Is this much play acceptable? Boondocker w/Heelclicker - Polaris RZR Forum - RZR Forums.net
post #1 of 6 Old June 20th, 2019, 07:12 AM Thread Starter
Paxx's Avatar
First Name: Max
My RZR: 2014 XP1K with lots of goodies!
Member #70266
View Paxx's Photo Gallery(2)
So long story short, I had to replace my primary clutch and I just added the Heelclicker kit to my P85 Boondocker clutch.
I’m wondering if this much play is acceptable in the flyweights or if I need to shim them or something to remove it?
Everything is brand new in this setup so there’s no wear causing the movement.
Is this normal or do I need to deal with this before I cause damage?
Thanks!
https://youtu.be/9UfpnP8b468
2014 XP1K
BoonDocker Ripp Tied Clutch w/Heelclicker Kit - Special Carriers A-Arms - ZRP High Clearance Radius Rods - RacerTech steering arms - Method 401's - 32" BFG KM3's - Shock Therapy Stage 3 kit and sway bar - SSV Works overhead 4 - Mastercraft 5 points - Polaris half windshield - 4-6" A-pillar light bars - ProArmor Doors - Sawgrip chainsaw mount - ISOTA full box - Spring Brake Thingy - Drake extinguisher mount ...and a never ending wish list!
Paxx is offline
post #2 of 6 Old June 22nd, 2019, 11:49 AM Thread Starter
Paxx's Avatar
First Name: Max
Member #70266
Bump
2014 XP1K
Paxx is offline
post #3 of 6 Old June 22nd, 2019, 02:35 PM
Highrider's Avatar
Member #54711
Re: Is this much play acceptable? Boondocker w/Heelclicker
Your spider should be holding pressure on the weights
2019 XP 1000 Trails and Rocks
Highrider is offline
post #4 of 6 Old June 22nd, 2019, 05:18 PM
CB-BLR
chris_bullock's Avatar
My RZR: 2018 XP Dynamix
Member #66283
View chris_bullock's Photo Gallery(0)
When I had that clutch setup on my Boondocker Turbo car...I tried and liked the Heelclicker weight setup...and they did move like that...but ended up using the 10 series Polaris weights, and liked them better.
Chris
chris_bullock is online now
post #5 of 6 Old June 24th, 2019, 11:23 AM Thread Starter
Paxx's Avatar
First Name: Max
Member #70266
So you're saying that they shouldn't be moving at all like this?
2014 XP1K
Paxx is offline
post #6 of 6 Old June 24th, 2019, 11:30 AM Thread Starter
Paxx's Avatar
First Name: Max
Member #70266
Chris
I have the rooster 10 series adjustables but the base arm weight is too heavy for my setup (56g) and I can't get my RPM up high enough.
I ordered the lightest heelclicker arms to try and get my rpm back but even with them I have had to remove all the weight to get the rpm up but now I'm getting belt slip.
I think I need to get into spring tuning so I can use more weight (and possibly switch back to the roosters because they didn't have play) but I really don't know where to start on the springs...
lol anyone with any insight into spring tuning?
2014 XP1K
Paxx is offline
