hayabusa RZR - Polaris RZR Forum - RZR Forums.net
post #1 of 27 Old May 20th, 2012, 08:15 AM Thread Starter
fritster's Avatar
First Name: Frit
My RZR: Custom
Member #40424
View fritster's Photo Gallery(0)
hayabusa RZR
ANYONE got a hayabusa RZR for sale?
Does anyone make a conversion kit?
CHEEK, you should sale a conversion kit.... lots would jump on it.
Below is my latest build. GIXXER 600 jeep cart. Size of a golf cart, all aluminum body and frame. Final drive is chain to a transaxle (has reverse gear). 6 speed clutch. I am installing an auto clutch form EFm and then Iwill try to sell it to build a RZR.
Frit
Name:	2012-04-22 15.19.18.jpg
Name:	2012-04-22 15.07.46.jpg
Name:	black jeep cart.jpg
fritster is offline
post #2 of 27 Old May 20th, 2012, 10:08 AM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: hayabusa RZR
There are a few out there.
Not sure if there is a kit though.
Check with Weller Racing. They make R1 kits for the Rhino.
Tuf-Skin is offline
post #3 of 27 Old May 20th, 2012, 12:04 PM Thread Starter
fritster's Avatar
First Name: Frit
My RZR: Custom
Member #40424
Re: hayabusa RZR
Thanks... may have to build a rhino instead of a rzr?
fritster is offline
post #4 of 27 Old May 20th, 2012, 03:15 PM
GHETTOSLED's Avatar
Member #13216
View GHETTOSLED's Photo Gallery(0)
Re: hayabusa RZR
Here's Rick aka bigdogs Busa Rzr with custom turbo kit by Race Proven Motors
I don't think it's for sale but this one may be for sale... Turbo Busa build by Race Proven Motors
If your trying to build one yourself we have lots of pics on our Facebook page. Check em out!
www.facebook.com/raceprovenmotors.com
GHETTOSLED is offline
post #5 of 27 Old May 20th, 2012, 05:07 PM
Sparky's Avatar
First Name: Dave
My RZR: Aerocharged 1110
Member #1007
View Sparky's Photo Gallery(0)
Re: hayabusa RZR
Just a shame that the BUSA motor can't be converted to CVT -- And .. That someone doesn't offer a conversion kit for the installation into an XP.
Imagine a 1720cc 280+ HP/155Ft.Lbs. of Torque All Motor powerplant powering an XP .. .. SWEET
Sparky is offline
post #6 of 27 Old May 20th, 2012, 05:59 PM
JKChad's Avatar
Member #36005
View JKChad's Photo Gallery(0)
Wouldn't a Z1 conversion achieve about that same power. I know there are apex/ z1 conversion kits available.
Sent from my Galaxy Nexus using Tapatalk 2
JKChad is offline
post #7 of 27 Old May 20th, 2012, 07:34 PM
Sparky's Avatar
First Name: Dave
Member #1007
Re: hayabusa RZR
Sure ...... Butt -- Either has to be Boosted to achieve.
Each engine brings to the table engineering issues to Turbocharge. Look at Mike's 2nd pic to illustrate this point.
Being able to have a 280HP All Motor (N/A) engine eliminates some of these engineering issues.
Performance parts also abound for the BUSA engine. Just a Jewel of a powerplant.
Sparky is offline
post #8 of 27 Old May 20th, 2012, 07:41 PM
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
Re: hayabusa RZR
I'm putting a busa in mine right now. Using a XP transmission.
crazywatson is offline
post #9 of 27 Old May 20th, 2012, 07:51 PM
Sparky's Avatar
First Name: Dave
Member #1007
Re: hayabusa RZR
Only way I see this being done is to gut the secondary and weld a sprocket to the steel splined shaft.
Although this has been done a few times -- I'm not fond of the short chain from the crank to the transmission inputshaft. One also has either a 5sp or 6 sp manual transmission to shift.
I'd prefer a Busa with a true CVT in the XP. When this can be achieved -- It's Game Over for any other conversion.
Sparky is offline
post #10 of 27 Old May 20th, 2012, 07:53 PM
Tuf-Skin's Avatar
Member #2228
Re: hayabusa RZR
why can't you make a new output shaft for the Hyabusa that has a tapered end that fits a STM primary?
Tuf-Skin is offline
post #11 of 27 Old May 20th, 2012, 08:19 PM
Sparky's Avatar
First Name: Dave
Member #1007
Re: hayabusa RZR
You know Cliff -- I've thought about many times.
A couple of issues though ...... Is there enough crank sticking out of the case to machine for a tapered end ??
The 2nd issue is the side load placed on the end of the crank - And can the main bearings take this load ??
A new crank could be forged/machined to take care of the length/tapered end. One problem solved.
The bearing issue -- I have no idea.
Butt -- IF it could be done ......... That's the route I'd like to go.
What do you think Mike ??
Sparky is offline
post #12 of 27 Old May 20th, 2012, 09:29 PM
Just kidding!
First Name: steve
Member #3534
Yes that is how i will do the transmission sprocket. Chain heat is always been a big issue with a set up like this. I have been doing allot research on diffrent systems of saving the chain. Seems like the small motor sprocket is a big cause of the problem. It makes for a short chain and tight bend for the chain. Right now im leaning towards putting a drive shaft coupling on the motor sprocket and moving the chain and sprocket away from the engine and putting a big sprocket on the motor with 630 chain instead of 530. This will make the chain longer and less of a bend plus the chain is bigger and stronger. Just need to figure out a support bearing since the sprocket will be so far away from the motor. But yes a cvt on the crank would be the cats meow!
Sent from my DROIDX using Tapatalk 2
post #13 of 27 Old May 20th, 2012, 09:39 PM
Spicoli's Avatar
First Name: Jonathan
My RZR: 2009 Polaris Rzr
Member #5093
View Spicoli's Photo Gallery(0)
Re: hayabusa RZR
Dude steve I cant wait to see the build. And then once your done you got to take me for a spin
Rzr Weber Sold. Need new ride desperately!
Spicoli is offline
post #14 of 27 Old May 20th, 2012, 09:42 PM
Just kidding!
First Name: steve
Member #3534
You got it buddy
post #15 of 27 Old May 20th, 2012, 09:43 PM
Tuf-Skin's Avatar
Member #2228
Re: hayabusa RZR
I don't know much about the hayabusa engine and its bike trans.
check out pages 3-6 of this PDF file I found that adapts a Honda CBR engine to a snowmobile. they attach an adapter to the crank: http://www.mtukrc.org/download/mtu/m...paper_2005.pdf
Tuf-Skin is offline
Hayabusa Powered RZR 170??? RT PRO RT PRO UTV 54 May 4th, 2014 10:43 AM
Hayabusa RZR v2 twvette RZRForums Members' Rides 60 February 5th, 2012 11:45 AM
Hayabusa rzr part 2!!! cheek RZR and UTV Video's 15 March 2nd, 2011 11:53 AM
Took out the Hayabusa RZR-S MossLager General RZR Discussion 26 June 30th, 2010 07:41 AM
