fan not working - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 19 Old May 16th, 2012, 12:20 PM Thread Starter
longbow's Avatar
First Name: brandon
My RZR: 2012 CAN-AM Commander 800xt( soon to be a rzr again)
Member #21442
View longbow's Photo Gallery(0)
Re: fan not working
well i figured out he problem i went back to the recently replaced circuit breaker and found a wire had completely corroded off so its an easy fix...... thanks for your help...... by the way is there a way to bypass the darn thing
longbow is offline
post #17 of 19 Old May 16th, 2012, 12:32 PM
Mattshs2005's Avatar
My RZR: 2009 RZR 800 EFI
Member #27004
Feedback Score: 4 reviews
View Mattshs2005's Photo Gallery(0)
Re: fan not working
most people relocate it higher up. My friend moved his by the ecu behind the driver seat.
Mattshs2005 is offline
post #18 of 19 Old May 16th, 2012, 12:51 PM
olddognewtrick's Avatar
First Name: Jim
Member #18785
Re: fan not working
I am tempted to run a bypass wire to a dash mounted switch to override the CB in case it takes a dump on a ride.
Gotten into the habit of keeping my display on the engine temp because of these threads.
2011 Pursuit Camo
olddognewtrick is offline
post #19 of 19 Old May 16th, 2012, 02:42 PM
Magicmantx's Avatar
First Name: Bruce
My RZR: 2016 Graphite XPT
Member #20584
Re: fan not working
UTV makes a fan override kit. Costs like 30 bucks or so. Very easy to install. I had to put one on out of necessity when my fan quit and I didn't know about the circuit breaker and we were 12 hrs from home riding. installed the kit and kept riding. got home did a little forum research and dug in and relocated it up by the ecu. High and dry and easy to access if it should cause a problem in the future. its good to know though that I can just flip a switch to turn on my fan at will. Quality kit for the price. Glad you got it figured out.
Magicmantx is offline
08 Rzr 4wd not working jasondc02 General RZR Discussion 2 March 14th, 2012 02:56 PM
4wd not working? limetime Engine and Drivetrain 2 February 15th, 2012 09:42 PM
Working RZR ridgerunner General RZR Discussion 14 May 16th, 2011 08:50 PM
4wd not working boat4life Engine and Drivetrain 22 June 30th, 2010 08:56 PM
4 wd not working kybodyguy Engine and Drivetrain 1 January 8th, 2010 02:21 PM
