installed rzr-s belt now wont go into gear. - Polaris RZR Forum - RZR Forums.net
post #1 of 31 Old May 16th, 2012, 09:07 AM Thread Starter
turbotank's Avatar
Member #34513
View turbotank's Photo Gallery(0)
it grinds if i try to put it into gear. the stock belt back on it goes just fine? what gives? machine has epi clutch kit.
turbotank is offline
post #2 of 31 Old May 16th, 2012, 09:30 AM
Officially Addicted
BamaRZR's Avatar
First Name: Michael
My RZR: 2015 Black Pearl 900S
Member #30950
View BamaRZR's Photo Gallery(3)
Re: installed rzr-s belt now wont go into gear.
I did it with no issues. Did you try to ride it a bit and let it settle in? I don't have a clutch kit though.
BamaRZR is offline
post #3 of 31 Old May 16th, 2012, 09:33 AM
BarRZR's Avatar
My RZR: 2012 RZR 800-S L/E
Member #32278
Ya, the new belt is tighter than the old one, so it's "dragging" on the clutch; you need to break it in for awhile......my two-bits......
Cheers
BarRZR is offline
post #4 of 31 Old May 16th, 2012, 10:39 AM
King of crash!
Member #787
do you have the white plastic washer under the bolt on the primary? epi suplies it with their kit?
johnnycat8 is offline
post #5 of 31 Old May 16th, 2012, 02:13 PM
I am still 16 in my head!
Kandgo's Avatar
First Name: Rick
My RZR: 09s 08stnd. 11-800s, 12 900XP
Member #22394
Feedback Score: 29 reviews
Are you trying to put a S belt on a Standard?
Kandgo is offline
post #6 of 31 Old May 16th, 2012, 03:24 PM Thread Starter
turbotank's Avatar
Member #34513
yes sure do
post #7 of 31 Old May 16th, 2012, 03:25 PM Thread Starter
turbotank's Avatar
Member #34513
yup, seen it on here it seems to be the popular thing to do.
post #8 of 31 Old May 16th, 2012, 03:26 PM Thread Starter
turbotank's Avatar
Member #34513
Cheers
i guess i can try to get it into gear. it tries to move tho. maybe i just have to get it in gear and go up and down the road a few miles??
post #9 of 31 Old May 16th, 2012, 03:34 PM
Blktegra's Avatar
My RZR: 09 LE
Member #24641
View Blktegra's Photo Gallery(0)
The newer S belt will not work with older models. I can't remember the part numbers at this time but I think the newer one ends with the numbers 33. Comparing the 2 side by side you can see the newer S belt is wider then the older one. I went through the same problem with mine
09 LE
S converted
Fox Podium RC2s
Pro Armor Doors and Bumpers
Killer Kicker tunes
Ski Doo Mach 1 for the winter
Blktegra is offline
post #10 of 31 Old May 16th, 2012, 03:48 PM
Officially Addicted
BamaRZR's Avatar
First Name: Michael
Member #30950
It works 100% on a 2012 standard model. It also gets rid of the annoying belt squeal when you let off of the throttle.
BamaRZR is offline
post #11 of 31 Old May 16th, 2012, 03:52 PM
Just kidding!
crazywatson's Avatar
First Name: steve
My RZR: Faster than yours!
Member #3534
yes sure do
Try it without that washer. If it still does it either the clutch is not in prefect alignment, the bearing is going bad, the clutch is not fully disengaging or the clutch is packed full of dust.
crazywatson is offline
post #12 of 31 Old May 16th, 2012, 07:24 PM Thread Starter
turbotank's Avatar
Member #34513
its an 08, the machine has 30 hours on it. the belt is part number 3211133. will this work?
post #13 of 31 Old May 16th, 2012, 07:36 PM
Dunerocket's Avatar
First Name: Don
My RZR: 2018 RZR 4 1000/2015 1000
Member #15059
View Dunerocket's Photo Gallery(0)
On my 2011 std RZR I had to use the shim washers to line up the belt.
Dunerocket is offline
post #14 of 31 Old May 16th, 2012, 07:46 PM
redrzrrider's Avatar
First Name: Butch
My RZR: 2012 LE
Member #17841
Your BS'n! And I just bought a new spare "std. belt" for my 2012! Now I want the S belt! I hate that annoying pain in the a$$ squeal.........
redrzrrider is offline
post #15 of 31 Old May 16th, 2012, 07:52 PM
buchshot's Avatar
First Name: LB
My RZR: 09 rzr
Member #7823
View buchshot's Photo Gallery(0)
I just put an s belt on my 09 std and it works flawlessly. Maybe the belt you picked up is out of spec? I would compare it to another to confirm.
buchshot is offline
Check Engine light and wont show gear orv3c Engine and Drivetrain 6 August 3rd, 2012 06:34 AM
need help just bought new 800 now High gear wont move hbghost General RZR Discussion 12 March 28th, 2012 01:13 PM
RZR wont see low gear dirtjunkey200 Engine and Drivetrain 9 January 30th, 2011 12:37 PM
Wont stay in high gear tjmotors Engine and Drivetrain 6 October 23rd, 2010 03:58 PM
Wont go into gear pszutiak Community Help 2 December 22nd, 2009 09:11 AM
