Hood latches on Turbo S - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old September 20th, 2019, 07:36 PM Thread Starter
fishdog7's Avatar
My RZR: 2019 Velocity Tubo S & 2016 Titanium 1000 XP that’s for sale
Member #50628
View fishdog7's Photo Gallery(0)
MIS Flag Hood latches on Turbo S
Just got a new 2019 Velocity Turbo S from Abernathyís a few days ago. The hood is a pain to get off. It seems like the one latch is 180 degrees off. You have to lift and pull on one side at the same time to get it to come off and reverse to put back on. Is anyone else having this problem or know how to fix it? The one that is off is the drivers side.
Thanks!
fishdog7 is offline
post #2 of 6 Old September 20th, 2019, 07:46 PM
Customsoud's Avatar
Member #271910
View Customsoud's Photo Gallery(0)
Re: Hood latches on Turbo S
Thanks!
Mines not that bad but the gap from side to side doesnít match and is a pain to get on and off
Customsoud is offline
post #3 of 6 Old September 20th, 2019, 08:59 PM
Toddg1's Avatar
My RZR: 2015 XP 1000
Member #225138
View Toddg1's Photo Gallery(0)
It's a common problem. Mine is the same way. You would think the fit would be a lot better.
2019 Turbo S Velocity
Street Legal
Toddg1 is offline
post #4 of 6 Old September 21st, 2019, 05:30 AM Thread Starter
fishdog7's Avatar
Member #50628
MIS Flag Re: Hood latches on Turbo S
Thanks for the responses, I thought it might just be mine. The keepers on the underside of the hood appear to to be different. If the keeper on the drivers side was the same as the other, l donít think there would be an issue.
fishdog7 is offline
post #5 of 6 Old September 21st, 2019, 07:04 AM
FatDog's Avatar
First Name: Jim
My RZR: The Beast / Turbo S 4
Member #81154
View FatDog's Photo Gallery(0)
As much as I hate to say.......It's normal
To improve it, Polaris should actually make a left and a right hood latch or design something that can be used on both sides that actually works.
There are some other aftermarket hood pin / latches out there that you can replace the stock ones with. There's a couple threads on here if you do a search.
FatDog is offline
post #6 of 6 Old September 21st, 2019, 08:21 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
I use these and they are the only way to go !!
https://www.fukaweeoffroad.com/produ...in-kit-for-rzr
Max H is online now
