Trailer tires and maintenance - Polaris RZR Forum - RZR Forums.net
 2Likes
  • 2 Post By turnkyle
post #1 of 12 Unread June 9th, 2019, 06:50 AM Thread Starter
Mr Pickles's Avatar
My RZR: 2019 RZR 1000S
Member #269256
View Mr Pickles's Photo Gallery(0)
Iím sure you have seen the expensive ATV/SxS loaded onto a trailer that looks like it should be in the junk yard. A friend of mine is guilty of this... Do you keep your trailer tires at 50psi? Check them before every trip? A quick web search showed trailer tire life span at 3-8 years regardless of mileage. Really? How often you check/grease your hubs? Check signals and marker lights? Any trailer storage tips? The trailer is an important piece of equipment, there are folks out there that just bring it out of the yard, load and go and donít give it much thought. Trailer issues can be a hell of thing on the road. Read posts on here that show how some strap their machines down for travel, some good advice there but was curious about your trailer maintenance program.
Mr Pickles is offline
post #2 of 12 Unread June 9th, 2019, 07:01 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
Re: Trailer tires and maintenance
Always maintain tire pressure and give a little grease after every trip.
Just replaced my tires after 5 years.
I also cover my tires.
It's not worth trying to get every extra year out of them especially here with the dry heat.
I see so many boat trailers with blown tires this time of year when people just get their boat out of storage and probably don't check them and start rolling down the hwy when it's 100*+ outside
185EZ is online now
post #3 of 12 Unread June 9th, 2019, 07:53 AM
superjunior's Avatar
First Name: Dan
My RZR: 2015 900S
Member #74479
Most trailers have bearing buddies, easy to grease before each trip. Always check tire preasure and keep a spare and the tools to change it. I also rotate the tires once per season
superjunior is offline
post #4 of 12 Unread June 9th, 2019, 07:54 AM
204 AR's Avatar
First Name: Russ
My RZR: 08 rzr
Member #189561
View 204 AR's Photo Gallery(0)
I haul 2 800s on a single axle trailer, it's a pretty heavy axle but still... Tires are of the utmost importance, especially on long trips. Proper pressure, and yes, don't try to get all the goody out of them or you will be along side of the road with a blown tire someday and it's NO FUN having semi's whiz by a few feet away. You will probably never wear out a set of trailer tires, 5 years like 185 said is probably a good number to go by. Have a spare, and don't let it get 20 years old either. I learned long ago that tires age poorly whether they are being used or not.
Last weekend in fact I pulled the hubs, inspected and repacked the bearings. Everything looked good and would have been fine for another season, but now I know for sure. Do that every year, and if you're in water like a boat trailer more often than that.
Check your brakes and adjust if needed. You should be able to squeeze the controller by itself and feel a good tug when the trailer brakes apply.
And of course lights need checked and repaired as needed.
That's my routine.
204 AR is offline
post #5 of 12 Unread June 9th, 2019, 08:34 AM
turnkyle's Avatar
My RZR: 2013 570
Member #139233
View turnkyle's Photo Gallery(0)
The following opinion is from working at a trailer dealership for over 3 years performing repair and maintenance work. You should not put grease in your ez lube hubs before every trip. All you are going to do there is create to much pressure in your hub and blow the hub seal out of the back and spray grease all over the back side of your hub and wheel. Once the hub seal is blown out you start getting dirt and contaminates introduced into grease and prematurely wear out bearings. Ez lube hubs were originally designed for boat trailers to help keep water out of the bearings. The better thing to do is to remove the hubs and inspect the bearings every year to every other year. In my experience trailer tires very rarely need replaced due to low tread, they are usually develop cracking and dry rotting from sitting parked for long periods of time and UV exposure. Driving down the highway, a tire with low air pressure will generate more heat than an optimally filled tire and combined with dry rot will blow out fairly easily on a hot day.
Everytime I hook onto a trailer that does not get regularly used I check the lights, air pressure, and brakes if equipped (just test with brake controller on truck). My trailer that gets used almost every weekend in the summer gets a walk around everytime I hook it up for a visual inspection and gets a full check once a month. I try to visually inspect the wheel bearings once a year but it usually ends up being every other year haha.
