Tire PSI??? - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old May 20th, 2012, 04:32 PM Thread Starter
scottrod's Avatar
Member #32204
Tire PSI???
I'm from PA and I mostly do very rocky trail riding. What PSI do you guys run? I have the stock wheels and tires for now but I plan to upgrade to 14" wheels and bigger tires in a couple months.
scottrod is offline
post #2 of 12 Old May 20th, 2012, 05:13 PM
soapman72's Avatar
My RZR: XP Turbo EPS
Member #33867
View soapman72's Photo Gallery(0)
Re: Tire PSI???
If you ride where it is very rocky, I would recommend that you stay away from 14" wheels. I wanted them for my RZR unti I saw how easy it was to chunk your rims and/or pinch a sidewall. As for your iriginal question, most people run around 8-10 psi. It depends on the brand and exact size of your tires as well. Less pressure (up to a point) increases traction but protects the tire less. More pressure makes it less likely that you will get flats.
soapman72 is offline
post #3 of 12 Old May 20th, 2012, 05:47 PM
2000XLifted's Avatar
First Name: Russ
Member #35439
View 2000XLifted's Photo Gallery(0)
Re: Tire PSI???
Stock 2012 50" LE at 8psi here. Works well for lost trails and the other rockville places I ride.
2012 RZR 800 50" LE
2000XLifted is offline
post #4 of 12 Old May 20th, 2012, 06:06 PM
Kip
Kip's Avatar
Member #9016
View Kip's Photo Gallery(0)
I run my 26" on 14" at 9 psi
Kip is offline
post #5 of 12 Old May 20th, 2012, 06:36 PM
prtymrcr's Avatar
Member #30948
View prtymrcr's Photo Gallery(0)
Re: Tire PSI???
2010 S 26 " BH on 12" wheels ,7.5 psi
prtymrcr is offline
post #6 of 12 Old May 20th, 2012, 07:26 PM
SnotRkt's Avatar
First Name: Kevin
My RZR: '12 Magnetic Metallic 800 LE
Member #36872
View SnotRkt's Photo Gallery(0)
Re: Tire PSI???
I ran my 26" Tusk Trilobites (Big Horn knockoff) today at 6 psi. We did some rough trails, mud, hill climbs and fast riding and they felt great all day.
2012 RZR 800 LE Magnetic Metallic - RacerTech 2" lift, Makin Trax progressive springs, 1" SATV spacers, Polaris ESP, Polaris doors, 12" STI HD3 wheels with 27x9 BigHorns all around, Rear cab frame extension, Tractor Tunes stereo, and the list goes on and on....
SnotRkt is offline
post #7 of 12 Old May 20th, 2012, 08:50 PM
srt20's Avatar
My RZR: 2015 RZR 4 900 Red
Member #23480
View srt20's Photo Gallery(0)
Re: Tire PSI???
I run 12 psi in my bighorns. Rough rocky trails at high speed. 26" tires, 14" wheels.
2015 900 4 SSV Works door pods and glovebox sub, UTV headquarters roof, 30" curved led bar, Mudbusters flares Maxxis Liberty 29x9.5x15 tires, KMC Machete 15" wheels 5x2
Sold
2011 Boardwalk Blue and White LE 26" Bighorns on 14" SIXr wheels, 1.5" spacers, 58" wide, Racertech lift, front and rear bumpers,tunes by SSV Works, LTR 450 shocks
srt20 is offline
post #8 of 12 Old May 21st, 2012, 03:09 AM
AKBNY's Avatar
My RZR: 2013 900XP
Member #28822
View AKBNY's Photo Gallery(0)
Re: Tire PSI???
I have itp ss312 14" rims with 26" bighorns. I ride in upstate NY so we are in the same terrain, i run 11 - 13 psi. But i still get pinch flats and sidewall tears like crazy, so much that im dropping back down to a 12" rim.
2013 RZR 900XP Black/Evasive Green
AKBNY is offline
post #9 of 12 Old May 21st, 2012, 07:08 AM
I am still 16 in my head!
Kandgo's Avatar
First Name: Rick
My RZR: 09s 08stnd. 11-800s, 12 900XP
Member #22394
Feedback Score: 29 reviews
Re: Tire PSI???
12in Rims, 26 Bighorns. Rocky riding. 11 front, 12 rear. So far, so good! We prefer 12in Rims also over 14in.
Kandgo is offline
post #10 of 12 Old May 21st, 2012, 08:45 AM
rokindaz's Avatar
Member #38656
View rokindaz's Photo Gallery(0)
Re: Tire PSI???
Am I nuts..? I've been running 5 psi. in my stock 26" big horns ever since I got it. Rocky desert and forest roads mostly.
rokindaz is offline
post #11 of 12 Old May 21st, 2012, 09:03 AM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Re: Tire PSI???
I'm running those same tires in those same conditions, but I run 10 psi front and back; no problems so far.
Cheers
BarRZR is offline
post #12 of 12 Old May 21st, 2012, 11:14 AM
Magnus1's Avatar
My RZR: 2008
Member #17316
View Magnus1's Photo Gallery(0)
Re: Tire PSI???
I run 90% rocks so I treat my RZR just like a rock crawler. Beadlocks and 3-4psi. If I'm going to just trail ride, hunt or cruise my property I kick it up to 12-14. I set mine up with tires and rims that will not pinch or cut easily.
Magnus1 is offline
tire shop cant get my tire broken down jaketruck Wheels and Tires 18 November 11th, 2016 04:53 PM
WTB Spare front tire and rim or 09 S Front Rim if you dont have a tire. Quad411 Want to Buy 2 February 4th, 2011 12:11 PM
which tire is best and where to buy Bshay169 Wheels and Tires 5 December 31st, 2009 05:00 PM
What tire should i buy? Dave07vette General RZR Discussion 3 November 10th, 2009 04:56 PM
tire ? Brenton Wheels and Tires 0 September 10th, 2008 12:29 PM
