Powdercoating OEM shocks - Polaris RZR Forum - RZR Forums.net
post #1 of 5 Old September 15th, 2019, 11:01 AM Thread Starter
scott434's Avatar
First Name: Scott
My RZR: 2014 Rzr S 800 Indy Red
Member #19980
View scott434's Photo Gallery(5)
Anyone ever take apart, if even possible, and powdercoat shock springs off of an 09-14 RZR 800S stock Sash shocks? I don't like the black color. I'd like to paint the spring red. How much trouble is it and can it be done? Or, do they make RED springs to replace the stock black ones?
scott434 is offline
post #2 of 5 Old September 15th, 2019, 12:39 PM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Re: Powdercoating OEM shocks
It is possible, would not be cheap to bead blast the old spring then powered coat them. Have you looked around for red replacements springs. Use to be available. Probably not any more. The other thing would be to remove, scotch bright them and shack can them. Other options would be a set of red shock covers.
sandblster is offline
post #3 of 5 Old September 15th, 2019, 01:34 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Considering the worthlessness of stock sacked-out Polaris springs on the Sachs non-rebuildable shock, either put a set of springs from RtPro or Bandit UTV Suspension on, or a complete shock replacement from Bandit. If color is the goal and you can't buy red, just clean and rattle-can them. Easy enough to take the springs off, only need a 1" ratchet strap, and that's only if installing new springs.
Denver is online now
post #4 of 5 Old September 15th, 2019, 05:23 PM Thread Starter
scott434's Avatar
First Name: Scott
Member #19980
So the stock springs are not hard to get off? I might go that route and just paint them myself. Thanks guys!
scott434 is offline
post #5 of 5 Old September 15th, 2019, 07:14 PM
Denver's Avatar
First Name: Denver
Member #41951
Just realize that you will gain probably 2 inch of ground clearance if you change the springs; or change the spring and shocks you'll get better ride too. @atvpro [email protected]
