DIY Fabricated Windshield for aftermarket cage - Polaris RZR Forum - RZR Forums.net
 1Likes
  • 1 Post By Shawn_Thomas
post #1 of 14 Old September 8th, 2019, 07:03 AM Thread Starter
Shawn_Thomas's Avatar
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
View Shawn_Thomas's Photo Gallery(0)
I was wondering if anyone has done this and if they had any pointers, pictures or do’s and don’ts. I’ve got a 911fab cage with hood protection and the wife wants a windshield, so I know I’ll have to custom fit one, but I guess I’m wondering what did you use to start with?
Shawn_Thomas is offline
post #2 of 14 Old September 8th, 2019, 07:10 AM
88_pathy's Avatar
Member #122401
View 88_pathy's Photo Gallery(0)
Re: DIY Fabricated Windshield for aftermarket cage
Pro armor windshield for the correct car so it fits the dash. Then, cut it all down to fit.
88_pathy is offline
post #3 of 14 Old September 8th, 2019, 07:13 AM
metro's Avatar
First Name: Seth
My RZR: 1000XP & 900S
Member #79618
View metro's Photo Gallery(0)
EMP makes a kit. I have it on my TMW cage on my XP1K. No complaints.
metro is offline
post #4 of 14 Old September 8th, 2019, 07:43 AM Thread Starter
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
I don’t see how the pro armor would be able to be trimmed to fit? I looked it up and it’s like glass inside of a frame
That actually looks like it would be best with the mounting straps. Did you have any issues trimming it? What did you use to trim
post #5 of 14 Old September 8th, 2019, 08:02 AM Thread Starter
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
This is what I have (had to delete old pictures cause I reached my limit)
post #6 of 14 Old September 9th, 2019, 05:14 AM
SSGPohlman's Avatar
My RZR: 18' RS1
Member #172713
View SSGPohlman's Photo Gallery(0)
Give me a day or two and I should get my cage back from the shop thats installing the glass.
Simply took my cage to work and welded in a “pinch weld” made from flat stock. Going with 1/4” glass like most new cars and glued in.
Then I just have to work out the bottom flap near the dash for an air vent.
Noble Eagle 03-05
Iraqi Freedom 05-07
Enduring Freedom 12-13
Med Retired after 17yrs
SSGPohlman is offline
post #7 of 14 Old September 9th, 2019, 05:33 AM Thread Starter
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
Definitely send pictures, I am interested to see it. I think I would like it to be removable if I choose to do with out for a ride. I guess my two biggest concerns is how to mount it, or reuse stock mounts from a box item and how to cut it without fracturing it. I was told cut with a jig saw but wanted to make sure it won’t mangle it and make it a waste
post #8 of 14 Old September 10th, 2019, 02:58 AM
tbg120's Avatar
My RZR: 2015 XP1K
Member #28610
View tbg120's Photo Gallery(0)
When I did my knock down kit on my old 800S I made mine from scratch and impact resistant polycarbonate from Mcmaster Carr. The sheet I purchased was big enough where I made two, a full and a half for hot days. I used my old half as a template for the bottom so it fit the dash nice and snug.
https://www.mcmaster.com/polycarbonate
tbg120 is offline
post #9 of 14 Old September 10th, 2019, 04:01 AM
miboatcapt's Avatar
First Name: Chad
My RZR: 2017 xp1k
Member #215833
View miboatcapt's Photo Gallery(0)
I am looking for a glass windshield for my Houser Cage. May have to make one. For a half I took my broken factory one to a glass shop and they can put the little deflector bend at the top and cut it using the pattern.
miboatcapt is offline
post #10 of 14 Old September 10th, 2019, 06:44 AM
Mr.Jones's Avatar
First Name: Billy
My RZR: 2014 1000xp
Member #162177
View Mr.Jones's Photo Gallery(0)
Metro what EMP kit do you have for yours and do you have any pics of it installed?
Mr.Jones is offline
post #11 of 14 Old September 10th, 2019, 11:14 PM
SSGPohlman's Avatar
My RZR: 18' RS1
Member #172713
So the cage is back and installed on the machine. I too have a houser cage and like OP cage it has a bottom horizontal bar. Local glass shop guy has been in it for over 2 decades. Said its too easy to do. Only thing I added was to take black silicone from lowes “for windows and doors” lol and go around the edges of the glass to close the gap between the glass and cage.
Air flows well under the bottom horizontal bar, which Im yet to make a flap for given winter is going to be here fast. See if I can get a link in here.
https://www.flickr.com/photos/160866.../shares/nR2919
-Sarge-
Noble Eagle 03-05
Iraqi Freedom 05-07
post #12 of 14 Old September 11th, 2019, 01:31 AM Thread Starter
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
Looks good. So I think I’m going to get the scratch and impact resistant glass from McMasters. A 24”x48” 0.25 thick sheet is 158$ plus 19$ shipping, 13$ for UTV windshield mounting straps from amazon should put me around 200$ for the window. The black rubber stripping is a great idea. I was going to just get a strip of foam with sticky side to have press against the cage especially because I have a center intrusion bar. Not sure what would be best or maybe a combo of both? Idk
post #13 of 14 Old September 11th, 2019, 03:01 AM
tbg120's Avatar
My RZR: 2015 XP1K
Member #28610
Shawn, before you order double check your measurements. Not sure how your going to make a full windshield from that size?
tbg120 is offline
post #14 of 14 Old September 11th, 2019, 03:09 AM Thread Starter
First Name: Shawn
My RZR: 2016 1KXP
Member #270060
40 inches wide, 18 inches from hood bars to light bar mount. So I am either gonna leave the space behind the lightbar open, or I can notch it out to touch the roof but I don’t think I’ll be notching for the hood protection. But you’re right. I should definitely remeasure to be safe
tbg120 likes this.
