Amount of wheel bearing play? - Polaris RZR Forum - RZR Forums.net
post #1 of 9 Old May 17th, 2012, 07:36 PM Thread Starter
Plainsman's Avatar
Member #19203
View Plainsman's Photo Gallery(0)
Hello, I have felt a pop when backing up somtimes and went to check my bearings. I jacked up the RZR and rocked the wheels top to bottom like you do a car. All seem to have play, with right front the most. What amount is reasonable? I have 500 miles on a 2012 50".
I had to do this on my 2003 HD this winter, had about the same amount of play Question is whats normal and how should one measure normal play?
Thanks!
Plainsman is offline
post #2 of 9 Old May 17th, 2012, 08:20 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Re: Amount of wheel bearing play?
Make sure you're not feeling the bushings or the tie-rod ends going bad before you assume it's the bearings. You can do a visual and watch for very slight movements at the bushings and TR ends.
FunRide is offline
post #3 of 9 Old May 17th, 2012, 08:45 PM Thread Starter
Plainsman's Avatar
Member #19203
Which bushing? There are tie rod ends and ball joints at the hub I see.
I still am not convinced I have an issue, maybe these are just more sloppy than what I have encountered in vehicles?
post #4 of 9 Old May 17th, 2012, 10:18 PM
dr.vacation's Avatar
First Name: elias
Member #2092
Feedback Score: 5 reviews
View dr.vacation's Photo Gallery(0)
you cant use the word loose and good in the same sentance with bearings
dr.vacation is offline
post #5 of 9 Old May 17th, 2012, 10:52 PM
King of crash!
Member #787
No play .... Have you checked to see if the castle nut is torqued correctly ? I have come across a few that we're lose tightened them right up
johnnycat8 is offline
post #6 of 9 Old May 18th, 2012, 05:58 AM Thread Starter
Plainsman's Avatar
Member #19203
They all seem to have the same amount. You can feel it but not detect with your eye. That is what leads me to think it may be normal. I'll torque those castle nuts that's a good call.
post #7 of 9 Old May 18th, 2012, 03:33 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
It's probably the beginnings of bushing wear you're feeling. I'm talking about the bushings in the a-arms. There's a whole bunch of them in the upper and lower units. Look there for a tiny bit of visible play.
FunRide is offline
post #8 of 9 Old May 18th, 2012, 05:44 PM
teamhog's Avatar
My RZR: 2009 LE
Member #8136
I'm not sure they are used on all models, but I know there are some that use cupped washers. Have you checked that the washers are in the correct order and are the right type?
Chris Dierkens
teamhog is offline
post #9 of 9 Old May 20th, 2012, 09:00 AM Thread Starter
Plainsman's Avatar
Member #19203
Checked things over yesterday. The castle nuts werent 80lbs they were lighter. I torqued to 80+ ish ( just to get cotters back in). One was pretty loose maybe 50lbs. The front right wheel - it was the bushing moving. I packed with grease again and it stopped moving. I dont know where the hell the grease is going as it was just greased a bit ago. BTW I use that green grease.
Things seem pretty tight now. Thanks.
Front wheel play LoneStarRZR Suspension 7 November 12th, 2011 05:38 AM
wheel bearing play truggyboy General RZR Discussion 2 November 9th, 2010 08:47 PM
Wheel Bearing justang04black Engine and Drivetrain 20 November 1st, 2010 07:07 PM
Steering wheel play mainelyrzr General RZR Discussion 15 January 9th, 2010 09:07 PM
Wheel bearing k5gsxr General RZR Discussion 0 August 22nd, 2008 03:28 AM