RZR_Joe and Rockwerx like this.
turnkyle is offline
post #6 of 12 Unread June 9th, 2019, 01:30 PM
Greyhoundman's Avatar
My RZR: 16 900 Trail S-conversion
Member #145689
View Greyhoundman's Photo Gallery(0)
My previous 2 trailers (and current one) have had dexter ez lube hubs and consistently they fail a few trips after pumping the grease in to them to repack the bearings they blow out and spit grease all over the inside of the wheel. I am only going to pull hubs and repack them manually in the future and never use the grease fitting ever again.
Greyhoundman is offline
post #7 of 12 Unread June 9th, 2019, 10:20 PM
Hobbs's Avatar
Member #64447
View Hobbs's Photo Gallery(0)
Make sure to change bushings also every few years
Hobbs is offline
post #8 of 12 Unread June 10th, 2019, 12:09 PM
timoloco's Avatar
My RZR: XPT
Member #71730
View timoloco's Photo Gallery(0)
Its funny how many people put their $30-$40k machine on a ratty old trailer that hasn't been maintained. I cover my tires to prevent sun damage and pack my wheel bearings annually to ensure I have good coverage. I usually get about 4 years out of a set of tires. But air pressure and wiring gets examined.
2017 Polaris RZR XP4 Turbo- UTV inc. Destroyer cage, Polaris front and rear bumpers, Polaris lower door assemblies, Polaris 4500lbs winch, Polaris side mirrors, Rigid Industries midnight edition 12" light bar, Ricochet offroad skid plates, Rockford Fosgate Stage 5 system, Shock Therapy Stage 4 springs, PRP GT/SE seats, PRP 4-2 harnesses, PRP upper and lower door bags, MBRP Power Tech4 exhaust, NRP gated shifter, Super ATV rock sliders, Method 401 14" wheels, MOTO Race X-ROX-DD 32" tires, Walker Evans sway bar end links, EMP tinted half windshield
Past units- 2016 Orange Madness XP Turbo, 2014 XP 900 Orange Madness
timoloco is offline
post #9 of 12 Unread June 10th, 2019, 12:26 PM
Mick6R's Avatar
My RZR: '14 800-S
Member #62825
View Mick6R's Photo Gallery(0)
Tire pressure, marker/signal/brake lights get checked every time I hook it up. Grease the wheel bearings twice a season. Tires wear out from cracking/dry-rot before the tread is worn. I try to keep the tires placed on pavers instead of the dirt/grass. In off season, Ill put it up on jack stands to keep tire off ground altogether.
You should never underestimate the predictability of stupidity.
Mick6R is offline
post #10 of 12 Unread June 10th, 2019, 01:55 PM
paul463's Avatar
My RZR: 2014 XP1000
Member #39598
View paul463's Photo Gallery(0)
I don't know if it's been mentioned yet,but....
In addition to a spare tire, carry a complete spare hub and bearing assembly.. I can't count how many times we've had people from out of town at the shop with bearing or hub troubles with no spare parts for their particular axle in town.
Sent from my XT1585 using Tapatalk
paul463 is offline
post #11 of 12 Unread June 10th, 2019, 02:56 PM
Total Loss's Avatar
Member #4844
View Total Loss's Photo Gallery(33)
I cover my whole trailer...D-range radials also.
Inspect regularly.
"When you are going through hell, just keep going"
Winston Churchill
Total Loss is online now
post #12 of 12 Unread June 10th, 2019, 04:33 PM
bimmerdog's Avatar
First Name: Pat
My RZR: 2017 XP Turbo
Member #72309
View bimmerdog's Photo Gallery(0)
I do this.
1 cover the tires
2 grease the bearings and replace seals every year
3 do a full pre trip before every trip. Check all lights and tire pressure.
4 when stopped on a trip I always feel the hubs for any heat.
Almost 20,000 miles and 4 trailers never a flat tire or hub problem.
2017 XP Turbo
January Ride of the Month
bimmerdog is offline
