Service manual says "discard & replace fasteners" - Polaris RZR Forum - RZR Forums.net
 6Likes
  • 2 Post By Rockymtn5280
  • 2 Post By RWB713
  • 1 Post By BWXT
  • 1 Post By Denver
post #1 of 10 Old July 18th, 2019, 04:21 PM Thread Starter
Rockymtn5280's Avatar
My RZR: 2018 RZR 1000 TRE
Member #223457
Interesting item.
When working on my RZR and using the Polaris service manual, a lot of times it states to discard fastener (nut/bolt) and replace with new.
Have always followed their instructions. Usually, its just the nut (nylock) that is supposed to be replaced. Greasing my wheel bearings. Have to remove radius rods. Manual says replace nuts on outer radius rod bolts to hub. Got new OEM nuts from Polaris.
Nothing about bolts.
Torque to 100 foot pounds per manual. A 12MM X 1.5, 10.9 bolt should be able to take about 135+ foot pounds.
Hit 90 foot pounds. Snap.
I think I am going to also replace the bolt when the service manual says just replace the nut on critical components. Like suspension!
P.S. Its not a harbor freight torque wrench problem.
My hunch is the original threads/bolt got stretched correctly the first time. Second time around, nope. Especially with a new nut.
Fastone110 and RWB713 like this.
Rockymtn5280 is offline
post #2 of 10 Old July 18th, 2019, 05:18 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
Re: Service manual says "discard & replace fasteners"
Iíve reused the suspension bolts multiple times. Iím guessing that bolt was already stretched.
2017 RZR XP4 1000
Alaska UTV Fab LLC
Instagram: alaska_utv_fab
FOR SALE
- Hunterworks secondary rollers, set of 2, $35 shipped
- Sinister Fabrication A pillar bungs, set of 2, $45 shipped
SNWMBL is offline
post #3 of 10 Old July 18th, 2019, 05:18 PM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Yup, bolts can only take so many torque to yield procedures, or tighter as some do.
Iím not gonna say I replace every bolt or nut every time, but I do from time to time if Iíve been pulling stuff apart a few times.
That being said, the primary clutch bolt is very subject to breaking after repeated use... especially if you use an impact on it... I donít use an impact on it, but I do replace that bolt at least every other time I pull the clutch...secondary too... those arenít fun to get out if they break... and can be pretty catastrophic if they break under operation
Rockymtn5280 and RZR_Scott like this.
2018 XPT4 - Bailey
RWB713 is offline
post #4 of 10 Old July 18th, 2019, 06:49 PM
BWXT's Avatar
My RZR: 2018 XP1000 Black
Member #241858
View BWXT's Photo Gallery(0)
That's crazy! Don't think I've ever broken a bolt torqueing one down. On anything! lol
RZR_Scott likes this.
BWXT is online now
post #5 of 10 Old July 19th, 2019, 11:11 AM
Denver, CO - 303-400-0205
American Rock Rods's Avatar
First Name: Chris @ ARR
Member #25882
View American Rock Rods's Photo Gallery(0)
Curious, are you running factory or aftermarket radius rods? Aftermarket ones adjusted incorrectly can stress and shear the mounting bolts.
If OEM, it is most likely just a bad bolt. It happens, but not very common. I have seen it more with the smaller 10x1.25 bolts.
We replace nuts every time. Bolts we inspect and reuse if ok, except on racecars where we replace every bolt every time.
Chris @ ARR
303-400-0205-shop #
We are Colorado's Premier UTV Parts/Accessory shop!
American Rock Rods is offline
post #6 of 10 Old July 19th, 2019, 11:33 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Magnaflux them puppies!
Denver is offline
post #7 of 10 Old July 19th, 2019, 01:05 PM
Herdfan's Avatar
Member #203033
View Herdfan's Photo Gallery(0)
You weren't by chance using any lubricant were you? Products such as anti-seize, thread locker or even oil that got on will throw off a torque wrench.
Learned this on my HD5 beadlocks. Put anti-seize on them and was breaking them before I got to 12lbs. They are all torqued to 7.5 now and are holding just fine.
Herdfan is offline
post #8 of 10 Old July 19th, 2019, 01:59 PM
RZR_Scott's Avatar
My RZR: 2014 800 XC
Member #271236
If they say replace they are most likely TTY. So they have been stretched the first time and need new from now on. Also, even so, that is a big bolt, but I think I would go a little easy on it next time anyway. 90 ft/lbs is a lot.
RZR_Scott is offline
post #9 of 10 Old July 19th, 2019, 03:51 PM
Denver's Avatar
First Name: Denver
Member #41951
That's why I don't take the wheel studs to the full torque. Almost. Axle castle nuts, yes.
Denver is offline
post #10 of 10 Old July 20th, 2019, 06:17 AM Thread Starter
Member #223457
Stock radius rods.
No lube. Had taken them apart last year to grease wheel bearings. New nuts and torque to 100.
Just got back from Taylor. LOTS of water!!!! WE joked TRE stands for Trails & Rivers Edition. One spot, buddy filmed me and I was actually drifting sideways it was so deep & strong.
Figured I should probably grease the wheel bearings again. Used new nuts again and the second one snapped. Two others are feeling iffy about getting close to 100. Gonna replace all 4 and pick up some spares.
