fan not working - Polaris RZR Forum - RZR Forums.net
post #1 of 19 Old May 15th, 2012, 06:59 AM Thread Starter
longbow's Avatar
First Name: brandon
My RZR: 2012 CAN-AM Commander 800xt( soon to be a rzr again)
Member #21442
View longbow's Photo Gallery(0)
fan not working
i had the circuit breaker under the drivers seat replaced so i dont think that is my problem but my fan will not kick on at all whatsoever and its causing my temp to reach limp mode any ideas....... fuse,bad fan,bad wiring im clue less
longbow is offline
post #2 of 19 Old May 15th, 2012, 07:06 AM
TURBO'S RULE
allcool's Avatar
My RZR: 2010 rzrs
Member #11295
View allcool's Photo Gallery(7)
Re: fan not working
Unplug the temp sensor on the engine.
The fan should now run continuously with key on.
If not, unplug the fan motor it self and test for 12v coming to motor at the connector.
If there is 12v than your motor is bad .
If no 12v's, then test for voltage thru circuit breaker, relay, wiring, connectors.
Good possibility that your just changed out circuit beaker could be related to your problem....
jmo
CURRENT GLAMIS WEATHER
allcool is offline
post #3 of 19 Old May 15th, 2012, 07:07 AM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
Re: fan not working
Unplug the sensor on the head and with the key on (engine doesn't have to be running) the fan should run non-stop...
Try this and let me know what you find out...
swingarm1 is offline
post #4 of 19 Old May 15th, 2012, 07:25 AM Thread Starter
longbow's Avatar
First Name: brandon
Member #21442
Re: fan not working
ok itll be later on before i can get back with you im not home at the moment but will let you know as soon as i can get to the rzr
longbow is offline
post #5 of 19 Old May 15th, 2012, 08:32 AM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
Feedback Score: 5 reviews
I had a bad place in my wire and had to rerun a complete new wire from the breaker to the fuse box. Could be the issue also.
chipper is offline
post #6 of 19 Old May 15th, 2012, 08:52 AM Thread Starter
longbow's Avatar
First Name: brandon
Member #21442
Re: fan not working
Where exactly on the motor is the fan plug thingy i see several plugins around there
longbow is offline
post #7 of 19 Old May 15th, 2012, 08:56 AM
Mattshs2005's Avatar
My RZR: 2009 RZR 800 EFI
Member #27004
Feedback Score: 4 reviews
View Mattshs2005's Photo Gallery(0)
Re: fan not working
delete
Mattshs2005 is offline
post #8 of 19 Old May 15th, 2012, 09:02 AM Thread Starter
longbow's Avatar
First Name: brandon
Member #21442
Re: fan not working
Thanks for the link but that is for an Xp i have the standard model
longbow is offline
post #9 of 19 Old May 15th, 2012, 09:18 AM
chipper's Avatar
First Name: Chip
My RZR: 2011 RZR
Member #15196
There is a greenish and a black wire running to it if i remember right. It comes out of a pigtail under the front box. Remove the tray and you'll see it. Maybe try swapping the relay to see if that's the issue. They are all the same.
chipper is offline
post #10 of 19 Old May 15th, 2012, 10:56 AM
TURBO'S RULE
allcool's Avatar
My RZR: 2010 rzrs
Member #11295
Re: fan not working
Temp sensor is on the head.
here is a pic...
Name:	temp sensor.JPG
allcool is offline
post #11 of 19 Old May 15th, 2012, 11:06 AM Thread Starter
longbow's Avatar
First Name: brandon
Member #21442
Re: fan not working
found it unpluged it and nothing
longbow is offline
post #12 of 19 Old May 15th, 2012, 11:51 AM
TURBO'S RULE
allcool's Avatar
My RZR: 2010 rzrs
Member #11295
Re: fan not working
I would start by going back to the circuit breaker that just got replaced and confirm voltage is going thru the new breaker. Test with volt meter on both sides of circuit breaker.
allcool is offline
post #13 of 19 Old May 15th, 2012, 12:13 PM
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
Re: fan not working
have you checked the relay in the fuse box?
Magicmantx is offline
post #14 of 19 Old May 15th, 2012, 12:22 PM Thread Starter
longbow's Avatar
First Name: brandon
Member #21442
Re: fan not working
not yet im gonna check that next
longbow is offline
post #15 of 19 Old May 15th, 2012, 12:25 PM
swingarm1's Avatar
First Name: Tim
Member #7690
Re: fan not working
Put 12 volt from the battery to one wire on the fan and ground the other wire if the fan doesn't work, it's the fan...
08 Rzr 4wd not working jasondc02 General RZR Discussion 2 March 14th, 2012 02:56 PM
4wd not working? limetime Engine and Drivetrain 2 February 15th, 2012 09:42 PM
Working RZR ridgerunner General RZR Discussion 14 May 16th, 2011 08:50 PM
4wd not working boat4life Engine and Drivetrain 22 June 30th, 2010 08:56 PM
4 wd not working kybodyguy Engine and Drivetrain 1 January 8th, 2010 02:21 PM
