Fun trip to the atv park but broke tie rod couple questions - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old May 23rd, 2012, 11:11 PM Thread Starter
gman6797's Avatar
First Name: Gary
My RZR: 2008 800
Member #34480
View gman6797's Photo Gallery(5)
First had a great time with some friends at a local (2 hours away) atv park
Hit a jump and nose dived and broke my tie rod. so did I not have enough speed at the launch? I have jumped before and am fairly new to rzrs (within 4 months) always had good "luck" with my landings this time I was looking directly at the sand bar hoping my belts and roll cage would hold up in the roll. Luckily just broke a tie rod.
So tips on keeping the nose high? goose it at launch?
Next tie rod recommendations? found some heavy duty ones on ebay or OEM?
last would love to hear how you "patch something like this. The best i could think of was to use a tree and my winch lift it up pull the tire off and winch it up on the back of my buddy's 850xp polaris and gimp it back to camp.
If you care to browse our trip feel free its a bit long just threw up video and stills.. at 9:05 i hit the ramp and have a terrible landing if you want to watch and give advice...
My other buddy caught a tree and knocked out a headlight and broke some plastics on his "borrowed" polaris 500 ;-)
All tips and information is appreciated.
gman6797 is offline
post #2 of 4 Old May 24th, 2012, 12:05 AM
chad214's Avatar
My RZR: 2011 rzr 4 2011 rzr xp le
Member #19862
View chad214's Photo Gallery(0)
Way to small of a jump for a Rzr. That was more of a kicker then a jump.
2015 Voodoo Blue Xp1000
2011 LE XP
chad214 is offline
post #3 of 4 Old May 24th, 2012, 12:18 AM
roadhazzard's Avatar
First Name: bryan
My RZR: 2011 rzr 800 LE S
Member #22151
View roadhazzard's Photo Gallery(4) Send a message via Skype™ to roadhazzard
Re: Fun trip to the atv park but broke tie rod couple questions
well as far as i know that is the rzr nature of "nose diving" on jumps my 11' rzr s le has the fox shocks and i have adjusted and adjusted both spring rates and the dampen/rebound screw but still dose the same nose dive, if the jump is a smooth take off (not like a short steep jump) it is not bad with jumping.
As for the tie rod i have not broken them but have "egg shaped" the outer tie rod where the bolt goes through, if that happens the outer part of the tie rod will fall off and scar up the caliper, i have limped home by using a flat steel washer that is just a hair bigger than the outer tie rod housing keeping it steerable.
roadhazzard is offline
post #4 of 4 Old May 24th, 2012, 04:07 AM
so-illrzr's Avatar
First Name: Jeremy
My RZR: 12 XP 900 Orange Madness
Member #17934
View so-illrzr's Photo Gallery(0)
My rule of thumb for jumping is the ramp needs to be longer than the rzr, if not the front tires are usually coming down before the rear launches and you lawn dart. Check out Racer Tech for heavy duty tie rods, they're pricey but worth the money.
so-illrzr is offline
A couple of pictures from my Quick Moab Trip Johnny UTV Inc 69 May 21st, 2012 06:00 AM
First Trip With the XP & Sure Enough I Broke Something jnl900xp RZR XP 900 20 March 22nd, 2012 06:42 PM
Couple Pics from our last trip to Florence OR nvs2none General RZR Discussion 1 March 13th, 2012 09:35 PM
Have a couple of questions raider General RZR Discussion 6 March 25th, 2010 01:42 PM
Couple questions kenzo General RZR Discussion 2 August 3rd, 2009 08:05 AM
