Front wheel scrapers hit with 14" Method 409s on my 19 Turbo - Polaris RZR Forum - RZR Forums.net
post #1 of 4 Old September 19th, 2019, 04:54 AM Thread Starter
w00derson's Avatar
Member #271158
View w00derson's Photo Gallery(0)
Its the little fins on top of the scraper that hit the inside of the front wheel, closer to the mounting surface. It looks like the inside of the Method wheels taper in more than the stock 14" Turbo wheel.
Should I remove them? Grind the fins down where needed? I don't want to cause any issues. I took them off so I could run the dunes a couple weekends ago and had no issues.
14" method 409s, 5+2 front, 4+3 rear with 30-10-14 Terrabites.
w00derson is offline
post #2 of 4 Old September 19th, 2019, 11:10 AM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
Re: Front wheel scrapers hit with 14" Method 409s on my 19 Turbo
Grind it down, or swap to the older xp1k style which is tiny and made of plastic.
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
post #3 of 4 Old September 19th, 2019, 07:12 PM Thread Starter
w00derson's Avatar
Member #271158
I ground em down. Thanks for the input.
post #4 of 4 Old September 21st, 2019, 07:31 AM
Tonytoodogs's Avatar
First Name: Tony
My RZR: 2017 RZR S900 EPS, 2019 RZR XPT 4
Member #238490
View Tonytoodogs's Photo Gallery(0)
I put the 409's on with 32-10-14 Carnivours and they also hit on my 2019 XPT 4 seater. Ground all the fins down to flat. Mine is aluminum so it was easy. Just please use a aluminum grinding wheel not one for steel. I would hate to hear another horror story about using the proper wheel for alum.
Tonytoodogs is offline
