Negative Camber or Drivers Right Wheel - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old May 18th, 2012, 02:57 PM Thread Starter
waitingforrzr's Avatar
Member #6430
View waitingforrzr's Photo Gallery(0)
Just noticed my 2008 gen III razor has a little negative camber (approx 1/2" delta between the bottom to top of the outside of the tire) on the drivers side rear wheel, but the passenger side has no camber at all. Could this be a manufacturing problem or did I really hit something hard enough to bend something? Any ideas?
waitingforrzr is offline
post #2 of 4 Old May 18th, 2012, 06:49 PM
Banned
desertvet1990's Avatar
First Name: Rick
Member #15483
Feedback Score: 11 reviews
Re: Negative Camber or Drivers Right Wheel
I bet there adjusted like that. My passanger side is the same way.
desertvet1990 is offline
post #3 of 4 Old May 21st, 2012, 04:12 AM Thread Starter
Member #6430
Re: Negative Camber on Drivers Right Wheel
I have looked all over the rear suspension and there does not seem to be anywhere I can adjust the camber for the rear wheels. Am I missing some adjustment?
post #4 of 4 Old May 21st, 2012, 06:22 AM
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
Camber is not adjustable....at least not by design....I have had a stump adjust my camber once however. A sagging spring on that corner can give the appearance of more negative camber as the suspension on that corner is in a compressed state relative to the other corners. A quick way to check for this problem is by getting a measurement from the top of the upper A-arm to a stable point above on the chassis and compare to measuring the same points on the opposite side. To be accurate the points on the chassis must not be bent. If the distance is less on the side in question it is likely spring sag (not uncommon with the stock springs. If the distances are the same then jack up that corner and check for play in the wheel/hub in the axis of camber. A bad bearing or bushings can increase the negative camber. If the hub bearing is bad you should also have some brake bind when the hub/rotor is tipped inward into the pads (in this case you may also not the top of the inboard and bottom of the outboard pads unevenly worn)
rardoin is offline
wheel offset terminology (negative, zero, and positive offset) Tuf-Skin Wheels and Tires 47 August 21st, 2019 04:55 PM
wheel camber ventracing RZR XP 900 1 March 26th, 2012 08:40 AM
Adjusting Wheel Camber? RHINO KILLER Wheels and Tires 2 February 20th, 2010 11:25 AM
A cure for 1999 Ford Ranger 4x4 4"lift kit negative camber Gunfighterdusty Misc For Sale 0 October 13th, 2009 10:25 AM
Negative Camber dearingdesign Suspension 1 June 30th, 2008 05:16 PM
