Signal Light Kits - Polaris RZR Forum - RZR Forums.net
 1Likes
post #1 of 17 Old June 8th, 2019, 06:39 AM Thread Starter
Tbreakman29's Avatar
First Name: Travis
My RZR: 2016 RZR XP4 1000 Sunset Red
Member #191537
View Tbreakman29's Photo Gallery(0)
Signal Light Kits
Looking to put a signal light kit on my 2019 XP4 Ride Command. What are your suggestions? I would like to use the factory rear tail lights if possible.
Tbreakman29 is offline
post #2 of 17 Old June 8th, 2019, 06:58 AM
Dwight45's Avatar
Member #753
View Dwight45's Photo Gallery(0)
Re: Signal Light Kits
I've used the Ryco kit on my last 2 rzrs. They use the original taillights and 3 small LEDs on each front fender. The last kit also uses the turn signal indicator in the speedometer, it doesn't flash, it just lights up. Nice feature if you forget to turn them off. A bit spendy but it works good. It also incorporates a horn button on the the turn signal arm. I'm happy with it.
Dwight
Dwight45 is offline
post #3 of 17 Old June 8th, 2019, 07:04 AM
topgun's Avatar
My RZR: 2019 Turbo RZR
Member #17581
Ryco offers the signal fangs which look pretty good.
https://www.rzrforums.net/forums.php.../536026?page=1
2019 RZR Turbo Titanium
2008 Can Am Renegade 800
2018 RZR RS1 Black Pearl
2011 Can Am Outlander 650 XTP
topgun is offline
post #4 of 17 Old June 8th, 2019, 07:58 AM
Shenandoahman's Avatar
Member #163809
View Shenandoahman's Photo Gallery(0)
I installed signal lights on my Rzr several years ago since I drive on the streets in AZ. I've found that other drivers pay more attention to hand signals than the signal lights and have come to regard them as the least valuable upgrade I've done and a huge waste of time and money. Just my opinion.
Gary
Shenandoahman is offline
post #5 of 17 Old June 8th, 2019, 09:08 AM
The Lone Rzr
185EZ's Avatar
My RZR: 2017 1KXP4
Member #89257
View 185EZ's Photo Gallery(0)
SATV
Uses rear lights
https://www.superatv.com/polaris-rzr...urn-signal-kit
I put on one of those compact motorcycle air horns
Huge difference if you want someone to hear you
185EZ is offline
post #6 of 17 Old June 9th, 2019, 10:08 AM
Pat H's Avatar
First Name: Pat
My RZR: 2018 1000 XP4 Ride Command Edition. 2018 RZR XP1k Ride Command 2 seat
Member #211553
View Pat H's Photo Gallery(0)
www.corbincustomworks.com
Pat H is offline
post #7 of 17 Old June 9th, 2019, 10:23 AM
JKTANK's Avatar
First Name: Ryan
My RZR: 2019 XP 4 1000
Member #269972
View JKTANK's Photo Gallery(0)
Originally Posted by Pat H View Post
YES ! Definitely!
If it doesn’t fit, force it. If it breaks, it needed to be fixed anyway!
JKTANK is offline
post #8 of 17 Old June 9th, 2019, 11:12 AM
GeneralD's Avatar
My RZR: 2019 XP 1000 TRE
Member #197225
View GeneralD's Photo Gallery(0)
Just received a kit from Corbin Custom Works for our 2019 XP1000 TRE.
Excellent product, direction and service.
My understanding is the turn signal indicator lights on the 2019 displays do not usually work correctly with any manufacturers kits.
Chris can now include 2 small LED bulbs to mount on the dash so you can easily see when you have your left or right turn signal activated.
We also installed a Corbin kit on our General that worked great... super easy installation. Didn't have the 2 extra LEDs for mounting on the dash and I was often forgetting I had a turn signal on. Wont have that problem on our XP1000.
Also... Chris's kit requires no splicing with the flimsy plastic T taps.
GeneralD is offline
post #9 of 17 Old June 9th, 2019, 12:19 PM
Flashman1's Avatar
Member #37609
View Flashman1's Photo Gallery(0)
Gary
I live in Az also - but Utah now requires the turn lights to be legal on pavement.
I bought a 40$ kit off ebay and it works perfect - fits into rear light covers with a hole drilled in the rear of the plastic lens. The wire cost more than the turn kit. I went with a dash mount toggle switch - it has LEDs mounted on each side on the switch to tell you they are on.
I would have sprung for the steering column control but my Garmin GPS is there.
Flashman1 is offline
post #10 of 17 Old June 9th, 2019, 02:42 PM
Pat H's Avatar
First Name: Pat
Member #211553
Chris is awesome. I bought a 2 seat and 4 seat and ordered signal kits for both. He sent two 2 seat harnesses by mistake. It was a sunday when I installed these and I emailed him that sunday with the issue. Wasn’t 15 minutes and he responded with apologies and the following Tuesday correct harness was at my doorstep. Customer service.....Corbin Works has it and the product itself has had zero issues from day one. Im getting ready to trade my four seater and my new one will have Corbin signals
Pat H is offline
post #11 of 17 Old June 9th, 2019, 03:39 PM
SpdBump's Avatar
First Name: Mac
My RZR: 2017 XP1K
Member #22190
View SpdBump's Photo Gallery(0)
I have the XTC kit on mine. Integrates with the stock tail lamps, and they added two small yellow LEDs on the front corners. The brake lights/turn signals also integrate with my rear light bar for added visibility. I preferred a three-way toggle switch on the dash to the steering column lever, because most of the column mounted stalks are ugly and clumsy looking IMO. A separate switch on the dash controls the horn and four-way flashers. The toggle switch for the turn signals has LEDs to show when they're on, but I still forget and drive around with a turn signal on about half the time.
Turn signals aren't required to be street legal in AZ, but I do like the added safety. We occasionally ride in Utah, where turn signals are mandatory equipment to be street legal, so it's worth the investment just to not have to hassle with trailering around every time we go to Utah.
SpdBump is offline
post #12 of 17 Old June 9th, 2019, 04:09 PM
R3d R3b3l's Avatar
Member #266926
View R3d R3b3l's Photo Gallery(0)
I have the Corbin kit on mine as well. I had the dealer install it, so I’m not sure how easy that it, but it’s super clean. It looks totally factory.
The only thing I don’t love about it, for some reason the switch seems awkward. The placement is a little far away from the wheel. I’d also prefer it to switch left and right instead of up and down. Super super minor complaint, but it’d be perfect like that...imo.
R3d R3b3l is offline
post #13 of 17 Old June 9th, 2019, 05:37 PM
Highrider's Avatar
Member #54711
I have a Ryco turn indicator kit on my 2019 T&R and I got the factory turn indicators in the dash to work..
2019 XP 1000 Trails and Rocks
Highrider is offline
post #14 of 17 Old June 9th, 2019, 05:38 PM
Highrider's Avatar
Member #54711
I have a Ryco turn indicator kit on my 2019 T&R and I got the factory turn indicators in the dash to work.. Here is a pic with the emergency flashers working ..
Attachment 578296
post #15 of 17 Old June 9th, 2019, 06:50 PM
GeneralD's Avatar
Member #197225
Attachment 578296
Glad you got yours to work.
I couldn't get a definitive answer from any of the kit manufacturers guaranteeing they would work with my 2019 dash display.
Also... I read the installation instructions from the other manufacturers and didn't like the way you needed to splice into the brake light wire with the plastic T taps. I haven't had good luck with those connectors in the past. Chris's kit integrates into the factory wiring seamlessly for a nice clean installation.
Crossover likes this.
GeneralD is offline
