oil pressure sending uinit - Polaris RZR Forum - RZR Forums.net
post #1 of 18 Old April 12th, 2012, 05:12 AM Thread Starter
bengalwill's Avatar
Member #35802
View bengalwill's Photo Gallery(0)
Going to install an autometer electric oil pressure guage and I'm not sure where the sending unit should be installed. I have a 2012 and I believe I see the stock sender near the oil filter but I'm not sure how it is threaded?
bengalwill is offline
post #2 of 18 Old April 12th, 2012, 05:15 AM
swingarm1's Avatar
First Name: Tim
Member #7690
Feedback Score: 176 reviews
Re: oil pressure sending uinit
You need a flex hose between the cases and sending unit... If you use a hard pipe style nipple it'll break for sure...
swingarm1 is offline
post #3 of 18 Old April 12th, 2012, 07:44 AM Thread Starter
bengalwill's Avatar
Member #35802
where at on the cases?? I see a plug above the oil filter but I'm thinking this may have something to do with the oil pump. Does anybody have pic's with there flex hose installed?
post #4 of 18 Old April 12th, 2012, 08:08 AM
GenDis's Avatar
My RZR: 2008 RZR
Member #10100
View GenDis's Photo Gallery(0)
I think that is where I installed my sending unit. I will have to look when I get home and try and post a pic of my install. But I do think mine was right above my oil filter on an 08 rzr 800.
GenDis is offline
post #5 of 18 Old April 12th, 2012, 08:14 AM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
Thanks to whoever pict this is , but this is where it goes.
post #6 of 18 Old April 12th, 2012, 08:16 AM
GenDis's Avatar
My RZR: 2008 RZR
Member #10100
NVM, beat me to it.lol
GenDis is offline
post #7 of 18 Old April 12th, 2012, 08:28 AM
swingarm1's Avatar
First Name: Tim
Member #7690
YES BUT USE A FLEX LINE BETWEEN THE FITTING IN THE CASES AND THE SENDING UNIT or it will break from vibrations......
post #8 of 18 Old April 12th, 2012, 09:43 AM Thread Starter
bengalwill's Avatar
Member #35802
I'm thinking mine is different, I have a 2012 and I don't believe the is a plug or tapped hole there. My OEM sending unit looks to be above the oil filter in a little bit of a different area. I'll check when I get home, thanks for all the help and I'll let you know if mine looks the same.
post #9 of 18 Old April 12th, 2012, 05:12 PM Thread Starter
bengalwill's Avatar
Member #35802
I was wrong, when I got home I looked and there is a plug like the picture posted, thanks for the help and I'll definately put the flex line in.
post #10 of 18 Old May 31st, 2012, 11:42 AM
diggerbuzz's Avatar
First Name: Brad
My RZR: 2012 Xp 900 LE
Member #18641
View diggerbuzz's Photo Gallery(0)
I called auto meter cause im wanting to install one on my xp also and they said the pro-comp fluid filled is the only one they recommend for a UTV. Do we need a sender or is that just on electrical guages and not mechanical ?
diggerbuzz is offline
post #11 of 18 Old May 31st, 2012, 12:14 PM
RacerSam's Avatar
My RZR: 2009 Nuclear Orange LE, 2012 Walker Evans
Member #7858
View RacerSam's Photo Gallery(0)
above the oil filter is camshaft sensor to let ECU know when #1 is @ TDC, required on 2011-2012 models since they have sequential fuel injection vs bank or batch fire eFI on 2008-2010 models
'16 Graphite Crystal turboXP
'14 Black Stealth 900XP
'12 Walker Evans 800
'09 Nuclear Orange 800LE SOLD
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #12 of 18 Old May 31st, 2012, 12:14 PM
RacerSam's Avatar
Member #7858
any reason that freeze plug is installed backwards?
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
post #13 of 18 Old May 31st, 2012, 12:29 PM
rardoin's Avatar
First Name: robin
My RZR: 2010 RZR LE +3
Member #16043
"any reason that freeze plug is installed backwards?"
Yes...that is a counter-rotating engine sold in the Southern hemisphere. Maybe some Aussies will chime in!
rardoin is offline
post #14 of 18 Old May 31st, 2012, 02:24 PM
Pirate's Avatar
First Name: Stuart
Member #3677
Do yourself a favor and get a Dakota Digital gauge. I have the Dakota Digital Oil Pressure, Water Temp and Voltage. Gives me accurate readings and with a quick scan of the dash I know what's going on.
I got the Concours Specialties dash plates as a door prize at the RZRForums rally in Taylor Park, CO. I would recommend them as they are excellently made.
Here's a couple pictures of my oil pressure sending unit. Flex line came with my old gauge set from Quadovator. Don't know if they are still out there or not.
Pirate
Pirate is offline
post #15 of 18 Old May 31st, 2012, 06:56 PM
RacerSam's Avatar
Member #7858
Pirate
is that some sort of oil filter relocation set-up I see to the side where the braided hose with red/blue hose end is? would love to relocate mine, as its sorta hard to get to and get much grip on it. thanks
'11 rzr170 SOLD
'05 YFZ450 SOLD
RacerSam is offline
Oil pressure sending unit install location?? jakal RZR XP 900 12 January 19th, 2012 07:05 AM
Oil Pressure Sending Unit ronb172 RZR-S Specific Discussion 4 January 25th, 2011 11:01 AM
Inline Oil Pressure Sending Unit - Install Help temecularanger RZR-S Specific Discussion 18 October 6th, 2009 03:19 PM
sending unit ThaMule Want to Buy 4 July 20th, 2009 11:38 AM
Oil pressure sending unit!!! Davemn41 Engine and Drivetrain 19 February 17th, 2009 09:51 PM
