Sprague Carrier Replacement - VIDEO - Page 2 - Polaris RZR Forum - RZR Forums.net
post #16 of 41 Old December 29th, 2011, 04:47 PM
tanglefoot69's Avatar
First Name: Peter
Member #32425
View tanglefoot69's Photo Gallery(5)
Re: Sprague Carrier Replacement - VIDEO
Originally Posted by CallingAllBobs View Post
Originally Posted by Wreckless123 View Post
With the plastic carrier gone, what is the next weak link?
That's a good question and I don't have the answer. I assume you're asking because with that part now fortified, the next failure will be something more catastrophic and expensive. I don't think Polaris designed the plastic part to intentionally fail to protect other components though. It was more likely a cost consideration. The reason I think that is because the current models now have metal carriers. They had to respond to the high failure rate of that part by designing a better one.
Nice Video,so the 2012's have a metal carrier?
2017 Polaris General 1000 White Lightening,Pro fit roof,Lock & Ride half windshield,Rear Panel,Rearview mirror,Polaris wireless winch remote,Polaris 4500lb winch.Polaris Glacier Pro Plow.
tanglefoot69 is offline
post #17 of 41 Old December 29th, 2011, 04:55 PM
nozzleman's Avatar
First Name: Philip
My RZR: RZR 50"
Member #22371
View nozzleman's Photo Gallery(0)
What year did they start putting metal carriers in?
nozzleman is offline
post #18 of 41 Old December 29th, 2011, 05:16 PM Thread Starter
CallingAllBobs's Avatar
My RZR: 2010 RZR LE
Member #13516
View CallingAllBobs's Photo Gallery(0)
I better qualify the OEM metal carrier comment. I know the XPs have them but I'm not sure about the RZR or RZRS model. Someone should be able to confirm.
CallingAllBobs is offline
post #19 of 41 Old December 29th, 2011, 05:39 PM
stomper's Avatar
First Name: Brent
My RZR: 2008 RZR
Member #12554
View stomper's Photo Gallery(0)
Thanks for the vid. I was wondering what it looked like in there. Looks pretty simple to do.
stomper is offline
post #20 of 41 Old December 29th, 2011, 05:57 PM
Wreckless123's Avatar
First Name: Tim
My RZR: 2012 RZR4
Member #27965
View Wreckless123's Photo Gallery(0)
After reading about the plastic carrier, I am convinced Polaris put it in there to save them on Warrenty claims. Its a very weak, weak link. Its going to fail before anything else and its a cheap fix. Thats my take..
2012 RZR4
Wreckless123 is offline
post #21 of 41 Old December 29th, 2011, 09:26 PM
jerrzr
Guest
jerrzr's Avatar
Member #
Posts: n/a
View jerrzr's Photo Gallery()
Nice vid! Next weak link is the outer CV joints and front hubs - These will need to be upgraded next.
post #22 of 41 Old December 29th, 2011, 10:04 PM
Ridin' above 10,000 ft!
J to the B's Avatar
First Name: Jim
My RZR: 2015 XP1K Blue Dragon
Member #6112
View J to the B's Photo Gallery(21)
A great video.....that took a lot of effort to put together!
J to the B is offline
post #23 of 41 Old December 29th, 2011, 10:46 PM
pawngod's Avatar
My RZR: 2016 XPT BLUE
Member #12452
Feedback Score: -1 reviews
View pawngod's Photo Gallery(4)
i am fixing to do this on my rzr, do you have to remove the upper a-arm? on either side? another video showsthe diff. removed from passenger side, and yours from drivers side? will it go out either side? do i have to totally break down the wheel assemblyand remove hub or to remove axle, i wondered if the top a arm removed would let the axle come out while attached as hub end? trying to remove as least amount of bolts possible. thanks
09 RZR S k&t turbo (SOLD)
2012 ARCTIC CAT WILDCAT 1000 (SOLD)
2015 RZR XP 1000 (SOLD)
2016 XPT BLUE
pawngod is offline
post #24 of 41 Old December 30th, 2011, 12:24 AM
MrGrim's Avatar
My RZR: XP 900
Member #33266
View MrGrim's Photo Gallery(0)
Very nice video. A+
Thank you sir.
MrGrim is offline
post #25 of 41 Old December 30th, 2011, 07:32 AM Thread Starter
My RZR: 2010 RZR LE
Member #13516
I don't know about removing the upper A-arm but that seems much harder to me. You would also have to remove the lower arm as well and pull the whole thing away from the machine. All you have to do is separate the hub (knuckle) from the A-arm ball joint as I did and then you can pull out the axle. One bolt you can save is the lower pinch bolt on the hub. It does not need to come out. Just the upper pinch bolt. That would save a little effort.
And yes, the differential can come out either side. One thing I'd suggest is to re-attach the vent tube before re-installing the diff. It's pretty tight doing it after.
post #26 of 41 Old December 30th, 2011, 01:42 PM
Itstoolate's Avatar
Member #19454
View Itstoolate's Photo Gallery(0)
Thank you, excellent video qulaity and job of describing the process.
Itstoolate is offline
post #27 of 41 Old January 2nd, 2012, 01:49 PM Thread Starter
My RZR: 2010 RZR LE
Member #13516
Just a follow-up. I spent some quality time in the machine on Saturday and confirmed everything is working great. AWD comes on an off as it should.
post #28 of 41 Old February 11th, 2012, 02:33 PM
yoshman762's Avatar
My RZR: 2012 RZR S 800 LE tan
Member #35023
View yoshman762's Photo Gallery(0)
Does anyone have an update on the 50" and S model carriers? Are they plastic like previous years or metal like the XP? Thanks for the time and effort on the video btw, well done!
Yoshman762
yoshman762 is offline
post #29 of 41 Old February 11th, 2012, 05:59 PM
sandcrazy's Avatar
First Name: mike
My RZR: 2013 rzr s 2015 xp 1000
Member #33170
View sandcrazy's Photo Gallery(0)
great video
sandcrazy is offline
post #30 of 41 Old February 12th, 2012, 09:04 AM Thread Starter
My RZR: 2010 RZR LE
Member #13516
Another update - I put on about 50 miles on heavy, muddy trails. Lot's of big logs and rocks. It was this environment that broke the plastic carrier and the new one is holding up great. At one point I came down pretty hard on spinning front wheels and cringed thinking I'd hear the dreaded ratchet sound. Nope. I only heard the sound of my RZR tearing forward through logs, rocks and mud! This is a great fix.
Sprague carrier zach7 RZR XP 900 2 November 10th, 2011 06:45 PM
Free Sprague Carrier SuperATV Suspension 3 October 4th, 2010 08:03 AM
Sprague Carrier Sale SuperATV General RZR Discussion 0 September 13th, 2010 07:18 AM
Sprague carrier mac013 General RZR Discussion 2 September 6th, 2010 04:04 AM
Sprague Carrier Replacement Installation SuperATV Engine and Drivetrain 7 July 24th, 2010 08:43 PM
