2019 RZR High Lifter oil overfill after oil filter change - Polaris RZR Forum - RZR Forums.net
 13Likes
post #1 of 44 Old June 6th, 2019, 03:42 AM Thread Starter
evnizio's Avatar
Member #269016
View evnizio's Photo Gallery(0)
Changed the oil and filter for the first time using the polaris oil change kit that includes 2 qts plus a little oil bottle and when I measure the oil with the dipstick,it shows like one inch overfill.
Is this normal?
Should I take some oil out?
evnizio
evnizio is offline
post #2 of 44 Old June 6th, 2019, 03:54 AM
Kuszlyk's Avatar
My RZR: 2016 RZR S 1000
Member #144081
View Kuszlyk's Photo Gallery(0)
Re: 2019 RZR High Lifter oil overfill after oil filter change
Normally, these engines only take 1.5 quarts.
Kuszlyk is offline
post #3 of 44 Old June 6th, 2019, 04:29 AM
olddog's Avatar
First Name: billy
My RZR: sold 2013 900 xp sold.......2017 turbo
Member #53180
View olddog's Photo Gallery(0)
i would drain a little out....thats just me....
olddog is offline
post #4 of 44 Old June 6th, 2019, 04:32 AM
RZR_Joe's Avatar
Member #23438
Feedback Score: 6 reviews
You drained the transmission fluid and not the engine. So when you put in new oil it has 2x as much as it should. Fairly common mistake.
dartersracing and Doin It like this.
RZR_Joe is offline
post #5 of 44 Old June 6th, 2019, 04:37 AM
RZR_Joe's Avatar
Member #23438
Depends on engine model but it's 2.0-2.75 quarts. For the 1k it's 2.75qts
RZR_Joe is offline
post #6 of 44 Old June 6th, 2019, 06:44 AM
Denver's Avatar
First Name: Denver
My RZR: 2015 S900 Titanium
Member #41951
Did you run it to circulate the oil and fill up the filter, then check it?
Sent from my S9+ using Tapatalk Pro
Denver is offline
post #7 of 44 Old June 6th, 2019, 06:45 AM
Denver's Avatar
First Name: Denver
Member #41951
One inch high on the dipstick is not twice the oil.
Denver is offline
post #8 of 44 Old June 6th, 2019, 06:52 AM Thread Starter
evnizio's Avatar
Member #269016
Yes I did run it
The oil filter is at an angle so it would not retain much oil
evnizio is offline
post #9 of 44 Old June 6th, 2019, 07:19 AM
Denver's Avatar
First Name: Denver
Member #41951
I don't know where you guys are getting those numbers, but it's not the owner's manual. Did you check your owner's manual?
According to the 2019 XP1000 HighLifter owner's manual (available on Polaris website) and the XP1000 shop manual I have access to, engine oil capacity is 2.5 quarts.
The XP oil change kit includes 2.5 quarts of oil.
Most likely scenario is that you didn't fully drain it, would be my guess. If you want to drain a bit, it's up to you. I don't think I'd bother unless it was coming out the breather tube.
Denver is offline
post #10 of 44 Old June 6th, 2019, 07:21 AM
RZR_Joe's Avatar
Member #23438
1" above the full mark is double the oil, I had two friends do this.
BTW - you don't need run the engine to "circulate" before checking. Oil is checked by height in the the oil pan, the filter holds no oil after shutdown, and all the oil will drain back to the pan.
RZR_Joe is offline
post #11 of 44 Old June 6th, 2019, 07:27 AM
Denver's Avatar
First Name: Denver
Member #41951
Originally Posted by evnizio View Post
Yes I did run it
Once the filter is full, it stays full. Doesn't run back thru the pump to the pan. Notice when you took the filter off to change it, it was full of oil and leaked all over the place?
Denver is offline
post #12 of 44 Old June 6th, 2019, 07:37 AM
RZR_Joe's Avatar
Member #23438
Yes I did run it
Ah no, on a 1k or XPT engine it most certainly does drain back. Very little oil stay in the filter.
Rockwerx likes this.
RZR_Joe is offline
post #13 of 44 Old June 6th, 2019, 07:42 AM
Denver's Avatar
First Name: Denver
Member #41951
Well, Polaris instructions for oil change, per shop manual, are to add 2.5 quarts specified oil, run engine for 30 seconds, shut down, wait 15 seconds then check oil level.
If that isn't circulating it to fill the filter, I don't know what is. It's the same as my truck.
I'm not saying the OP didn't accidentally pull the wrong drain plug; he should pull the transmission fill port and check service level just to be sure. But 5 quarts in the crankcase instead of 2.5 quarts is going to be way more than one inch overfill on the dipstick. That crankcase ain't that big.
Denver is offline
post #14 of 44 Old June 6th, 2019, 07:42 AM
Max H's Avatar
First Name: Max
My RZR: 2018 XPT 2 seat
Member #16311
View Max H's Photo Gallery(0)
Yes I did run it
I second that ...the oil will drain back out of the filter . Thats why i dont run the motor before I do a oil change I dont like the mess and cleanup
Max H is online now
post #15 of 44 Old June 6th, 2019, 07:50 AM
Denver's Avatar
First Name: Denver
Member #41951
Oh, and BTW, 2.75 quarts is the spec for the XPT. 2.5 quarts for the XP1000. Per the owner's manuals.
Denver is offline
