Enclosed trailor for rzr1000 - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 37 Old August 9th, 2019, 02:39 PM Thread Starter
Breadkrum's Avatar
Member #258824
View Breadkrum's Photo Gallery(0)
Ok guys looking to see if anyone on this forum is towing a 4 seat rzr with a 7x14 enclosed trailor? If so how tight is the fit. With or without a v nose. Looking to buy one asap
Breadkrum is offline
post #2 of 37 Old August 9th, 2019, 02:47 PM
sandblster's Avatar
My RZR: 2018 Dynamix
Member #46247
Re: Enclosed trailor for rzr1000
You know you have to climb over stuff to get in and out with that wide of a trailer. Get the wider one and can open the door and walk in and out.
FRAZR and DogRunner2 like this.
sandblster is offline
post #3 of 37 Old August 9th, 2019, 05:29 PM
Greyhoundman's Avatar
My RZR: 16 900 Trail S-conversion
Member #145689
View Greyhoundman's Photo Gallery(0)
I have an 8.5 wide and have plenty of space to get out and get around both sides to strap it down.
Only downside to a wider trailer is visibility if you don't already have wider tow mirrors.
ID:	581984Click image for larger version
Greyhoundman is offline
post #4 of 37 Old August 9th, 2019, 05:59 PM
sdorn's Avatar
Member #258394
View sdorn's Photo Gallery(0)
I have 8.5’ wide as well. Wouldn’t want anything narrower.
sdorn is offline
post #5 of 37 Old August 9th, 2019, 06:01 PM
topgun's Avatar
My RZR: 2019 Turbo RZR
Member #17581
From experience, get the trailer larger than what you think you need or most likely you will be buying another. Length is the first thing. Is 14' long enough? The 4 seat is over 12' with no bumpers. Figure the equipped machine + additional space for ease of tie down and some room for storage. 14' sounds pretty tight if you have bumpers. If you were to upgrade to a 4 seat Pro at some point, it will be an even longer machine. Same with a Can Am. And both are not stepped in on the sides as much as the XP1000 so getting in and out in a 7' trailer will be a lot harder. A few more $$ now for something a little bit larger is a heck of a lot cheaper than having to upgrade in a few years and spend thousands.
I had a 18' X 7' snowmobile trailer (so 23' with the V) and hauled a XP1000 and full sized utility quad. No issues with the width. It was tight but there is still about 8" on a side between the wall and tire. That said, I replaced it with a 102" wide car hauler so we could haul 2 RZRs. It is a lot nicer for moving around in the trailer but not truly necessary. Just depends on your situation, what you are comfortable towing.
Good luck!
2019 RZR Turbo Titanium
2008 Can Am Renegade 800
2018 RZR RS1 Black Pearl
2011 Can Am Outlander 650 XTP
topgun is offline
post #6 of 37 Old August 9th, 2019, 06:20 PM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
7X14 is just enough, barely
No room for anything else
If i did it again I would go V nose and rv extended tongue but I only tow with my rv
8.5 wide is great but depends on what you're towing with
Make sure you get the extra height door opening
ID:	581952   Click image for larger version
185EZ is offline
post #7 of 37 Old August 9th, 2019, 06:45 PM
03tjsport's Avatar
My RZR: Xpt
Member #118289
View 03tjsport's Photo Gallery(0)
Seven feet is not enough. The door width is less. I am 66”-67” wide and barely fit between the cables for the door. The next one I get will be 8’ wide. I have a 7x19 v nose and a 17 xpt. It takes up a fair amount of space in there. We convert it to sleep in after the machine is out of it, so all of the camping stuff rides in there too.
03tjsport is offline
post #8 of 37 Old August 9th, 2019, 10:24 PM Thread Starter
Breadkrum's Avatar
Member #258824
Ok so I have decided to go with a 8.5x14 now I just need to find a used one around my location
bruce7105 likes this.
post #9 of 37 Old August 10th, 2019, 05:07 AM
DogRunner2's Avatar
Member #137545
8' would do. Forget about the 14'. 16'length.
2018 XP1K LE
DogRunner2 is offline
post #10 of 37 Old August 10th, 2019, 05:24 AM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
Attachment 581984Attachment 581986
They also make tow mirrors that snap right on to your existing mirrors for most trucks. I bought a set for a ram 1500 for fairly cheap and they work great.
superjunior is offline
post #11 of 37 Old August 10th, 2019, 08:47 AM
Pat H's Avatar
First Name: Pat
My RZR: 2018 1000 XP4 Ride Command Edition. 2018 RZR XP1k Ride Command 2 seat
Member #211553
View Pat H's Photo Gallery(0)
8.5 and glad I did
Pat H is offline
post #12 of 37 Old August 10th, 2019, 09:14 AM
bbyers's Avatar
First Name: Brian
My RZR: 2017 XPT4
Member #175225
View bbyers's Photo Gallery(0)
i bought a 7X16 for my 4 seat turbo and have plenty of room to get out and walk out of trailer. I kinda hug the passenger side of trailer when im pulling in. If your 500lbs i can see you having a issue.
its loaded up now and i can take a few pictures for you if that would help you decide.
-2017 XPT4-Polaris roof, sliders, trailing arm guards, half windshield, front winch bumper & rear mesh screen, Warn 4500 winch, Ride Command w/rear camara, Razorback 3.0, Evo charge tube, intake tube & Bov, Dyno jet JUNK power vison((ITS HAD BLUE SCREEN OF DEATH FOR OVER A YEAR. ZERO HELP FROM DYNOJET!))w/AA stage 3 tune, Empire exhaust w/quite cores, NRP gated shifter, NRP radius rods, 32" curved led light bar, lower door inserts, PRP door bags, R2C filter. AIRDAM CLUTCHES Best purchase so far!
bbyers is offline
post #13 of 37 Old August 10th, 2019, 10:11 AM
sandblster's Avatar
Member #46247
You must be one thin dude. Cannot count the times have watched people loading and unloading from a 7'. Sure something I do not want to struggle with when the 8.5 makes life so much easier.
post #14 of 37 Old August 10th, 2019, 11:59 AM Thread Starter
Breadkrum's Avatar
Member #258824
Yah send pics of your 7x16 please
post #15 of 37 Old August 10th, 2019, 01:07 PM
bbyers's Avatar
First Name: Brian
My RZR: 2017 XPT4
Member #175225
ill take some tonight when i get home
bbyers is offline
