Tie downs. - Polaris RZR Forum - RZR Forums.net
 4Likes
post #1 of 25 Old October 4th, 2019, 03:46 PM Thread Starter
Flashman1's Avatar
Member #37609
View Flashman1's Photo Gallery(0)
Tie downs.
I am tired of have my sxs move around in my tow hauler. I ratchet strap all four corners - and it still walks around. I can't use wheel bonnets because of the tie down points in my trailer. What is wrong with using a strap through the mag wheel and then to the ratchet straps. I think my 570 moves around because the suspension has give in it even with the straps tightened down. Using the wheels will by pass the springs - if it is this simple why doesn't everyone do it?
Flashman1 is offline
post #2 of 25 Old October 4th, 2019, 04:12 PM
AZRIDER82146's Avatar
First Name: Don
My RZR: Ď18 1000 XP TRE
Member #187593
View AZRIDER82146's Photo Gallery(0)
Re: Tie downs.
There is nothing wrong woth running a strap through your wheels and then tying it down that way. The best way there is, other than bonnets.
I only tie down by the wheels, eithe straps through the wheel, tire bonnets, or whatever. trying to tie down the frame it will move around.
Just secure the wheels and let the rest of the machine do its thing, it wont go anywhere.
Why doesn’t everyone do it????? IDK, not my problem. We had a guy we frequently ride with almost unload his machine in the middle of a highway because he didn’t have it tied down properly.
PS. I put down e-track in my toy hauler so I can use the bonnets in it, also on my flatdeck trailer.
Internet diagnostics..........unless you know exactly what to describe, and how to describe it, no one knows what exactly what to tell you. And if you DO know exactly what to describe and how to describe it.........you likely donít need the internet answer!!!!!!! LOL
AZRIDER82146 is offline
post #3 of 25 Old October 4th, 2019, 04:20 PM
First Name: Don
Member #187593
Re: Tie downs.
As an addendum to my previous post; when I DO use straps through the wheels, I run the straps from the front wheels in such a way that they are pulling rearward; and run the straps on the rears so they are pulling forward, That way they are working against each other to keep things secure. Too bad I donít have a picture to show you.
Good luck
post #4 of 25 Old October 4th, 2019, 04:42 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
Re: Tie downs.
Mine has never moved. I put 2 straps in back and 2 in front and cinch down to just start compressing shocks
I also put in neutral and use a parking brake
185EZ is offline
post #5 of 25 Old October 4th, 2019, 04:45 PM
dafish's Avatar
Member #223617
View dafish's Photo Gallery(0)
Re: Tie downs.
E-track here too, with straps dedicated to the task. Great way to go. Next time I'll buy mesh nets. Meanwhile I still run a doubled up 3" strap across the back in case of panic braking, and the run another from both A-Arms to a front mount point. So 6 straps total, and everything rated at least twice the working rating I need.
So long the mag wheels don't have a rough edge all should be well. That said, depending on how it all works out, you may not have a lot of "down" on the tires. Personally I want to mildly compress the tire as I strap in. I not only want it to not move, but I want it to stay put in even the worst accident I can imagine. I think roll-over at that point, and now I'm just wanting to make sure it doesn't become a missile.
Less of a concern in an enclosed of course.
dafish is online now
post #6 of 25 Old October 4th, 2019, 10:42 PM
Ak Matt
thecazman's Avatar
First Name: Matt
My RZR: 18 RZR 1000 S
Member #272680
View thecazman's Photo Gallery(0)
Re: Tie downs.
I am going to try to tie down my tires, Iíve got many feet of e-track on my deck over trailer. Seems sturdy. Compress the tires a bit, and go.
Iím going to use e track rings and 2Ē ratchet straps. Should work great, hold the tires stationary and let the suspension do its thing.
Iíll let you know how it works.
2018 RZR 1000 S, mostly stock, home made aluminum roof, with rack for spare tire. Dual battery, stock Polaris and Napa AGM with a battery isolator. Warn Axon 3.5S winch. Almost 3k miles, working on installing lights, itís life before me was a street legal machine in Arizona, lotsa miles , never saw mud.
No tunes.
thecazman is offline
post #7 of 25 Old October 4th, 2019, 10:56 PM
dafish's Avatar
Member #223617
Re: Tie downs.
Yep, that's what I do. I was still worried about a emergency breaking action and what kind of force might be exerted on the e-track so as above I used a doubled up 3" through my rear bumper and back to the rear of the trailer.
Good luck!
D
post #8 of 25 Old October 5th, 2019, 12:25 AM
ntrsandman's Avatar
First Name: Ken
My RZR: 2012 900 XP
Member #200753
Re: Tie downs.
https://www.shockstrap.com/
ntrsandman is offline
post #9 of 25 Old October 5th, 2019, 08:32 AM
Greyhoundman's Avatar
My RZR: 16 900 Trail S-conversion
Member #145689
View Greyhoundman's Photo Gallery(0)
Re: Tie downs.
I ran straps through the wheels for a while but I found if I didn't have them positioned just right the wheels would shift a little and loose tension on the strap, using a parking brake did minimize that issue.
Greyhoundman is offline
post #10 of 25 Old October 6th, 2019, 03:23 PM
Grizzlander's Avatar
Member #271370
View Grizzlander's Photo Gallery(0)
X2 on Shock Straps.
Grizzlander is offline
post #11 of 25 Old October 6th, 2019, 03:40 PM
Big Rob's Avatar
First Name: Rob
My RZR: 2019 XP4 Turbo S
Member #266844
View Big Rob's Photo Gallery(0)
Re: Tie downs.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
This is what I have been using and it works well for me. Only needs 1 tie down point per wheel and the strap sinches down on the tire very well, never had any movement and the RZR suspension still does it's thing
Big Rob is offline
post #12 of 25 Old October 7th, 2019, 05:49 AM
rottendiesel's Avatar
Member #233994
View rottendiesel's Photo Gallery(0)
Re: Tie downs.
This is the same style that I use. No e-track required, just four simple tie down points at the corners. Machine never moves around and no mid-trip re-tightening required.
Sent from my Pixel 2 XL using Tapatalk
rottendiesel is offline
post #13 of 25 Old October 8th, 2019, 04:39 PM
Boisegolfer's Avatar
First Name: Charlie
My RZR: 2009 RZR 800
Member #70504
View Boisegolfer's Photo Gallery(0)
Re: Tie downs.
This is what I use....solid!
https://www.amazon.com/Kolpin-Lock-R...577876&sr=8-27
wfosxs likes this.
Boisegolfer is offline
post #14 of 25 Old October 8th, 2019, 04:45 PM
Dwilly's Avatar
Member #261668
View Dwilly's Photo Gallery(0)
X3 on shock straps. Mine hasn't moved an inch in my toyhauler since I got them. Expensive but cheaper than it getting loose.
Dwilly is offline
post #15 of 25 Old October 8th, 2019, 05:36 PM
flyingfisch's Avatar
Member #40358
View flyingfisch's Photo Gallery(0)
Re: Tie downs.
ATV Mighty TiTe tiedown system
atvqrt.com
flyingfisch is offline
