2016 Xp4 1000 highlifter - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Brandongsxr21
post #1 of 7 Old September 17th, 2019, 02:08 AM Thread Starter
Brandongsxr21's Avatar
Member #272926
View Brandongsxr21's Photo Gallery(0)
Help with power steering issue. The machine is 3 years old but only has 160 miles on it. The code 520230 shows and I have NO. Power steering. I have checked everything I can find on these forums to check and nothing has worked. Help!!!! Lol.
Brandongsxr21 is offline
post #2 of 7 Old September 17th, 2019, 03:09 AM
Prowler59's Avatar
First Name: JD
My RZR: 2016 RZR 1000 XP4 Highlifter
Member #50860
View Prowler59's Photo Gallery(0)
Re: 2016 Xp4 1000 highlifter
Have you checked the fuse? Check the relays? I have the same model and mine kept blowing the fuse. I ended up having a bad voltage regulator and had to replace it.
2019 RZR 900 Trail
2015 RZR 170
2018 Ace 150
Prowler59 is offline
post #3 of 7 Old September 17th, 2019, 03:30 AM Thread Starter
Member #272926
I haven't yet. I will today. I bought a new battery and drove it around for a bit. EPS light still on. No power steering. I'll check all the fuses tonight. And get back to ya. Thanks.
Prowler59 likes this.
post #4 of 7 Old September 17th, 2019, 11:00 AM
Shawn_Thomas's Avatar
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
View Shawn_Thomas's Photo Gallery(0)
There’s only one fuse that would cause it and that’s the EPS fuse, mines a 20A fuse. I blew it last week and had this issue. Luckily there was a spare in my block to replace and go
Shawn_Thomas is offline
post #5 of 7 Old September 17th, 2019, 12:44 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
New battery? Just throwing parts at it? Google the code.
"IC CAN communication error with EPS"
Sounds like a wiring or EPS problem; might be fuse...
Denver is offline
post #6 of 7 Old September 18th, 2019, 02:04 AM Thread Starter
Member #272926
Alrighty. Best case scenario for now. It was the fuse. Prolly needed a new battery anyway tho. Lol. It was 3 years old. Thanks for the help. I'll keep some extra fuses on me in case it happens again. If it recurs. I'll check the regulator next. 👍🏻
post #7 of 7 Old September 18th, 2019, 03:24 AM
Prowler59's Avatar
First Name: JD
Member #50860
Good deal. My voltage regulator issue was easy to diagnose, at idle you could watch the Volts go from 12.2 to 17.1 back and forth. Hope you don't have to replace it too.
2019 RZR 900 Trail
2015 RZR 170
2018 Ace 150
