Helicoil in Differentials - Polaris RZR Forum - RZR Forums.net
 7Likes
  • 2 Post By 702youngbergs
  • 3 Post By dmcmark
  • 1 Post By CA 800
  • 1 Post By markwalker
post #1 of 10 Unread Yesterday, 11:30 AM Thread Starter
SpyGame's Avatar
My RZR: 17 XP4T
Member #62431
View SpyGame's Photo Gallery(0)
17 Turbo both front and rear diffs drainplugs are stripped whereas I screw the plug in it fails to get tight. The plug/bolt is fine and I can get it out w/o issue.
My plan is to use a helicoil kit off Amazon to fix this. I have never done this before, I am told its rather simple. They have different sizes though, anyone know what to get?
I see one with this title: CO-Z 131 pc Stripped Thread Rethread Recoil Repair Kit Metric M5 M6 M8 M10 M12
Thank you
SpyGame is online now
post #2 of 10 Unread Yesterday, 02:21 PM
markwalker's Avatar
First Name: mark
My RZR: 2008 RZR 800
Member #210785
View markwalker's Photo Gallery(0)
Re: Helicoil in Differentials
Just "bite the bullet" and buy these. Never worry about it again.
https://www.sandcraftmotorsports.com...rain-plug-kit/
markwalker is offline
post #3 of 10 Unread Yesterday, 03:17 PM
GPS GURU
702youngbergs's Avatar
My RZR: 2019 XP1000 RC
Member #269632
View 702youngbergs's Photo Gallery(0)
How is buying that gonna solve his stripped plug problem?
I have used helicoils in head studs before with good results but not in any areas that have fluid transfer. I would worry about leaks myself. But Maybe your copper gasket will work well enough
DogRunner2 and RZR_Scott like this.
702youngbergs is online now
post #4 of 10 Unread Yesterday, 05:12 PM
Standard Vendor
dmcmark's Avatar
Member #36968
View dmcmark's Photo Gallery(0)
Unless you bond the coil in somehow it might leak. If you can get them out you could find the next size up tap in American standard, tap them out and use a bolt and o-ring. Might even consider an NPT tap and plug, They are tapered and it will probably seal better.
Regards,
Denver, RWB713 and RZR_Scott like this.
Mark
Feel free to contact us at 760-955-1409 if you have any questions about any of our products.
Visit our website at Desertcraft
Like us on Facebook
dmcmark is offline
post #5 of 10 Unread Yesterday, 05:44 PM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
I think the rear gearcase drain plug is M18 X 1.5 ORB (O-Ring Boss)
and the front gearcase drain plug is M16 X 1.5 ORB
Take a look at this link for pros and cons on different repair options.
https://ricksfreeautorepairadvice.co...il-drain-plug/
RZR_Scott likes this.
2014 800 LE w/EPS 50
CA 800 is online now
post #6 of 10 Unread Yesterday, 05:52 PM
Impact344's Avatar
Member #268904
How did you end up stripping them? I'm JW I know they get real tight for some reason I always use antiseize after I put them back in to help and if you could get them somewhat tight you can use gear oil rtv to seal it but idk how bad its striped
Impact344 is offline
post #7 of 10 Unread Today, 12:52 AM
Ruko's Avatar
First Name: Rob
My RZR: 2013 900XP W.E.
Member #47257
View Ruko's Photo Gallery(0)
The diff plugs are an ORB (O-Ring Boss) so you will need an ORB insert. A helicoil will not work with an ORB plug.
Here is an example of what you should look for.
O-Ring Boss Inserts for Hydraulic Fittings and Drain Plugs - Basic Kits On Lock-N-Stitch
Ruko is offline
post #8 of 10 Unread Today, 04:47 AM
markwalker's Avatar
First Name: mark
Member #210785
Sorry. I thought he stripped the pathetic 8mm hex opening for the plug removal. Carry on.
post #9 of 10 Unread Today, 01:34 PM Thread Starter
SpyGame's Avatar
My RZR: 17 XP4T
Member #62431
I was careful, but just tightened them a tad too tight. The first go around I covered the bolt with gasket maker and it worked fine. Did not leak or move a bit. Just changed the oil in the rear, was going to do the same thing, but it just feels a little looser now. Beyond what I consider comfortable.
A friend said helicoil, seems as if that is being met with mixed reviews.
Starting to sound like its going in the trailer and over to Ridenow.
post #10 of 10 Unread Today, 02:33 PM
RodHatter's Avatar
First Name: Rod
My RZR: 2019 Polaris RZR XP Turbo S
Member #271580
View RodHatter's Photo Gallery(0)
If the plugs out how about JB weld? Or use JB weld with you Helicoil to seal it.
RodHatter is offline
