-   -   fan not working (https://www.rzrforums.net/general-rzr-discussion/79037-fan-not-working.html)
longbow May 15th, 2012 06:59 AM
fan not working
i had the circuit breaker under the drivers seat replaced so i dont think that is my problem but my fan will not kick on at all whatsoever and its causing my temp to reach limp mode any ideas....... fuse,bad fan,bad wiring im clue less
allcool May 15th, 2012 07:06 AM
Re: fan not working
Unplug the temp sensor on the engine.
The fan should now run continuously with key on.
If not, unplug the fan motor it self and test for 12v coming to motor at the connector.
If there is 12v than your motor is bad .
If no 12v's, then test for voltage thru circuit breaker, relay, wiring, connectors.
Good possibility that your just changed out circuit beaker could be related to your problem....
jmo
swingarm1 May 15th, 2012 07:07 AM
Re: fan not working
Unplug the sensor on the head and with the key on (engine doesn't have to be running) the fan should run non-stop...
Try this and let me know what you find out...
longbow May 15th, 2012 07:25 AM
Re: fan not working
ok itll be later on before i can get back with you im not home at the moment but will let you know as soon as i can get to the rzr
chipper May 15th, 2012 08:32 AM
I had a bad place in my wire and had to rerun a complete new wire from the breaker to the fuse box. Could be the issue also.
longbow May 15th, 2012 08:52 AM
Re: fan not working
Where exactly on the motor is the fan plug thingy i see several plugins around there
Mattshs2005 May 15th, 2012 08:56 AM
Re: fan not working
delete
longbow May 15th, 2012 09:02 AM
Re: fan not working
Thanks for the link but that is for an Xp i have the standard model
chipper May 15th, 2012 09:18 AM
There is a greenish and a black wire running to it if i remember right. It comes out of a pigtail under the front box. Remove the tray and you'll see it. Maybe try swapping the relay to see if that's the issue. They are all the same.
allcool May 15th, 2012 10:56 AM
Re: fan not working
1 Attachment(s)
Temp sensor is on the head.
here is a pic...
longbow May 15th, 2012 11:06 AM
Re: fan not working
found it unpluged it and nothing
allcool May 15th, 2012 11:51 AM
Re: fan not working
I would start by going back to the circuit breaker that just got replaced and confirm voltage is going thru the new breaker. Test with volt meter on both sides of circuit breaker.
Magicmantx May 15th, 2012 12:13 PM
Re: fan not working
have you checked the relay in the fuse box?
longbow May 15th, 2012 12:22 PM
Re: fan not working
not yet im gonna check that next
swingarm1 May 15th, 2012 12:25 PM
Re: fan not working
Put 12 volt from the battery to one wire on the fan and ground the other wire if the fan doesn't work, it's the fan...
