installed rzr-s belt now wont go into gear. - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 31 Old May 16th, 2012, 08:33 PM
Family, it's about time
Familyman's Avatar
First Name: Paul
My RZR: 2012 xp4 900
Member #10232
View Familyman's Photo Gallery(6)
Re: installed rzr-s belt now wont go into gear.
Originally Posted by turbotank View Post
Originally Posted by BarRZR View Post
Ya, the new belt is tighter than the old one, so it's "dragging" on the clutch; you need to break it in for awhile......my two-bits......
Cheers
i guess i can try to get it into gear. it tries to move tho. maybe i just have to get it in gear and go up and down the road a few miles??
If you want to run it to break it in then shift it into gear with the engine off kind of a pain but better that grinding gears.
Familyman is offline
post #17 of 31 Old May 16th, 2012, 09:06 PM
srt20's Avatar
My RZR: 2015 RZR 4 900 Red
Member #23480
View srt20's Photo Gallery(0)
Polaris sleds are know for the clutch alignment to be WAY off from the factory. I wouldnt be surprised if this is true for the rzr as well. If the alignment is off it will drag on the belt and cause the secondary to spin and cause the grinding. I know my rzr did the same thing with the factory belt when new. I havent aligned it yet. It went away after a little while. I will be aligning the clutches sooner or later though, because I will be using a "S" belt in the future.
2015 900 4 SSV Works door pods and glovebox sub, UTV headquarters roof, 30" curved led bar, Mudbusters flares Maxxis Liberty 29x9.5x15 tires, KMC Machete 15" wheels 5x2
Sold
2011 Boardwalk Blue and White LE 26" Bighorns on 14" SIXr wheels, 1.5" spacers, 58" wide, Racertech lift, front and rear bumpers,tunes by SSV Works, LTR 450 shocks
srt20 is offline
post #18 of 31 Old May 16th, 2012, 10:03 PM
Sparky's Avatar
First Name: Dave
My RZR: Aerocharged 1110
Member #1007
View Sparky's Photo Gallery(0)
its an 08, the machine has 30 hours on it. the belt is part number 3211133. will this work?
You have been sold the wrong Polaris CVT belt.
Your '08 RzR takes a 3211113 CVT belt. This measures 1.188"
If you wish to upgrade to a much stronger CVT belt -- The correct belt to use on your '08 is the '09S CVT belt -- 3211130. This measures 1.178"
You have been sold a Polaris CVT belt that is to wide for the spacing of your clutch sheaves. The 3211133 belt measures appx. 1.225". If you wish to use this CVT belt - You must re-shim the clutches thus allowing the use of this wider CVT belt.
You don't have a clutch alignment issue - You're running the incorrect belt for your year RzR.
Use a veneer caliper if you wish to verify this.
Sparky is offline
post #19 of 31 Old May 17th, 2012, 04:49 AM
MN-RZR's Avatar
First Name: Andy
My RZR: 2008 50"
Member #39030
View MN-RZR's Photo Gallery(0)
I have a 2008 with the roller secondary. I have the ***33 belt on it. It is not a belt that just fits, it is as said, to wide. I shimmed my secondary clutch to make this belt work in an attempt for maximum sheave use. You need to take the clutch all apart, split the sheaves and space them apart father to set your delfection. I suggest getting the other belt mentioned.
08' 50" RZR 26" bighorns 14" wheels, 2011' front bumper/hood, pro armor doors, gibson ss exhaust, cooter brown top, dynatek cdi and fuel programmer, kolpin windshield, oil, water, odyssey battery, a/f gauges, rear window, 4500# winch, wireless winch remote, Tusk rear storage bag, Kolpin 4 gal fuel pack, kfx450 front shocks, DIY snorkels, rzr s flares, super atv radiator, rhino axles. swingarm1 clutch kit, Lowrance hds 5m gps, custom tunes. SOLD
MN-RZR is offline
post #20 of 31 Old May 17th, 2012, 05:48 AM
redrzrrider's Avatar
First Name: Butch
My RZR: 2012 LE
Member #17841
I have a new 3211113 belt still in the package that I'm carrying for a spare that I would trade with you, "if you are interested". I'm running a 2012 and looking at the other posts I wouldn't need to shim my secondary. Let me know if ???? if not no big deal. Just trying to rid my 2012 of the squealing when I slow down!
redrzrrider is offline
post #21 of 31 Old May 17th, 2012, 06:30 AM
Sik-06's Avatar
First Name: Dan
My RZR: 2015 XP 4 1000
Member #8915
View Sik-06's Photo Gallery(0)
3211133 is the belt i found in my 2010 RZR4. is that the correct one???
