Amsoil AGL Alternative Not Safe? - Polaris RZR Forum - RZR Forums.net
 11Likes
post #1 of 37 Old October 26th, 2019, 02:56 PM Thread Starter
dafish's Avatar
My RZR: '18 XPT
Member #223617
View dafish's Photo Gallery(0)
VOA research has shown Polaris AGL to be a 0W to 5W oil. While the additive package could be found in a motor oil, the oil analyst suggested it was very much like tractor hydraulic oil. In fact, for a time Amsoil themselves stipulated their synthetic tractor hydraulic fluid as a replacement.
Today Amsoil stipulates a GL-5 gear oil rated at 75W-90 to replace AGL. However, while the cold flow viscosity of such an oil has quite a range, that range starts at 10W and could be as high as 20W (on the motor oil J300 table). Note then the possible range never touches the 0W-5W range AGL reportedly occupies.
Now Im not saying this wont work, or perhaps be even better. I AM saying it appears to no longer be a direct replacement. Might this void warranty? Since its viscosity is higher, doesnt this eliminate Magnuson-Moss? Is cold operation compromised?
And what might Amsoil have to say? Ive seen no explanation for why they now specify a thicker rated oil, and/or what that might mean in cooler operating situations. Is there a case that it clings or climbs better (this is a splash lubrication application)? Might it be that their oil actually does meet 5W flow rating? Ive not seen a lower cold viscosity gear oil rating (J306) than 75W, and perhaps there isnt one.
Anybody got a great Amsoil contact that would care to comment? Id like to change my tranny oil, and Id like to use Amsoil, but
Respect to all,
D
dafish is online now
post #2 of 37 Old October 27th, 2019, 09:54 AM
ItchinToRide's Avatar
My RZR: 2013 800LE 50"
Member #8600
View ItchinToRide's Photo Gallery(0)
Re: Amsoil AGL Alternative Not Safe?
I personally don't agree with the product Amsoil recommends for use in both the transmission and rear end (ATV/UTV Differential and Transmission Fluid). I think they missed a critical difference between the two applications. The factory transmission and Tx case are not lubed with gear lube. The rear end uses gear lube, the transmission uses a fluid more akin to ATF or hydraulic fluid. Its exact non-Polaris equivalent is unknown (unfortunately). The rear end needs gear lube, any will do. Amsoil's product is wrong for one or the other of these applications.
Many people swear by putting gear lube (such as 75w90) and a variety of other types in their transmission/Tx. I'm sticking with AGL. I don't want anything in there that doesn't have the climb rate and other properties Polaris selected for their machines. I don't want to mess with different seal swelling and compatibility either. I just buy the genuine stuff from discounters such as FixMyToys and get a good nights sleep. YMMV. JMO, I'm only at 8000 miles on AGL.
185EZ likes this.
Last edited by ItchinToRide; October 27th, 2019 at 09:54 AM. Reason: Showed up as a quote
ItchinToRide is offline
post #3 of 37 Old October 27th, 2019, 09:17 PM
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
I've ran Lucas universal hydraulic oil in the front diff of every rzr I've ever owned and I've owned pretty much all of them. (10 800s, 12 900xp, 14 1000xp 16 xpt and 18 rs1) I've also ran 75w90 Lucas in the transmission and Brad Penn v2 10/40 or 20/50 depending on time of year in the engine in everyone as well. Never had a single issue with a front diff, transmission, or engine related to lubrication. I don't trust any oil manufacturer like amsoil that makes me go buy a product from vendor selling oil out of his garage. Just my 2 cents. I will stick with what has worked for the past 10 years. Still great info here though.
DBRs1 is offline
post #4 of 37 Old October 28th, 2019, 05:05 AM
whiteford's Avatar
First Name: Jason
My RZR: 2016 900s 4
Member #93649
View whiteford's Photo Gallery(0)
Why dot you just email Amsoil? They will give you the answers you are looking for.
whiteford is offline
post #5 of 37 Old October 28th, 2019, 05:29 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Buy some John Deere hygard, can be bought in quarts on amazon and run it in the front diff. I have been to the factory where they make these and watched them put it in.
Run any gear oil you want in the tranny, I prefer mobil one 75w whatever, Can't remember now.
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #6 of 37 Old October 28th, 2019, 08:09 AM
Bullitt427's Avatar
Member #133409
Synthetic ATF in the front diff of every Polaris I have owned.
75W90 in the Transmission.
Used to use 5W20 in the older Polaris ATV/RZR 800 with the separate Transfer Case.
