installed rzr-s belt now wont go into gear. - Page 3 - Polaris RZR Forum - RZR Forums.net
post #31 of 31 Old May 29th, 2012, 06:32 AM
K-Dawg
K-Dawg's Avatar
First Name: K-Dawg
My RZR: 800
Member #40235
View K-Dawg's Photo Gallery(0)
Re: installed rzr-s belt now wont go into gear.
Originally Posted by Sparky View Post
Originally Posted by turbotank View Post
its an 08, the machine has 30 hours on it. the belt is part number 3211133. will this work?
You have been sold the wrong Polaris CVT belt.
Your '08 RzR takes a 3211113 CVT belt. This measures 1.188"
If you wish to upgrade to a much stronger CVT belt -- The correct belt to use on your '08 is the '09S CVT belt -- 3211130. This measures 1.178"
You have been sold a Polaris CVT belt that is to wide for the spacing of your clutch sheaves. The 3211133 belt measures appx. 1.225". If you wish to use this CVT belt - You must re-shim the clutches thus allowing the use of this wider CVT belt.
You don't have a clutch alignment issue - You're running the incorrect belt for your year RzR.
Use a veneer caliper if you wish to verify this.
Just wondering if this part #3211130 will work on an 09 RZR 800 also?
K-Dawg is offline
Check Engine light and wont show gear orv3c Engine and Drivetrain 6 August 3rd, 2012 06:34 AM
need help just bought new 800 now High gear wont move hbghost General RZR Discussion 12 March 28th, 2012 01:13 PM
RZR wont see low gear dirtjunkey200 Engine and Drivetrain 9 January 30th, 2011 12:37 PM
Wont stay in high gear tjmotors Engine and Drivetrain 6 October 23rd, 2010 03:58 PM
Wont go into gear pszutiak Community Help 2 December 22nd, 2009 09:11 AM
