Sprague Carrier Replacement - VIDEO - Page 3 - Polaris RZR Forum - RZR Forums.net
post #31 of 41 Old February 12th, 2012, 11:15 AM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
Re: Sprague Carrier Replacement - VIDEO
Originally Posted by CallingAllBobs View Post
Another update - I put on about 50 miles on heavy, muddy trails. Lot's of big logs and rocks. It was this environment that broke the plastic carrier and the new one is holding up great. At one point I came down pretty hard on spinning front wheels and cringed thinking I'd hear the dreaded ratchet sound. Nope. I only heard the sound of my RZR tearing forward through logs, rocks and mud! This is a great fix.
That "ratchet" sound is terrible to hear...Even with the billet sprague, sooner or later you will hear it again. I haven't seen a rzr not make that sound including the XP--its just the design of the hillard clutch but for some reason I'm begining to think that contaminated diff fluid greatly contributes to it...You can go on two or three hard rides and the front diff fluid will be black again with fine metal. There is a lot of wear going on in that front diff..The fluid needs to be changed much more often than what the manual calls for...
post #32 of 41 Old February 12th, 2012, 03:24 PM Thread Starter
CallingAllBobs's Avatar
My RZR: 2010 RZR LE
Member #13516
View CallingAllBobs's Photo Gallery(0)
Thanks for the heads up. I'm not very disciplined at changing out the front diff fluid like I should be. I will be now...
CallingAllBobs is offline
post #33 of 41 Old February 27th, 2012, 05:09 PM
Baditude's Avatar
My RZR: 2011 RZR XP
Member #1091
View Baditude's Photo Gallery(18)
First off thanks for the video has really helped me working on mine.
Where the magnet is there is a small metal piece that goes over it and it seems there is some way to adjust the depth of the magnet - it can be seen on yours towards the end of the video when you are putting the top cover on the diff before testing.
Mine is loose - I have pinched the ends in bit in the vise so it will stay on, did your magnet stick up 1/4" or so? I think someone tweeked enough to push that metal piece up enough to just be grabbing on the sides. Is that normal? Do I need to adjust it back down?
Its red and can be seen in your video around the 8 min mark on the top piece in the left of the video.
Without clamping it a bit would would just fall off down in the diff - curious how it is supposed to go before I finalize putting it back together.
#21 2203733
BUTTON-THRUST,DC(6203-42-037)
Baditude is offline
post #34 of 41 Old February 27th, 2012, 06:21 PM Thread Starter
My RZR: 2010 RZR LE
Member #13516
#21 2203733
I went back to the source video files and clipped out the entire section where I re-installed the armature plate. Maybe this will help?
I have plenty of time on the new carrier and it's working as expected. Turns on and off when needed.
post #35 of 41 Old February 27th, 2012, 06:56 PM
Norcal RZR's Avatar
My RZR: 2017 XPT
Member #15568
View Norcal RZR's Photo Gallery(6)
nice video...thanks for sharing.
Norcal RZR is offline
post #36 of 41 Old February 27th, 2012, 07:54 PM
FlatBlack's Avatar
Member #33886
View FlatBlack's Photo Gallery(0)
Deleted by FlatBlack
FlatBlack is offline
post #37 of 41 Old February 28th, 2012, 03:21 AM
Baditude's Avatar
My RZR: 2011 RZR XP
Member #1091
#21 2203733
Sure did - yours does not stick out at all, the red metal piece is flat. against the pushrod
Baditude is offline
post #38 of 41 Old February 28th, 2012, 07:19 AM
TURBO'S RULE
allcool's Avatar
My RZR: 2010 rzrs
Member #11295
View allcool's Photo Gallery(7)
Its refreshing to see a guy with good mechanical ability, that really knows how to spin a wrench, use an air ratchet, a punch, volt meter power source, understands oil seals, etc...
Very nicely done.
Just curious what do you do for a living?
You might be able to save a step by removing less front end components, and still be able to weasel out the axles.
I recommend you pm a mod or admin and put this in the Wiki section. Your video is the best Sprague Carrier Replacement vid I've seen so far, by a lot.
jmo
CURRENT GLAMIS WEATHER
allcool is offline
post #39 of 41 Old February 28th, 2012, 07:41 AM
HIGHOCTANE
Guest
HIGHOCTANE's Avatar
Member #
Posts: n/a
View HIGHOCTANE's Photo Gallery()
Originally Posted by yoshman762 View Post
Does anyone have an update on the 50" and S model carriers? Are they plastic like previous years or metal like the XP? Thanks for the time and effort on the video btw, well done!
Yoshman762
According to the parts manual they are zinc. Aluminum is listed as a "high performance accessory". The XP gets Billet Aum.
post #40 of 41 Old February 28th, 2012, 08:17 AM Thread Starter
My RZR: 2010 RZR LE
Member #13516
Very nicely done.
jmo
Thanks. I'm just a hack, really. I don't know how to do most things, but I do know I can figure things out! It's amazing what you can learn on YouTube and I'm grateful for folks who take the time to share knowledge. Just trying to do my part. I'm a business consultant and help companies run better.
Another member mentioned the same thing about removing less parts to get the axle out. It looks like you can disconnect the steering arm, lower shock mount and A-arm bolts and pull the whole thing forward? That would save the time of removing the brakes & caliper. I didn't consider that. Having done this once though, I could probably have that differential out in 20 minutes the next time. I think it took me a couple of hours the first time.
post #41 of 41 Old May 22nd, 2012, 02:32 PM Thread Starter
My RZR: 2010 RZR LE
Member #13516
Another follow-up.
As advised above (which I really appreciate) I changed the front diff fluid Saturday and was surprised at how contaminated it was. As predicted, fluid was dark and plenty of shiny metal particles. I actually changed it, drove around the house a couple of times and changed it again. I think that was a good call because I could see remnants of old fluid and some aluminum. After the second change, I drew some out through the fill port and it was very clear and clean. It will be interesting to see what happens on the next change to see if the wear keeps up at this rate.
Sprague carrier zach7 RZR XP 900 2 November 10th, 2011 06:45 PM
Free Sprague Carrier SuperATV Suspension 3 October 4th, 2010 08:03 AM
Sprague Carrier Sale SuperATV General RZR Discussion 0 September 13th, 2010 07:18 AM
Sprague carrier mac013 General RZR Discussion 2 September 6th, 2010 04:04 AM
Sprague Carrier Replacement Installation SuperATV Engine and Drivetrain 7 July 24th, 2010 08:43 PM
