Excess heat coming through the front - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 23 Old September 3rd, 2019, 04:18 PM Thread Starter
fuzzy01ram's Avatar
First Name: Gary
My RZR: 2013 800s
Member #49936
View fuzzy01ram's Photo Gallery(0)
2017 RZR 4 900 I have excess heat coming through the the firewall and where the cup holders are, if you put a bottle of water in one of the front cup holders at the end of the ride you can make a hot cup of tea, if you’re ankle hits the bottom part of the console you will almost burn yourself, anyone else have this problem?
fuzzy01ram is offline
post #2 of 23 Old September 3rd, 2019, 04:28 PM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Re: Excess heat coming through the front
Make sure your fan is working correctly. What is the engine temp running?
sandblster is online now
post #3 of 23 Old September 3rd, 2019, 04:46 PM Thread Starter
fuzzy01ram's Avatar
First Name: Gary
My RZR: 2013 800s
Member #49936
The fan works fine the temp runs between 194 and comes on around 218-224
post #4 of 23 Old September 3rd, 2019, 04:47 PM
sandblster's Avatar
Member #46247
Looks normal. Ride faster and keep the windshield open.
post #5 of 23 Old September 3rd, 2019, 04:49 PM
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
A Polaris RZR with too much heat in the center console?
Well, that's a first. . . . . . . . . NOT!
Try a RZR 1000. It will cook your ankles and turn your cold soda to a hot drink. Great if you drive in the winter and like hot chocolate.
Search Wolfsnout LINKY for insulation kits. It helps.
Rockymtn5280 is offline
post #6 of 23 Old September 3rd, 2019, 06:00 PM
Impact344's Avatar
Member #268904
I will give the 1000xp this it dont get near as hot as the 900 behind the seats
Highrider likes this.
Impact344 is offline
post #7 of 23 Old September 3rd, 2019, 06:55 PM
PTNOUT's Avatar
Member #269794
View PTNOUT's Photo Gallery(0)
Just placed some insulation around the cup holders and put a small sheet of it over the coolant lines under the cup holder. I think it should help.
PTNOUT is offline
post #8 of 23 Old September 3rd, 2019, 07:20 PM
bimmerdog's Avatar
First Name: Pat
My RZR: 2017 XP Turbo
Member #72309
View bimmerdog's Photo Gallery(0)
On my 2017 XPT I went with the Wolfsnout UTV-Cooler-Cab-Kit. Before I did this a frozen water bottle in the cup holder riding in 75 degree weather the ice would be melted in under 1 hour. After the kit was installed the frozen bottle of water same outside air temp there was still ice in the bottle 2 hours later. The heat in the cab was cut way down.
2017 XP Turbo
January Ride of the Month
Sold. What is next?
bimmerdog is offline
post #9 of 23 Old September 3rd, 2019, 07:55 PM
AZRIDER82146's Avatar
First Name: Don
My RZR: Ď18 1000 XP TRE
Member #187593
View AZRIDER82146's Photo Gallery(0)
Simple fix..........remove console, turn it over, use some spray foam around cup holders, let it dry/cure, re-install console. $5 bucks spent. Works great.
More expensive fix..........your fan should be coming on at 204-206, not 218-224.
TennesseeRZR likes this.
AZRIDER82146 is offline
post #10 of 23 Old September 4th, 2019, 04:42 AM
Member #223457
My buddy with a 900 just put a flap type seal on the panel behind his seats. That seam the 900 has was unbearable in his. Made a world of difference
post #11 of 23 Old September 4th, 2019, 06:13 AM
Impact344's Avatar
Member #268904
Remember everybody that the spray foam is flammable even after it has cured
post #12 of 23 Old September 4th, 2019, 06:24 AM
ParaQuader's Avatar
My RZR: '16 900 Trail EPS StealthBlack
Member #47120
View ParaQuader's Photo Gallery(0)
2017 RZR 4 900 I have excess heat coming through the the firewall and where the cup holders are, if you put a bottle of water in one of the front cup holders at the end of the ride you can make a hot cup of tea, if youíre ankle hits the bottom part of the console you will almost burn yourself, anyone else have this problem?
It's like that in all of them, here's a solution:
https://wolfsnout.net/shop/utv-acces...ooler-cab-kit/
Polaris lock & ride windshield, Polaris canvas roof, SuperATV rear window, Seizmik Pursuit side mirrors,
Viper Elite 3500 winch, Denali 66" Pro Series plow, UTV Giant lower doors, ATV-Guru front brush guard,
14x7 STI HD Beadlocks 4+3 / Tusk Terrabite 28x10Rx14, MudBusters fender flares, RT Pro springs,
Modified Grafix, LED Headlight bulbs, Sirius LED cube floods on A-pillar
ParaQuader is offline
post #13 of 23 Old September 4th, 2019, 06:36 AM
Bullitt427's Avatar
Member #133409
I also concur with the Wolfsnout Kit.... really tamed my XPT cabin heat
2018 RZR XPT Walker Evans
2017 RZR S1K Black Stealth
2013 RZR 800 LE
Bullitt427 is offline
post #14 of 23 Old September 4th, 2019, 06:46 AM
E.T.X.Rzr's Avatar
First Name: Justin
My RZR: 2019 HLE4
Member #81149
I have wrapped the coolant lines with header wrap and used fire block spray foam on multiple rzrís with very good results and is by far the cheapest way to do it. If you have a open flame in your console itís going to burn with or without spray foam.
https://www.homedepot.com/p/GREAT-ST...3992/207077797
AZRIDER82146 likes this.
2019 HLE4
E.T.X.Rzr is online now
post #15 of 23 Old September 4th, 2019, 06:50 AM
Impact344's Avatar
Member #268904
Well some ppl wouldnt think to use the fireblock spray they would use the normal gap filler stuff and the header wrap is a good idea also. I am just saying that the stuff can catch fire it's not fireproof