Sik-06 is offline
post #22 of 31 Old May 17th, 2012, 06:40 AM
First Name: Butch
My RZR: 2012 LE
Member #17841
I think that is the correct belt for the RZR 4. If I'm correct the 133 is the S belt that we all want to upgade too! The RZR 4 is a 4 seater in an S suspension, right??? I never could figure out what the difference was between the RZR and the RZR-S when it came to the motor to belt drive! Just different clutching due to the size of the machine or tire wheel combination? Getting back to your ? I think you have the correct belt. Maybe open up the houseing and see what you have on it now..........
post #23 of 31 Old May 17th, 2012, 06:45 AM
Sik-06's Avatar
First Name: Dan
Member #8915
[/QUOTE]
I think that is the correct belt for the RZR 4. If I'm correct the 133 is the S belt that we all want to upgade too! The RZR 4 is a 4 seater in an S suspension, right??? I never could figure out what the difference was between the RZR and the RZR-S when it came to the motor to belt drive! Just different clutching due to the size of the machine or tire wheel combination? Getting back to your ? I think you have the correct belt. Maybe open up the houseing and see what you have on it now..........[/QUOTE]
Yeah i have it opened to see what kind of condition its in and thats the part number on it. I just bought it with 1300 miles and i think its the original and i want to replace it to be on the safe side.
Sik-06 is offline
post #24 of 31 Old May 17th, 2012, 06:49 AM
First Name: Butch
My RZR: 2012 LE
Member #17841
Yeah i have it opened to see what kind of condition its in and thats the part number on it. I just bought it with 1300 miles and i think its the original and i want to replace it to be on the safe side.[/QUOTE]
That's a good idea. This way you have the used belt for a spare. If you break or burn the old belt you have nothing.
Don't forget to clean that new belt with warm soapy water and run her easy for the first 50 miles to break her in. It will last longer for ya! JMO
post #25 of 31 Old May 17th, 2012, 07:04 AM
buchshot's Avatar
First Name: LB
My RZR: 09 rzr
Member #7823
View buchshot's Photo Gallery(0)
In my 09 I just put in the 133 belt with no shimming. It sits above the secondary about 1/8" just like you'd run a sled belt. All I can think of is it might be too short from factory.
buchshot is offline
post #26 of 31 Old May 17th, 2012, 07:46 AM
MN-RZR's Avatar
First Name: Andy
My RZR: 2008 50"
Member #39030
For 2008 some have the Team roller secondary, after that this clutch was not used. If all of you guys can use this belt no problem , of who has posted have newer machines, that is probably the difference.
When I put this belt on it was tight to the bearing on primary and holding secondary open some. I added a shim (.125?)/big washer I machined, I now have the belt riding about 1/8 to 3/16 above on the secondary and about the same on the primary when it is all shifted out.
I never rode it with the stock belt. Results as of now, take off is good, I have seen 62 on dirt road on polaris speedo there is more but lack of room and need to go faster. I have the mods in my signature and all STOCK clutch kit. Take off hit 5800 right away then carries up to about 6200-6300. No belt squeak/squeal.
MN-RZR is offline
post #27 of 31 Old May 17th, 2012, 07:59 AM
I am still 16 in my head!
Kandgo's Avatar
First Name: Rick
My RZR: 09s 08stnd. 11-800s, 12 900XP
Member #22394
Feedback Score: 29 reviews
We have a Winner! Great explanation. Use the Belt that is for your Rig 3211113, for what little gain obtained by a S belt in my opinion is not worth paying twice the amount of money for. Two Standard Belts cost about as much as a S Belt.
Kandgo is offline
post #28 of 31 Old May 17th, 2012, 08:02 AM
Sik-06's Avatar
First Name: Dan
Member #8915
Don't forget to clean that new belt with warm soapy water and run her easy for the first 50 miles to break her in. It will last longer for ya! JMO[/QUOTE]
Thanks man!
Sik-06 is offline
post #29 of 31 Old May 17th, 2012, 09:46 AM
Officially Addicted
BamaRZR's Avatar
First Name: Michael
My RZR: 2015 Black Pearl 900S
Member #30950
View BamaRZR's Photo Gallery(3)
Here is a link and pics of the differences
Works on 2012, anything else I'm not sure. As long as it doesn't creep, it will probably break in. Run it around in the yard in low then see how it does. Maybe mine was set up loose, that's why I was slipping the belt in high gear alot.
BamaRZR is offline
post #30 of 31 Old May 19th, 2012, 07:36 PM Thread Starter
turbotank's Avatar
Member #34513
View turbotank's Photo Gallery(0)
we have a winner!!!!
the 3211130 belt worked. hell i even stumped the polaris parts guys..
admins should move this to the tech section for early rzr stuff
thanks for everyones help
turbotank is offline
Check Engine light and wont show gear orv3c Engine and Drivetrain 6 August 3rd, 2012 06:34 AM
need help just bought new 800 now High gear wont move hbghost General RZR Discussion 12 March 28th, 2012 01:13 PM
RZR wont see low gear dirtjunkey200 Engine and Drivetrain 9 January 30th, 2011 12:37 PM
Wont stay in high gear tjmotors Engine and Drivetrain 6 October 23rd, 2010 03:58 PM
Wont go into gear pszutiak Community Help 2 December 22nd, 2009 09:11 AM
