Front End alignment - Polaris RZR Forum - RZR Forums.net
 13Likes
post #1 of 29 Old July 9th, 2019, 02:47 PM Thread Starter
skijbal's Avatar
Member #268380
View skijbal's Photo Gallery(0)
Question Front End alignment
What do you pay for a front end alignment? I'm confident that I could do it but I don't know how and don't want to screw things up.
skijbal is offline
post #2 of 29 Old July 9th, 2019, 03:23 PM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
Re: Front End alignment
Simple, steering wheel straight, measure the distance in front/rear of front tires and adjust tie-rods to obtain ~1/4" toe-in.
RZR_Joe is offline
post #3 of 29 Old July 9th, 2019, 03:53 PM
DBRs1's Avatar
Member #257810
View DBRs1's Photo Gallery(0)
As RZR Joe said. All u need is a tape measure and 10 mins of time. Do make sure the suspension is settled by driving the machine forward and backwards a few times B4 u set it.
DBRs1 is offline
post #4 of 29 Old July 9th, 2019, 04:40 PM
tprender's Avatar
Member #263780
View tprender's Photo Gallery(0)
I get about 15-20 in front of the thing and look at the front tires and see if they line up with the rear tires after you have the steering wheel straight. You will find that most of the time one side will be pointed in or out and you will have to adjust to get it in line with the rear tire. I do when I am not able to get a tape measure to go though the frame sometimes. You will find that alot of the machines are out of alignment from the factory on both atv's and sxs's.
tprender is offline
post #5 of 29 Old July 9th, 2019, 04:50 PM
SNWMBL's Avatar
First Name: Caleb
Member #207521
I use string around jack stands and pull measurements off the frame to get the string lines spot on. Works great and alignment is exact.
AZ_TR0Y, Zonk and jeffster like this.
2017 RZR XP4 1000
SNWMBL is offline
post #6 of 29 Old July 9th, 2019, 05:36 PM Thread Starter
skijbal's Avatar
Member #268380
So this is my setup. How can I adjust that without disassembling something?
skijbal is offline
post #7 of 29 Old July 9th, 2019, 05:50 PM
RZR_Joe's Avatar
Member #23438
Loosen the jamb nut and turn the tie-rod, it has a pivot inside the boot on the steering rack.
RZR_Joe is offline
post #8 of 29 Old July 10th, 2019, 09:50 AM
tprender's Avatar
Member #263780
look just past the jam nut you will see slot on the rod about 2-3 in up, that is there so that a wrench will fit in to turn the rod to bring the wheel in or out to fix the alignment.
tprender is offline
post #9 of 29 Old July 10th, 2019, 12:05 PM
Zonk's Avatar
First Name: Zonk
My RZR: 900S
Member #75333
View Zonk's Photo Gallery(0)
I adjust mine 1/8" toe out, I believe Polaris recommends 1/8" to 1/4" toe out.
stomper1 likes this.
Zonk is offline
post #10 of 29 Old July 10th, 2019, 12:24 PM
shilo020's Avatar
First Name: Rick
My RZR: Wreck it Rick: 2015 XP1000 Voodoo Blue / You Know...For the Kids: 2015 XP1000 Havasu Red
Member #59828
View shilo020's Photo Gallery(0)
In theory this is easy but in practice not so much. It is difficult to get precise measurements from consistent measurement points. Way more than 10 minutes. Remember we are aiming for two measurements from nobby tires being accurate to 1/8”. I would be glad if people would share exactly how they measure.
shilo020 is offline
post #11 of 29 Old July 10th, 2019, 12:28 PM
quadfather171's Avatar
First Name: mark
My RZR: 2018 rzr xp turbo
Member #222482
View quadfather171's Photo Gallery(0)
just butt the end of the tape measure body against the inner sidewall and pull the tape end to the other side. do the same front and back.
quadfather171 is offline
post #12 of 29 Old July 10th, 2019, 12:38 PM
shilo020's Avatar
First Name: Rick
Member #59828
Yes. But needs to be measured from exactly the same point on the tire both sides and front and back. And this needs to be at very near the full diameter of the tire for the 1/8-1/4Ē toe out recommendation to have any meaning.
shilo020 is offline
post #13 of 29 Old July 10th, 2019, 01:33 PM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
Joe, why toe in?
Is that what you would recommend for high speed desert runs?
Michale is offline
post #14 of 29 Old July 10th, 2019, 01:52 PM
RZR_Joe's Avatar
Member #23438
The service manual actually calls for 1/8" toe-out if I remember correctly. Toe-out helps in corning but also causes the frontend to wander and it can also cause excessive CV angle on the inside tire (direction of turn). Slight toe-in will help the front end track better and the wheels will not fight one another and is typical of most vehicles. Toe-out can also cause oversteer which is useful in drifting to help break the rearend loose. As far as high speed desert stuff I have no idea, I would consult one of the race teams for their opinion. As an old school drag racer I'm use to going fast in straight line LOL
RZR_Joe is offline
post #15 of 29 Old July 10th, 2019, 03:36 PM
craigstumph
craigstumph's Avatar
My RZR: RZR 1000
Member #59177
The reason for toe out is for keeping the vehicle going straight at speed through rough terrain, jumping, or whoops. I usually use 1/8-3/16" toe out front and rear. The easiest way I know is to wrap a string around the vehicle's tires (all 4) near the center line. This method is not totally accurate, but you will get close and it's free. If you have rear adjustable radius rods it really helps to fix the steering from pulling one way or the other. Note: front and rear wheels must be the same width (example 64" front and 64" rear).
Denver and shilo020 like this.
Call or Text 801 367 1395
www.proutvparts.com
craigstumph is offline
