RZR shuts down when I disconnect the battery - Polaris RZR Forum - RZR Forums.net
 48Likes
post #1 of 44 Old September 17th, 2019, 04:46 PM Thread Starter
Dprzr's Avatar
First Name: Don
My RZR: 2012 RZR 570
Member #268930
View Dprzr's Photo Gallery(0)
I disconnect the battery while my RZR 570 is running and the machine shuts off, would this be a sign that my alternator is not working?? Thx
Dprzr is online now
post #2 of 44 Old September 17th, 2019, 04:53 PM
FRAZR's Avatar
My RZR: XPT4 Velocity
Member #82174
View FRAZR's Photo Gallery(0)
Re: RZR shuts down when I disconnect the battery
Don't do that.
RZR_Scott likes this.
FRAZR is offline
post #3 of 44 Old September 17th, 2019, 05:01 PM
RND's Avatar
First Name: Rich
My RZR: 570 EPS
Member #85203
View RND's Photo Gallery(0)
Why would you do that?
Sent from my SM-G973U using Tapatalk
2012 Polaris Sportsman 500 H.O.
2015 RZR 570 EPS trail LE Black Pearl
*Warn winch 3500 w/Synthetic rope
*Polaris front brush guard
*Polaris rear brush guard
*Richocet 9 piece complete underbody armor
*Polaris Lock-n-Ride Full Windshield
*Polaris Lock-n-Ride Rear Shield
RND is online now
post #4 of 44 Old September 17th, 2019, 05:02 PM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
NO. It is working as it is suppose too. Alternator need juice to make juice.
sandblster is offline
post #5 of 44 Old September 17th, 2019, 05:11 PM
sandblster's Avatar
Member #46247
To test charging, use volt meter on battery post. Start and watch volt meter. Rev up, you should get 14.0 to 14.5 volts.
Dprzr likes this.
post #6 of 44 Old September 17th, 2019, 05:20 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Sorry but that is incorrect. First they use a stator and not an alternator. Secondly, when the engine is spinning it turns the stator which in-turn produces a 3-phase AC signal. The Stater output goes to the voltage regulator where it is converted to DC and regulated to ~12.5-14.5V. So as long as the engine is running and the stator and voltage regulator are working properly no battery is needed. A battery's purpose is to start the engine and supply temporary over-current when the electrical system demands are beyond the stater ability to handle the load.
RWTDCT, Denver, Paxx and 6 others like this.
RZR_Joe is online now
post #7 of 44 Old September 17th, 2019, 05:20 PM
FRAZR's Avatar
Member #82174
I test mine by peeing on the battery terminals.
FRAZR is offline
post #8 of 44 Old September 17th, 2019, 07:29 PM
Megabite's Avatar
First Name: Orly
My RZR: 2019 RZR Turbo S
Member #90641
View Megabite's Photo Gallery(0)
Thatís how they learned me how to do it.
2017 XP1K
2015 900 XC (sold)
Megabite is offline
post #9 of 44 Old September 17th, 2019, 09:31 PM
graniteguy16's Avatar
Member #230193
View graniteguy16's Photo Gallery(0)
Joe sometimes u r offputting,but man u sure know what ur talkin about!! This guy is full of information about rzrs,thanks for all the input,and always helping out!
RWB713 likes this.
graniteguy16 is online now
post #10 of 44 Old September 18th, 2019, 04:20 AM
RZR_Joe's Avatar
Member #23438
Don't mean to be, sorry I just get straight to the point and sometimes my tact is not the greatest. The wife saying being an a$$hole comes naturally
RWB713, DogRunner2 and Marco75 like this.
post #11 of 44 Old September 18th, 2019, 05:31 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Anytime someone says off putting...I just have to...
Denver and RZR_Scott like this.
2018 XPT4 - Bailey
RWB713 is offline
post #12 of 44 Old September 18th, 2019, 06:05 AM
RZR_Joe's Avatar
Member #23438
post #13 of 44 Old September 18th, 2019, 08:19 AM
sandblster's Avatar
Member #46247
If no battery voltage, how does the regulator know what to output? Does it go all open non regulated voltage, or does it shut the output off? The safest would be to shut the output off. With un regulated voltage it can cause a lot of damage to all electronics unless all electronics is self regulated.
Experience with early motorcycles says a loose ground can cause an overcharge that burns out bulbs. They were simple/basic systems without a regulator as we have today. Regulator was battery voltage feedback. That is way a loose ground would cause an overcharge.
If a system has permanent magnets then it is possible to have output without input. If no permanent magnets, it has to have input to power the coils to produce.
RZR_Joe and RZR_Scott like this.
post #14 of 44 Old September 18th, 2019, 09:27 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Yes, this ^^^^^ don't do that on a computer controlled machine, you can fry stuff. Even on a non-computer controlled machine you can, just not as expensive of stuff (like your light bulb experience)
Like said before, only check charging with a voltmeter or peeing on the cables...
EDIT: I take that back, peeing on the cables only works for checking plug wires while it's running! Although peeing on things can be fun, battery voltage is too low for that test.
TennesseeRZR and FRAZR like this.
RZR_Scott is offline
post #15 of 44 Old September 18th, 2019, 09:29 AM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Is your battery dying or?? Why do this?
