Could it be the fuel pump? - Polaris RZR Forum - RZR Forums.net
 7Likes
  • 1 Post By Denver
  • 2 Post By fishdog7
  • 4 Post By fishdog7
post #1 of 8 Old August 20th, 2019, 06:57 AM Thread Starter
fishdog7's Avatar
My RZR: 2016 Titanium 1000 XP
Member #50628
View fishdog7's Photo Gallery(0)
MIS Flag Could it be the fuel pump?
Need some help please. We are riding in Taylor Park, Co. and having trouble with our 2016 1000 XP. It runs fine for five or six hours then for no reason sputters and dies. We have ridden it here many times, no problems so l don’t think it has anything to do with the altitude. When it dies you can remove the fuel cap and pressure has built up in the tank. Wait a while it will start and run a short distance (low power) then die again. This might go on five or six times and when your ready to give up it will start and run like nothing was ever wrong.
Could it be the fuel pump is getting hot? Any help would be appreciated!
Forgot to add; I noticed speedometer is registering about twice the speed as actually going. I’m pretty sure this is a separate problem, but any help with the cause would be appreciated also.
fishdog7 is offline
post #2 of 8 Old August 20th, 2019, 09:00 AM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Re: Could it be the fuel pump?
Pressure building up when taking the cap off means the vent hose is plugged. That could cause a fuel starvation problem as the fuel is sucked out and creates a vacuum in the tank the pump can not pull against. First is to follow the fuel tank vent hose and make sure it is clean with not restrictions. Suspect you will have no more problems once the vent is cleared. It is possible the fuel pump could receive damage from fuel starvation. As it would run full bore with no fuel going through to cool the pump. This would explain why it runs great for hours before having a problem. Suspect it is not pressure you hear when removing the cap but air rushing into the tank.
sandblster is offline
post #3 of 8 Old August 20th, 2019, 01:51 PM
csacsa's Avatar
Member #71077
View csacsa's Photo Gallery(0)
Had same thing in Utah last year. Vent line was fine. When I got home to Michigan I replaced fuel tank because the one way valve is integrated in the tank and also replaced fuel pump. All better now. Which one was it, IDK. Any riding over 8000ft and I had the same problem as you.
csacsa is offline
post #4 of 8 Old August 20th, 2019, 02:56 PM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Originally Posted by fishdog7 View Post
Forgot to add; I noticed speedometer is registering about twice the speed as actually going. Iím pretty sure this is a separate problem, but any help with the cause would be appreciated also.
Did you accidentally set it to kilometers?
ItchinToRide likes this.
Denver is offline
post #5 of 8 Old August 20th, 2019, 04:24 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
Need some help please. We are riding in Taylor Park, Co. and having trouble with our 2016 1000 XP. It runs fine for five or six hours then for no reason sputters and dies. We have ridden it here many times, no problems so l donít think it has anything to do with the altitude. When it dies you can remove the fuel cap and pressure has built up in the tank. Wait a while it will start and run a short distance (low power) then die again. This might go on five or six times and when your ready to give up it will start and run like nothing was ever wrong.
You are going to have to do some diagnosing. I think I would start with fuel pressure. Either way you must figure out if it's spark or fuel first. Check for spark when it won't run. Spray some carb cleaner in the intake tube with the air filter removed when it's dead to see if it's fuel. Check engine light ever come on?
If it does have pressure in the tank I doubt that has anything to do with it. Vacuum in the tank heck yes. But it should start immediately if it was vacuum and you relieved it, shouldn't have to wait.
RZR_Scott is offline
post #6 of 8 Old August 20th, 2019, 04:38 PM
sandblster's Avatar
Member #46247
Pressure in the fuel tank is a sign of something wrong. Should be no pressure in the gas tank. Think pressure, think bomb.
post #7 of 8 Old August 21st, 2019, 07:42 AM Thread Starter
fishdog7's Avatar
Member #50628
MIS Flag Re: Could it be the fuel pump?
Thanks for all of your replies! Like l said l am riding at Taylor Park, Co. I ran in to Bill from American Rock Rods out here and he thought it could be a bad fuel pump, but said it would be best to get it diagnosed to be sure, which l agree. I then met some really GREAT folks from Grand Prix Motorsports out of Littleton, Co. Daryl and Rob. They contacted the dealership and are sending a fuel pump out with a friend thatís joining them today. Iím not sure it will fix my problem, but itís worth a shot. Also Bill from American Rock Rods volunteered to help put it on. Met some ďGREATĒ people out here and canít thank them enough!
Denver, you where right, in all the confusion l accidentally had switched to KM.
When l get a chance to try the new fuel pump out Iíll report back.
Thanks again!
Denver and RZR_Scott like this.
fishdog7 is offline
post #8 of 8 Old August 23rd, 2019, 07:41 AM Thread Starter
fishdog7's Avatar
Member #50628
The new fuel pump solved the problem and saved the rest of our vacation. Replacing the fuel pump was no big deal the worst part was getting the ring loose that secures the pump to the tank. A pair of large channel lock pliers worked great.
Bill from American Rock Rods and the folks from Grand Prix Motorsports in Littleton, Co. where GREAT and l canít THANK them enough!
To address one of the earlier posts, l was experiencing a build up of pressure in the fuel tank when l was having issues. We had taken the vent line off and there were no restrictions. I donít know, but there must be some sort of check valve in the pump itself.
Thanks for everyoneís input! This site continues to be a great source of info and folks willing to help another out!
fishdog7 is offline
