatar
First Name: Brad
My RZR: 2011 RANGER RZR® 800 Boardwalk Blue/White LE
Member #18622
View Kymedic's Photo Gallery(0)
90% time I run low. Most trails around here are slow speed. If I come up on a section that's wider and flat ill switch to high.
Sent from my Desire HD using Tapatalk 2
Kymedic is offline
Rzr will not go in any gear ?? skeeter67 Engine and Drivetrain 25 March 13th, 2013 07:42 PM
Has any one swaped out the rear gear box for the international gear box? dmax61 RZR XP 900 20 April 29th, 2012 03:26 PM
when to use HI and LO gear hmfman91 RZR-S Specific Discussion 14 December 10th, 2011 07:19 PM
Which gear? Drako99 RZR-S Specific Discussion 2 March 21st, 2011 07:01 AM
Fast in Low Gear or Slow in High Gear? WARPARTY36 General RZR Discussion 9 February 28th, 2010 05:25 PM
