Mysterious Rev Limiter. - Polaris RZR Forum - RZR Forums.net
post #1 of 16 Old May 17th, 2012, 07:04 PM Thread Starter
tanglefoot69's Avatar
First Name: Peter
Member #32425
View tanglefoot69's Photo Gallery(5)
Canada Mysterious Rev Limiter.
So i have a 2012 50" and at 6450rpm the limiter kicks in and that's the way it's been since new.So a few weeks ago i made a rear window from 1/8" Lexan to stop the dust swirl and it worked very well.But since i put the window in the limiter doesn't cut in till 6550 rpm,what ya'll think about that?????
2017 Polaris General 1000 White Lightening,Pro fit roof,Lock & Ride half windshield,Rear Panel,Rearview mirror,Polaris wireless winch remote,Polaris 4500lb winch.Polaris Glacier Pro Plow.
tanglefoot69 is offline
post #2 of 16 Old May 17th, 2012, 07:07 PM
darterdad's Avatar
First Name: Claud RZR forum Rocks
My RZR: 2012 900XP LE The White One
Member #33002
View darterdad's Photo Gallery(0)
Re: Mysterious Rev Limiter.
I think I'll put in a rear window...
DC IMPORT SERVICE SINCE 1984
YOUR HONDA SPECIALIST
darterdad is offline
post #3 of 16 Old May 17th, 2012, 07:11 PM Thread Starter
First Name: Peter
Member #32425
I'm wondering if the air was being pulled away from the air intake and the window has stabilized the air,it just doesn't make any sense to me but the machine even seems to have better acceleration now.
post #4 of 16 Old May 18th, 2012, 08:00 AM
MikeT's Avatar
My RZR: 2009 50" RZR
Member #14202
View MikeT's Photo Gallery(0)
Has your top speed remained constant or has it increased as well?
MikeT is offline
post #5 of 16 Old May 18th, 2012, 08:11 AM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
The tail wind just has more to push on now! LOL
Tuf-Skin is offline
post #6 of 16 Old May 18th, 2012, 08:48 AM
Mad Scientist
martymoe's Avatar
First Name: Marty
My RZR: 08 RZR 800 & 12 RZR XP & 16 XP Turbo
Member #385
View martymoe's Photo Gallery(7) Send a message via MSN to martymoe Send a message via Yahoo to martymoe
the tachs are really slow, im guessing the window is creating more resistance and causing the clutches to work a little harder, if that's the case, you could add a little more weight to your primary arms and it will run a little harder
2008 RZR 800 (built apr 27 07)
2012 RZR XP 900 (built apr 21 12)
2016 RZR XP Turbo
2000 Banshee
(4) 2000 Scramblers
(4) 2002 Blasters
20?? Eaton Rascal 40
martymoe is offline
post #7 of 16 Old May 18th, 2012, 09:04 AM
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
CAUTION!!!! Chinese Lexan can be contaminated with Lithium Crystals.....
Live long and prosper.....(place emoticon for Vulcan salute here)
rardoin is offline
post #8 of 16 Old May 18th, 2012, 09:13 AM
Tuf-Skin's Avatar
Member #2228
Marty is right.
the stock tachometer can be off.
adding or subtracting wind resistance won't change where the soft and hard limiter are set.
I think the soft limiter pulls timing and the hard limiter pulls fuel.
either way being on the rev limter is bad for the engine. so back off the throttle or adjust your clutch.
Tuf-Skin is offline
post #9 of 16 Old May 18th, 2012, 02:20 PM Thread Starter
First Name: Peter
Member #32425
I always back off the throttle when it hit's the limiter,i hate the sound of it.What's my best option to keep it off the limiter besides backing off the throttle?
post #10 of 16 Old May 18th, 2012, 03:03 PM
Tuf-Skin's Avatar
Member #2228
adjust the clutch with a kit or adjustable weights
Tuf-Skin is offline
post #11 of 16 Old May 18th, 2012, 04:12 PM Thread Starter
First Name: Peter
Member #32425
Will increasing the limiter with a dynatek cdi box DFS9-4 be risky.What is the max you would run a stock 800??
post #12 of 16 Old May 18th, 2012, 04:20 PM
turkeyhunter's Avatar
First Name: gary
My RZR: XP turbo
Member #16815
View turkeyhunter's Photo Gallery(0)
I would go with what the others suggested. Get yourself a clutch kit and you'll be better off. Simple to do and inexpensive.
turkeyhunter is offline
post #13 of 16 Old May 18th, 2012, 04:27 PM Thread Starter
First Name: Peter
Member #32425
Ok thanks for the info guys
post #14 of 16 Old May 18th, 2012, 05:45 PM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Speculation, granted, but I think you may actually be on to something. With a rear windshield and no front, or a half front windshield, one would expect to experience a slight positive pressure in the cockpit area while running at higher speeds. Given that it has been clearly and irrefutably established that the stock intake plenum opening (between the seats) on the 800's is undersized in relation to the combined cross-section and optimal flow-rates of the CVT-intake tube and the engine-intake tube, and that the stock 800, as delivered is set-up, at the factory, to run lean of optimal throughout the power-band, anything that raises the pressure at the intake opening, even slightly, can be expected to have a noticeable and positive effect on the achievable rpm and power output. A simple mercury manometer, or a more sophisticated Helix Magnitometer would, if installed in the intake tract, anywhere down-stream of the plenum opening, provide some definitive answers. This may be how Holtz Racing discovered the stock intake systems' deficiency/s, or they may have flow-benched the whole system, I don't know. Anyway, my two-bits...........
Cheers
BarRZR is offline
post #15 of 16 Old May 18th, 2012, 06:11 PM Thread Starter
First Name: Peter
Member #32425
All i know is it's different with the window in a positive way and yes i have a half windshield on front.I'm also thinking about putting a louver between the seats with a pre filter.
Mysterious cluncking noise antpal22 General RZR Discussion 3 July 5th, 2011 08:39 PM
How to get rid of rev limiter ROOSTER_AP General RZR Discussion 16 June 3rd, 2011 07:03 AM
Mysterious LOUD popping. birdmanf250 General RZR Discussion 15 September 13th, 2010 06:38 AM
Rev limiter dondiggs General RZR Discussion 20 September 7th, 2010 11:24 AM
Mysterious Screw??? The_KY_Kid RZR-S Specific Discussion 13 September 3rd, 2010 02:42 PM
