2011 rzr 800 no power with turn key - Polaris RZR Forum - RZR Forums.net
 3Likes
  • 2 Post By CA 800
  • 1 Post By Lastminute rex
post #1 of 12 Old July 22nd, 2019, 09:41 AM Thread Starter
DWJM2513's Avatar
Member #152841
View DWJM2513's Photo Gallery(0)
I was going to fix the water pump seal on my 800 today and I go to start it and Ive got nothing to the key turn. I started with the easiest which is the battery and if it was dead. Checked it, 12.2 volts. So I went to the fuse box, checked them all and none that I checked were blown. So next was the ignition switch, checked all 4 wires with a test light and there's no power to any of the 4 wires. So where do I go from here? Do I have to dig through the main harness for a broken wire or is there a fuse box I'm not finding? Is what I have pictured the possible culprit of not have any ignition power?
DWJM2513 is offline
post #2 of 12 Old July 22nd, 2019, 10:43 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Re: 2011 rzr 800 no power with turn key
That looks like a fusible link, another name for a high-amp fuse. Either disconnect one side and check it with an ohm meter or check from each side to ground for 12 volts.
But first, on frame behind driver's seat, find brake pressure switch. Pull off connector, jump it.
Denver is offline
post #3 of 12 Old July 22nd, 2019, 02:04 PM Thread Starter
DWJM2513's Avatar
Member #152841
I don't have power at all to the "dash" the cluster isn't lighting up at all with the key. I don't the the brake pressure switch is the problem. I wanna say it's the ignition switch but I don't even have power to the ignition switch.
DWJM2513 is offline
post #4 of 12 Old July 22nd, 2019, 02:05 PM Thread Starter
DWJM2513's Avatar
Member #152841
Is that "fusable link" factory for the 800's or did someone put it on afterwards?
DWJM2513 is offline
post #5 of 12 Old July 22nd, 2019, 02:18 PM
442raceRZR's Avatar
My RZR: 2009 RZR 800 S
Member #264074
Step 1. Clean that swamp donkey so you can proper diag.
Step 2. Key switch should 4 (possibly 5 depending on year), check the continuity of the C and D wire, those are the "on" wires.
88 Red goes to "red splice" and the fuse box.
91 goes to "red white splice" and that loops through a 20amp breaker.
AMA D38 - Sportsman UTV
Windansea Coffee / Mass Depot / MassFX / Frank Motors / Blud Lubricants / GL Performance Coatings / M&M Offroad / Big Gun Exhaust / TireJect / RynoPower / SuperATV.com / AG Sandcars / Filterwears / Austin Hose
2009 Polaris RZR 800S
442raceRZR is offline
post #6 of 12 Old July 22nd, 2019, 05:29 PM Thread Starter
DWJM2513's Avatar
Member #152841
I have nothing on all 4 wires going into the switch
DWJM2513 is offline
post #7 of 12 Old July 22nd, 2019, 05:53 PM
442raceRZR's Avatar
Member #264074
You have juice from the battery to the fuse box?
post #8 of 12 Old July 22nd, 2019, 06:44 PM
Lastminute rex's Avatar
Member #265982
View Lastminute rex's Photo Gallery(0)
Check solenoid. 4/5 small wires going to single eyelet. My eyelet broke and I lost all power
Lastminute rex is offline
post #9 of 12 Old July 22nd, 2019, 07:13 PM
442raceRZR's Avatar
Member #264074
Its not a no crank... Its no power at all.
post #10 of 12 Old July 23rd, 2019, 09:09 AM
CA 800's Avatar
First Name: Geoff
My RZR: 2014 800 LE
Member #79560
Those look like two thermal reset 50 amp circuit breakers, that have been added to RZR.
What are the red cables connected to?
One to battery, and other to starter solenoid?
Can you post picture of their backside? I suspect they are wired in parallel to provide 100 amps.
They are similar to the problematic fan circuit breaker that Polaris uses.
They do not play well in a damp location, and it appears yours are locate below the average waterline of your RZR.
I would start with volt meter at battery (12.2v you said) and work your way down stream till voltage dies.
Denver and 442raceRZR like this.
2014 800 LE w/EPS 50
CA 800 is offline
post #11 of 12 Old July 23rd, 2019, 04:16 PM
wrenchinator's Avatar
Member #259882
View wrenchinator's Photo Gallery(0)
I assume you made the fuse checks with your test light so that you know power is there. So you have a problem between the fuse box and the ignition switch. I would check the fuse that supplies the ignition switch to be sure it is contacting both contacts in the fuse box. checking the top of the fuse with a test light wont reveal if the spade is not contacting the rest of the circuit. If you have power coming out to the wire but none at the switch, bad wire.
wrenchinator is offline
post #12 of 12 Old July 23rd, 2019, 04:26 PM
Member #265982
I am aware it has no power at all. Wire come off the battery to the solenoid, then from solenoid to starter. But there are 5 small wires that go to other things, dash, lights, fuel pump? Ignition? That also comes off the solenoid. Had that eyelet break on my old 800 and also on a 900s. I lost all power. No lights radio nothing. Simple to check...
442raceRZR likes this.
