Polaris Rock Sliders - Polaris RZR Forum - RZR Forums.net
post #1 of 17 Old May 8th, 2012, 07:59 PM Thread Starter
ed43082's Avatar
First Name: Ed
My RZR: 2008 RZR
Member #37620
View ed43082's Photo Gallery(0)
Anyone have these?
I have a set on my 2008 and they fit tight to the rockers like I think they should. I just installed a new set on my 2012 and Polaris has completely changed the design. They are longer, look cheaper, and when installed there is about 1.25 inch gap between the rocker and the rock slider. They are mounted as close as I can get them. I'm thinking of cutting an inch off the brackets and drilling new holes to mount them closer to the rocker panel. They almost look like an atv nerf bar at this point and add about 4 inches to the width of the machine. I think they look hokey if you ask me.
Does it have this gap on your RZR?
ed43082 is offline
post #2 of 17 Old May 8th, 2012, 08:05 PM
Blu
Blu's Avatar
My RZR: 2012 800 EPS
Member #37286
View Blu's Photo Gallery(0)
Re: Polaris Rock Sliders
yep. Mine have that same gap and I have been contemplating about whether to deal with it, or just leave it. If you do modify yours, I would be interested to see what you come up with. I have the "S" flares and they didn't look so pronounced after I installed the flares.
2012 800 EPS - RacerTech 2" Lift, 3500lb winch, 14" Big Horns on Black Rims, "S" Flares, ProArmor Doors and Top, Flip Up Windshield, Windjammer, Rocker Guards, 3/8" FUTV Skid Plate w/ Arm Guards and Gas Tank Guard, ATV Guru Brush Guard and Bow Rack, Rear Cage Extension Bars, Rear storage rack, Lock Box with Cooler Rack, and Spare Tire.
Blu is offline
post #3 of 17 Old May 9th, 2012, 05:15 AM
revr's Avatar
My RZR: 2009 800
Member #7367
View revr's Photo Gallery(0)
Canada Re: Polaris Rock Sliders
I have the same gap too. i would like to know about any mods as well.
revr is offline
post #4 of 17 Old May 9th, 2012, 09:25 AM
JimL's Avatar
Member #7207
View JimL's Photo Gallery(0)
Couple good hits and they will be bent up tight to the plastic. At least mine did. First ride.
JimL is offline
post #5 of 17 Old May 9th, 2012, 09:32 AM
olddognewtrick's Avatar
First Name: Jim
Member #18785
The FUTV sliders are the way to go, not pretty to look at, but do the job and will not snag on something and tear the hell out of your rocker panel.
JMHO
2011 Pursuit Camo
olddognewtrick is offline
post #6 of 17 Old May 9th, 2012, 10:03 AM
FunRide's Avatar
First Name: Jim
My RZR: None
Member #17399
JMHO
Yeah but they don't cover anything more than just the rocker panel if one has a factory skid. You need something that has some width to it to protect the areas missed by the factory plate.
FunRide is offline
post #7 of 17 Old May 9th, 2012, 10:08 AM
First Name: Jim
Member #18785
JMHO
Oh yeah, gotcha!
Hard for me to imagine folks are still running on those factory skids..
Whoa..
2011 Pursuit Camo
post #8 of 17 Old May 12th, 2012, 08:07 PM Thread Starter
ed43082's Avatar
First Name: Ed
My RZR: 2008 RZR
Member #37620
No mods. Took them back off and took them back to the store with part number of old style like on the '08. Polaris still carries the old style. They just don't have them in their catalog for the past couple years. Exchanging them out for the old style.
ed43082 is offline
post #9 of 17 Old May 12th, 2012, 08:10 PM
King of crash!
Member #787
re drill sounds the way to go
johnnycat8 is offline
post #10 of 17 Old May 12th, 2012, 08:47 PM Thread Starter
ed43082's Avatar
First Name: Ed
My RZR: 2008 RZR
Member #37620
I was looking at the mod. I wasn't comfortable with just redrilling the bracket as it looked like the bolt holes would have been to close together for my liking. I would have had to weld an extension onto the bracket then redrill to the existing frame holes if they wouldn't have done the exchange. The old style was much more heavier duty. Same style as the aluminum ones but in metal. Not sure why they changed the metal style.
ed43082 is offline
post #11 of 17 Old May 21st, 2012, 07:10 PM
BigBird2's Avatar
My RZR: 2011 RZR 800 Walker Evans
Member #30424
View BigBird2's Photo Gallery(0)
Can you or anyone give me the old style part number?
BigBird2 is offline
post #12 of 17 Old May 21st, 2012, 07:26 PM
dsmracing1's Avatar
First Name: Cameron
My RZR: 2011 RZR 800 Walker Evans Edition
Member #27601
View dsmracing1's Photo Gallery(8)
First ride out with the rock sliders blew the two cheap little rear bolts they give you on both rock sliders. Selling them and trying to find out how to get a drill or something up in that tight area to pull the threads out which are stuck now. Not Impressed with the design of these at all.
Your Not Having Fun Til Your Rolled Or Stuck!
Warn RT40 4000lb Winch, 30" Gorilla Silverback Tires on STI HD2 SE Rims, Rhino Axles On All 4 Corners, Arctic Thunder Snorkel, Racer Tech 2" Lift/Progresssive Springs, EMP Gas Tank Guard and Outback Bumper, Pro Armor Doors, FUTV A-Arm Guards, SSV Marine Stereo, 30" Totron Light Bar, Dalton Clutch, Cooter Brown Skid, SATV Power Steering
BRAAAAAAP!
dsmracing1 is offline
post #13 of 17 Old May 21st, 2012, 07:31 PM
trizo123's Avatar
First Name: Troy
My RZR: 2011 RZR LE
Member #20859
View trizo123's Photo Gallery(0)
I busted my bolts also. Just use needle nose vise grips and thread it in till it falls out. Or just drill the hole bigger and use a bolt and nut to install again.
trizo123 is offline
post #14 of 17 Old May 21st, 2012, 08:14 PM
WHKed-Rider's Avatar
First Name: Warren
My RZR: 2012 800 S Liquid Silver LE
Member #39772
View WHKed-Rider's Photo Gallery(6)
Or you can go to Sear, Lowes or Home Depot and get an EZ Out that is designed to remove broken bolts. That way you don't mess up the original threads. Just put in a better quality bolt the next time from your local hardware store.
WHKed-Rider is offline
post #15 of 17 Old May 21st, 2012, 09:11 PM
trizo123's Avatar
First Name: Troy
My RZR: 2011 RZR LE
Member #20859
It's tiny bolts, I drilled it out and used better bolts with nuts.
trizo123 is offline
Polaris xp 9 rock sliders blumaro Polaris RZR Parts For Sale 0 December 14th, 2011 05:27 AM
Polaris Rock Sliders Pud RZR XP 900 4 September 13th, 2011 08:14 PM
Polaris rock Sliders... how do you get them off chipster314 General RZR Discussion 3 April 17th, 2011 07:33 PM
New rock sliders from Polaris... justinator General RZR Discussion 2 December 26th, 2010 05:06 AM
OEM Polaris Rock Sliders txmd500 Polaris RZR Parts For Sale 4 February 8th, 2008 01:59 PM
