How long did it take you to replace your front/rear bushings? - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old May 17th, 2012, 04:36 PM Thread Starter
atvrider07's Avatar
First Name: Thomas
My RZR: 2012 Rzr XP 900
Member #15656
View atvrider07's Photo Gallery(0)
My bushings are shot (3500 miles). I have a pretty good idea on how to replace them and have service manual, just wanted to get an idea on how long I should expect it to take me. I'm replacing upper and lower, front and rear. Plus two ball joints.
atvrider07 is offline
post #2 of 12 Old May 17th, 2012, 04:39 PM
Tuf-Skin's Avatar
First Name: Clifford
Member #2228
Re: How long did it take you to replace your front/rear bushings?
Do you have a lift? it will save your back if you do.
I think it took me about 2 hours, but I did lots of cleaning and greasing along the way.
Tuf-Skin is offline
post #3 of 12 Old May 17th, 2012, 04:43 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Figure it will take a night after work and a couple beers. Pull the nose off, pull the wheels off, move some brake lines around and start pulling off the a-arms. It's fairly nasty so get some rubber/disposable gloves to work with and start pulling them apart. The rear requires some parts to be removed, but none of it is too difficult. IDK, figure 3 hours to work through it the first time. Huge difference when you're done. Ball joints will take some more time. I'd take a serious look at your tie-rod ends too. Can almost guarantee they're shot too.
FunRide is offline
post #4 of 12 Old May 17th, 2012, 05:09 PM
whit107's Avatar
Member #28787
View whit107's Photo Gallery(0)
FunRide has it about right. It took me about 4 hours but I am a notorious piddler. It really is quite an easy job.
whit107 is offline
post #5 of 12 Old May 17th, 2012, 05:32 PM
groundhog's Avatar
First Name: roger
My RZR: 2010 rzr
Member #9975
View groundhog's Photo Gallery(0)
Take a hole saw and cut about a 2" hole in in the nose plastic (on each side) that lines up with the top A arm bolt. Then you can run an extension through there and remove the bolt w/o taking the front end off.
groundhog is offline
post #6 of 12 Old May 17th, 2012, 06:22 PM
King of crash!
Member #787
leave the c/v in the diff and hub just push out of way its easy take both arms off and the ball joints have a cir clip remove best to press out and in ball joint
johnnycat8 is offline
post #7 of 12 Old May 17th, 2012, 07:21 PM Thread Starter
atvrider07's Avatar
First Name: Thomas
Member #15656
thanks guys, and yes I am using a lift as long as it will fit on it. Hope the RZR isn't too small for it.
post #8 of 12 Old May 17th, 2012, 07:26 PM
DRJZ1974's Avatar
Member #22469
View DRJZ1974's Photo Gallery(0)
What do guys use for lifts? I have tried researching it, but it seems there is not really a lift for a side by side. ATV and motorcycle lifts are too small.
DRJZ1974 is offline
post #9 of 12 Old May 17th, 2012, 07:38 PM
Kymedic's Avatar
First Name: Brad
My RZR: 2011 RANGER RZRŪ 800 Boardwalk Blue/White LE
Member #18622
View Kymedic's Photo Gallery(0)
Why would you remove the front plastics? It isn't necessary. Just remove the nut, slide bolt until it hits the plastic and them angle aarm down and slide off. I converted mine from a 50" to a super atv +6 and never removed my plastics.
Sent from my Desire HD using Tapatalk 2
Kymedic is offline
post #10 of 12 Old May 17th, 2012, 07:39 PM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
Don't. Just lift it up with a floor jack and rest it on jack stands off the factory skid.
FunRide is offline
post #11 of 12 Old May 17th, 2012, 07:45 PM
DRJZ1974's Avatar
Member #22469
I am surprised nobody makes one.
DRJZ1974 is offline
post #12 of 12 Old May 17th, 2012, 08:06 PM
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
Yep did mine one evening . Spent more time cleaning parts than dissassembly and reassembly. Didnt pull any plastic. Its close but it can be done.
Magicmantx is offline
Lost Rear Axle need to Replace - Help thalin Engine and Drivetrain 4 April 30th, 2012 07:17 PM
How to remove and replace rear axles? catalac RZR XP 900 15 June 3rd, 2011 09:59 PM
Repaint or replace front plastic Fireman General RZR Discussion 21 September 18th, 2010 09:11 PM
Need to replace rear seal - need advice ArtVandelay Engine and Drivetrain 8 March 2nd, 2010 08:40 PM
How Long to Replace Front Diff Cage? jeepster Projects and How-To 11 November 8th, 2009 03:30 PM