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
post #7 of 37 Old October 28th, 2019, 06:32 PM
Pat H's Avatar
First Name: Pat
My RZR: 2018 1000 XP4 Ride Command Edition. 2018 RZR XP1k Ride Command 2 seat
Member #211553
View Pat H's Photo Gallery(0)
Good thing Polaris quit putting grease zerks on every pivot point there is on the suspension!!! We would be having a grease type/brand used debate too instead of everyone complaining about their suspension squeeking instead of just giving the maintenance points some grease, who cares what brand, just grease for no squeeks. Did I say maintenance??? If you question off brand lubes, go to your Polaris dealer and buy what they recommend and then youre safe, right? Or are the suggested fluids that manufacture x recommends, are they designed to make those components last just long enough to get the consumer through the warranty period (which I guarantee you that you paid for that 6 month warranty anyways) just so they can sell parts??? To each their own and its all personal opinion.
dartersracing likes this.
Pat H is online now
post #8 of 37 Old October 29th, 2019, 02:20 AM Thread Starter
dafish's Avatar
My RZR: '18 XPT
Member #223617
All: Thanks!
Hunderworks: Yes, in fact I've done research on the Demand Drive Fluid in the hopes I could better understand what AGL is by learning what it is not. (reverse engineering of sorts) I agree with you completely. More on DDF in a different thread.
Itching: Rear end oil is different from transmission oil? OK, please coach me here boss. My turbo seems to have one fill/oil point for both tranny and rear end. Maybe we have different machines? Or am I being an idiot? (again).
Bullitt: I suggest you look for my DDF thread that is forthcoming. Prolly tomorrow.
Whiteford: Yes, of course. Do you recall me asking if anybody had any good contacts? A good contact name beats a cold call most times.
Pat: Uh.. What? Nevermind. I do appreciate your intent to help the community.
All:
I'm going to have to correct myself some. DDF is, and is only, low viscosity tractor hydraulic fluid. Deere J-20D to be exact, although we don't know what's in the DDF bottles. What that means is I should eliminate UTHF it as a likely candidate from the VOA of AGL. That leaves 5W-20 motor oil. Or a new possibility I'd not considered: A poor 75W-85 gear oil that specs like a light motor oil.
This would explain Amsoil's take, the position of some very learned folks on BITOG, and the experience of some here as well. It also supports the reason some of us think about this: The present hypothesis shows a substantial oil improvement is possible over AGL.
Darters:
Given your statement of regularly rebuilding these transmissions (different thread), I'm a little confused by your apparent lack of interest in the pursuit of better oils. Perhaps I can get you to reconsider? Your contribution and experiences would doubtless be of value. For what it's worth, this thread is all your fault. You'll recall the upper bearings in the transmission you reported are chronically failing.... (I'd still appreciate the failing bearing numbers too!)
All:
So OK, I've no more answers yet. It does seem some form of "climbing" oil is needed, and it's seems it will be a low viscosity gear oil. Yet I've also read warning about using oil too thick as it creates chain stretch. Oh dear, is Po right? Is AGL some kind of extra low viscosity gear oil, something testing out like motor oil? Crud, what if the components that contribute to making an oil "climb" aren't tested for in a oil analysis. (read much swearing in background).
Am I proving AGL is the right oil here? Good lord, this wasn't expected. (God, am I going to have to admit all the "I only use factory oil" guys are right?)
OK, a conversation with Amsoil is coming. I wonder how a manual transmission oil might do here?
Anybody got anything else to contribute?
respect to all,
d
post #9 of 37 Old October 29th, 2019, 06:05 AM
Z15
Z15's Avatar
My RZR: 2018 S 900 EPS Black Pearl
Member #9114
View Z15's Photo Gallery(0)
Motor oils and gear lubes are NOT measured on the same viscosity scale! You cannot compare them viscosity wise.
AGL stands for Angle Gear Lube
RWB713 likes this.
Mike
2018 RZR S 900 EPS Black Pearl
2017 John Deere X738
2017 GMC Sierra 4WD CC Denali 6.2L
2016 RZR 900 EPS Trail
Z15 is offline
post #10 of 37 Old October 29th, 2019, 07:20 AM
turnkyle's Avatar
My RZR: 2013 570
Member #139233
View turnkyle's Photo Gallery(0)
This will be interesting to follow from an engineering/oil quality stand point but if you are looking at it from a cost saving stand point don't waste your time. I was just recently looking into alternative fluids from a cost saving stand point and found that the majority of the alternatives recommended by most people cost just as much as the Polaris brand oils if you buy them online and not from your local stealership. That's my two cents anyways.
