Just my luck - Polaris RZR Forum - RZR Forums.net
post #1 of 8 Old August 11th, 2019, 02:34 PM Thread Starter
liftedpsd2010's Avatar
First Name: Michael
My RZR: 2018 rzr 4 highlifter 1000
Member #85073
View liftedpsd2010's Photo Gallery(0)
Just my luck
We have a 2018 rzr highlifter 4. Running fine riding it on the woods and the oil light came on. Something hit the dipstick tube and broke it off. Got it pulled back to house and ordered a new dipstick tube. Put about 1.5 qts of oil in and started it up and the top end at idle sounds normal. Give it a little gas and itís rattling. I have extended warranty but local dealer is of no help. Iíd rather just fix it myself. What should I check? Thanks.
liftedpsd2010 is offline
post #2 of 8 Old August 11th, 2019, 03:03 PM
Impact344's Avatar
Member #268904
I just got a 5 year warrenty with my xp1 and it sounds like I wasted my money from what I am hearing but any way did you get all of the dipstick out ? And how long did it run after it happened?
Impact344 is offline
post #3 of 8 Old August 11th, 2019, 03:04 PM
dartersracing's Avatar
First Name: DONNY
My RZR: 2014 PACE Z1 1000
Member #19554
Feedback Score: 15 reviews
Re: Just my luck
rod bearings.
209-373-5336 DONNY DARTER
dartersracing is offline
post #4 of 8 Old August 11th, 2019, 03:07 PM Thread Starter
First Name: Michael
Member #85073
Re: Just my luck
I took the piece that the dipstick goes into off and got it out. The whole tube was gone. No idea how the heck something hit it.
Would it be worth it to just replace the rod bearings? Would that sound like the top end? Iíve taken apart Polaris transmissions before but never a motor. Thanks
post #5 of 8 Old August 11th, 2019, 03:10 PM
First Name: DONNY
Member #19554
Re: Just my luck
if its rattling I would tear down engine, if bearing has spun I would recd to replace crankshaft and rod as they are not serviceable. you will see the problem once torn down, if you have any questions give a call, I build at least one motor a week.
post #6 of 8 Old August 11th, 2019, 03:21 PM Thread Starter
First Name: Michael
Member #85073
Re: Just my luck
Thanks! I appreciate that. So this seems like itís gonna cost about 1000-1500 is that accurate?
post #7 of 8 Old August 11th, 2019, 06:32 PM
First Name: DONNY
Member #19554
Re: Just my luck
Just kinda need what parts are needed, if crank is bad you will be at that easy if you do your own work.
post #8 of 8 Old August 11th, 2019, 06:34 PM Thread Starter
First Name: Michael
Member #85073
Re: Just my luck
Ok thanks. One more question is there a good place to buy these parts? I seen quite a few places just wondering if one is any better than others. And any parts to upgrade while Iím in the motor?
