Rust already??? - Polaris RZR Forum - RZR Forums.net
 5Likes
post #1 of 21 Old September 16th, 2019, 02:13 PM Thread Starter
pearsth's Avatar
First Name: Tom
My RZR: 2019 XP4 Turbo S Velocity
Member #59126
View pearsth's Photo Gallery(0)
Rust already???
I have had my 2019 XP4 Turbo Velocity for about a month. It has been driven twice, less than 10 hours. Washed after riding and garage kept. Should I have worn paint and rust on the trailing arms already? Seems waaay too soon.
AZNorseman likes this.
pearsth is offline
post #2 of 21 Old September 16th, 2019, 02:18 PM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Re: Rust already???
Takes no time at on on the right abrasive material. Looks like road rash. Good news can be very easy touched up with a shake can of paint until next time. It is very similar to sand blasting what the tires can throw out. Once bare and a good washing the rust is automatic and very quick.
sandblster is offline
post #3 of 21 Old September 16th, 2019, 02:34 PM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Re: Rust already???
More rust on my 2019 after 2 rides than my 2013 with many more hours. Odd.
pearsth is offline
post #4 of 21 Old September 16th, 2019, 02:42 PM
Dstew619's Avatar
My RZR: 2017 Turbo XP4
Member #174273
Re: Rust already???
that's no surprise there, that's a wear area getting blasted by sand, rocks, and whatever other material you ride across. I wouldn't blame that on Polaris and would consider that normal maintenance. Now if it was an area not getting hit with rocks and dirt that was showing rust, I would be pissed. Maybe try coating those rear arms in some Bedliner type material, however no idea if that can hold up either.
Dstew619 is offline
post #5 of 21 Old September 16th, 2019, 02:42 PM
FRAZR's Avatar
My RZR: XPT4 Velocity
Member #82174
View FRAZR's Photo Gallery(0)
Re: Rust already???
1st thing I did to my Turbo S was add trailing arm rock guards. The paint on the trailing arms and radius rods gets punished.
FRAZR is offline
post #6 of 21 Old September 16th, 2019, 02:43 PM
sandblster's Avatar
Member #46247
Re: Rust already???
There are several kinds of rock quads one can purchase to avoid that problem. My 13 XP has more problems then either our 17 XP or 18 XPT. Where both years of your 4 place? The arm on the 4 place is sure different the the 2 seater. Powered coat would not stand up much longer.
post #7 of 21 Old September 16th, 2019, 02:58 PM
brbeck13's Avatar
Member #256290
View brbeck13's Photo Gallery(0)
Re: Rust already???
I also had the same issue and it was driving me crazy! I added the ModQuad trailing arm guards, the Mudbuster trailing arm protection guards, and I wrapped the radius rods in the 3M clear paint protection vinyl. All have done their job very well in the year and a half they have been on. No more rock chips and rust!
Larryg82 likes this.
brbeck13 is offline
post #8 of 21 Old September 16th, 2019, 03:27 PM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Re: Rust already???
Painted up and trailing arm guards going in now. Let’s see how it holds.
pearsth is offline
post #9 of 21 Old September 16th, 2019, 04:36 PM
PaulK's Avatar
First Name: Paul
My RZR: 17 XP Turbo
Member #34432
View PaulK's Photo Gallery(2)
Re: Rust already???
trailing arm guards from UTV Inc.
trailing arm guards from mudbusters
radius rod rollers from wolfsnout on the top and bottom rods
all in an attempt to keep the sand blasting to a minimum
PaulK is offline
post #10 of 21 Old September 16th, 2019, 06:06 PM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Re: Rust already???
It sure makes me glad I didn't buy a blue Turbo S. I would cry if that beautiful paint got a small scuff on it. Glad to have black - easy to match for a quick spray.
pearsth is offline
post #11 of 21 Old September 16th, 2019, 06:20 PM
Partsguy57's Avatar
Member #262504
View Partsguy57's Photo Gallery(0)
Re: Rust already???
Holy smokes it's a stupid utv for off road and will be worth nothing down the road. It's not like my hot rods/ classic cars that have staying power as far as worth, value and coolness factor. That is one thing I enjoy about my rzr who cares about chips the point is to drive and have fun with as it will one day be a used up piece of junk. Do I intentionally tear stuff up? Of course not. On the other hand what do you think you are protecting? A future classic?
Zbird likes this.
Partsguy57 is offline
post #12 of 21 Old September 17th, 2019, 02:44 AM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Re: Rust already???
I am simply concerned about longer term value and reliability. Nobody likes the look of a rusty POS if I decide to upgrade in a couple years. It is also valid to ask if perhaps my RZR has a QC problem. Again, my 2013, which I realize is a 900 and not a Turbo so perhaps less wheels sling and kick of sand, doesn’t have rust in those spots after 6 years, so I thought there was a problem.
pearsth is offline
post #13 of 21 Old September 17th, 2019, 06:53 AM
Partsguy57's Avatar
Member #262504
Re: Rust already???
Reliability??? For surface rust on a control arm? Long term value? How long? There is no long term value, they will eventually be used up and worth nothing. It's a off road vehicle with frame and suspension that has been stamped out and welded with what looks like the experience of a third day welder. There is nothing fancy or appealing to the eye under the plastic. Maintain and enjoy. ..
BigE64 likes this.
post #14 of 21 Old September 17th, 2019, 07:19 AM
dmax661's Avatar
Member #67537
View dmax661's Photo Gallery(0)
Re: Rust already???
Read this!! This was my solution to the same problem. Hope it helps.
https://www.rzrforums.net/rzr-xp-4-turbo/543852-trailing-arm-paint-fading-away.html#post5925610
Sent from my SM-G950U using Tapatalk
dmax661 is offline
post #15 of 21 Old September 17th, 2019, 11:26 AM Thread Starter
pearsth's Avatar
First Name: Tom
Member #59126
Re: Rust already???
https://www.rzrforums.net/showthread.php?p=5925610
Where did you get the flaps?
pearsth is offline
