Got a little stuck. Got a little wet. What next? - Polaris RZR Forum - RZR Forums.net
post #1 of 23 Old July 11th, 2019, 11:46 AM Thread Starter
Dubjitsu's Avatar
Member #271082
View Dubjitsu's Photo Gallery(0)
So, I got my new 2018 rzr Turbo a little stuck in a mud pit/small pond. Water got in just below the seat bottom. Drove it out with the help of a winch from an ATV. Let is sit for 20 minutes then drove back to the trailer. It drove fine but the check engine light was still on after we got back. Don't want to cause any further damage. Not sure what to do next? Any help is appreciated. Thx!
-Mike
Dubjitsu is offline
post #2 of 23 Old July 11th, 2019, 11:57 AM
rottendiesel's Avatar
Member #233994
View rottendiesel's Photo Gallery(0)
Re: Got a little stuck. Got a little wet. What next?
I've been in water up to the seats before and never got a check engine light...
Sent from my Pixel 2 XL using Tapatalk
rottendiesel is offline
post #3 of 23 Old July 11th, 2019, 12:16 PM
Steamfitters38's Avatar
Member #225146
Rottendiesel thanks for all your help LOL
Most likely you slipped the belt excessively when, presumably, you got the belt wet. That will throw a code.
BTW - it would really help us if you told us the code.
Steamfitters38 is offline
post #4 of 23 Old July 11th, 2019, 12:19 PM
Member #225146
And nice pic! Looks fun.
post #5 of 23 Old July 11th, 2019, 12:30 PM Thread Starter
Dubjitsu's Avatar
Member #271082
Where would I see the code?
Dubjitsu is offline
post #6 of 23 Old July 11th, 2019, 12:54 PM
Member #225146
You have the digital display right? It’s in the check engine screen. Hold the button down.
post #7 of 23 Old July 11th, 2019, 01:22 PM Thread Starter
Dubjitsu's Avatar
Member #271082
Originally Posted by Steamfitters38 View Post
You have the digital display right? Itís in the check engine screen. Hold the button down.
Didn't even know there was a check engine screen. Held down "mode." Went pushed arrow to diagnostics and hit the mode button and this is what I saw.
ID:	580064   Click image for larger version
Dubjitsu is offline
post #8 of 23 Old July 11th, 2019, 01:45 PM Thread Starter
Dubjitsu's Avatar
Member #271082
The 205230 code is a "Loss of CAN between EPS and instrument cluster." The other code isn't in the manual at all.
Dubjitsu is offline
post #9 of 23 Old July 11th, 2019, 02:00 PM Thread Starter
Dubjitsu's Avatar
Member #271082
Did some research and found it has to do with the turbo boost. "Itís an overboost/underboost code." The 31 seems to indicate that the "condition exists" but doesn't say if it's over or under...
Dubjitsu is offline
post #10 of 23 Old July 11th, 2019, 04:08 PM
Member #225146
Yeah you got it right. Water probably got in some connectors and tripped it out. I wouldn’t worry too much about it if everything is normal. Clear the codes and carry on.
The under/over boost code gets thrown with excessive belt slip btw. Nothing to worry about. I’d check your belt to make sure it’s not glazed or hourglassed, but chances are you’re fine.
post #11 of 23 Old July 11th, 2019, 05:33 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
You got mud in the boost controller vent tube. This prevent the wastegate from opening causing an overboost code. Remove the vent tube on the boost controller and clean it out.
RZR_Joe is online now
post #12 of 23 Old July 12th, 2019, 05:58 AM
Member #233994
I was merely suggesting the possibility that the code may be unrelated to the machine getting wet. Sorry if you don't think that's helpful.
post #13 of 23 Old July 12th, 2019, 06:15 AM
Member #225146
Just playin man. No hard feelings.
post #14 of 23 Old July 12th, 2019, 06:27 AM Thread Starter
Dubjitsu's Avatar
Member #271082
I appreciate the help. I'm gonna check out the things you guys suggested after I get her nice and cleaned up. Hopefully one of them does the trick!
Dubjitsu is offline
post #15 of 23 Old July 12th, 2019, 07:35 AM
True K30's Avatar
First Name: Michael
My RZR: 2018 Rzr Turbo S
Member #24498
View True K30's Photo Gallery(0)
Yep - X2
True K30 is offline