RWB713 likes this.
turnkyle is offline
post #11 of 37 Old October 29th, 2019, 07:40 AM
Z15
Z15's Avatar
Member #9114
Never used OEM fluids, ever. Recommending the best oil has never been the goal of any oem manufacturer, rather it’s a business decision. OEM’s recommendations are marketed to persuade buyers and even induce fear, i.e. warranty void. It’s a business deal for the OEM, not a quality deal for the consumer.
Many have been able to purchase AMSOIL at Preferred Customers savings online, check it out AMSOIL UTV Product Lookup Guide
AMSOIL is the only oil I have used for over 25+ yrs, never would I use anything else. I value my equipment and I only use the best. Every thing in my signature has AMSOIL in every area that is lubed.
Mike
Z15 is offline
post #12 of 37 Old October 29th, 2019, 07:41 AM
MN1965's Avatar
My RZR: 2017 S 1000
Member #220258
View MN1965's Photo Gallery(0)
What the heck? A gallon of Polaris AGL costs $55 on Amazon. That's enough to change 3x (3years on my RZR). Front differential takes a whopping 8oz, so a quart of DD lasts 4 years. Not seeing a huge cost savings even if the replacement is half the cost per ounce.
MN1965 is offline
post #13 of 37 Old October 29th, 2019, 10:03 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
Not to dumb down this conversation . But if the oil looks good still when you drain it ...then there is no big issue.
I have been running ( based on Nate's recommendations at Alba racing) Maxima Syn Blend 10w -40 engine oil in the last 4 RZR's we owned. My experience with the factory Pol engine oil is it breaks down and turn black quickly especially in Turbo models.
The Maxima goes about 2 times longer and typically looks good still when I change it .
In the transmission.... I have always used factory Polaris brand and it always looks about as good as it does going in ...I have seen very little breakdown
In the front Diff...I have used Amsoil and Polaris I do not see a difference between them. With both brands after 10 hrs of hard riding in 4 wheel drive it is black and very broke down . Since it only takes about 1/3 of a Quart and it is super easy to change , I just change it every 10 hrs depending on driving style and conditions
Here is a quote from Alba, from what I have seen I tend to believe them......
Alba take: The oil that comes in your RZR is junk. Yes we said junk. If your pour it and watch you will see it is very watery. We typically do not recommend running oils other than what the manufacturer recommends but Polaris oil is the exception and many learned this the hard way. The problem we see first is in the valvetrain. The camshaft will wear through the shim bucket and cause massive failure. Polaris themselves has come out with heavier duty buckets to help aid with this problem but it is a bandaid. Polaris has also come out with a extreme oil we assume due to the problems with there regular oil. We made the switch to Maxima oil in 2012 and immediately saw the benefits. No more problems. We will now never again use Polaris engine oil. On that note we only use OEM Polaris oils in every other part of the RZR (diffs, and transmission). So why would Polaris use such a poor oil? Our guess is to help meet new stricter emissions standards. About Maxima oil: Why do we use Maxima Synblend. The Maxima Synblend offers great quality oils and unlike automotive oils it is not EPA friendly and for use only for offroad/racing use only. It offers a very high zinc content which is a anti wear additive and also offers great cleaning properties. This is important as everyday we see these engine consuming dirt even with the best filtration systems. Your best line of defense against this is to change your oil often with good oil. Since we change the oil often full synthetic oil is not recommended as its extended life is not an issue. We have used this oil for 5 consecutive years in the SCORE series (1750 miles of grueling desert racing a year). We have won all 5 years with zero failures. We trust this oil and only this oil in all of our race vehicles.
I cant believe I just replied to an OIL thread....yep that just happened !
Jbbooks and RWB713 like this.
Max H is offline
post #14 of 37 Old October 29th, 2019, 10:26 AM
Member #8600
Originally Posted by dafish View Post
All: Thanks!
All:
Darters:
All:
respect to all,
d
Where are you using AGL then? It is not a ring and pinion (diff) lube.
BTW, a friendly suggestion--list your machine in your profile, or at least in your posts.
post #15 of 37 Old October 29th, 2019, 10:41 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Let me clear this up, because I see it getting confusing:
900 and up models only have 1 case to fill in the rear, it requires "AGL". We don't actually have a rear "differential", just one gear case, (models without "turf mode")
800 (570 guys correct me if I'm wrong, because I'm assuming) and under models have separate cases for the rear diff and trans.
ItchinToRide likes this.
2018 XPT4 - Bailey
RWB713 is online now
Tags
agl , amsoil , demand drive fluid , oil , oil alternatives
