FRONT DIFFERENTIAL RATTLING/NOISE - Polaris RZR Forum - RZR Forums.net
post #1 of 12 Old May 28th, 2019, 08:40 PM Thread Starter
NPATZKE's Avatar
Member #269588
View NPATZKE's Photo Gallery(0)
Arizona Flag FRONT DIFFERENTIAL RATTLING/NOISE
Since I bought my 2016 Trubo 4 w/ 1000mi on it, the front differential has made this horrible noise in 2WD. Switch into 4WD and it's gone.
I fear self-destruction.
The dealer told me to look at the coolant line brackets. Not broken. The front differential seals were replaced due to leakage, under warranty. Brought the RZR back in for this issue and they replaced the front diff output bearings and seals (again). No leak now, but same noise no change. I now have 2000mi on the rig.
I am tempted to take the diff out and ship it to RCR Sandcraft for rebuild as they claim they can fix this noise - however I'd like warranty/Polaris to take care of it for me.
Google has pointed towards a bad propshaft.
Does this rattling sound familiar to anyone?
VIDEO:
NPATZKE is offline
post #2 of 12 Old May 29th, 2019, 05:05 PM
UPRIDER's Avatar
My RZR: 2012 Liquid Silver, 2014 Orange Madness
Member #47303
View UPRIDER's Photo Gallery(0)
Re: FRONT DIFFERENTIAL RATTLING/NOISE
How is your front driveshaft yoke?
You can check it by pulling up the tunnel cover.
UPRIDER is offline
post #3 of 12 Old May 30th, 2019, 01:20 PM
E.T.X.Rzr's Avatar
First Name: Justin
My RZR: 2019 HLE4
Member #81149
I would like to know as well. I have a new 2019 XP4 HLE with the same noise. It only has 5 miles on it. Mine only seems to do it in high range though. I put it up on the four post lift and drove it and it would not make the sound.
E.T.X.Rzr is offline
post #4 of 12 Old June 26th, 2019, 04:08 PM Thread Starter
NPATZKE's Avatar
Member #269588
Bump.
Been at dealer for almost a month now 😢
They replaced carrier bearing with no luck.
NPATZKE is offline
post #5 of 12 Old June 26th, 2019, 06:45 PM
swamp24's Avatar
Member #265404
View swamp24's Photo Gallery(0)
I have the same Noise on my 18xp1k had it since new now have 1600 miles on it same noise I just turn up the radio more noise is gone just run it till it breaks Iíve heard some that have this problem and have 4000+ miles on them
swamp24 is online now
post #6 of 12 Old June 27th, 2019, 08:12 AM
todo's Avatar
My RZR: 2015 XP1K ... 2018 CanAm X3 X RC
Member #41620
View todo's Photo Gallery(0)
Mine has done it since day one. Warrenty replaced front diff at 200 miles. New diff slightly quieter but still rattles. 4000 miles no issues.
todo is offline
post #7 of 12 Old June 27th, 2019, 09:13 AM Thread Starter
NPATZKE's Avatar
Member #269588
It sounds like I just need to live with It.
I'm just worried that I've already worn out front diff output besrings and carrier bearing in less than 2000mi and it's gonna keep happening.
NPATZKE is offline
post #8 of 12 Old June 27th, 2019, 09:44 AM
rdsnake's Avatar
My RZR: 2016 XPT
Member #48735
View rdsnake's Photo Gallery(0)
For what its worth, you could find a turbo take out diff for around $700. They have better internals then the 2016.
rdsnake is offline
post #9 of 12 Old June 27th, 2019, 10:09 AM
ckr
ckr's Avatar
First Name: Clint
My RZR: 2018 Dynamix Turbo
Member #82890
View ckr's Photo Gallery(0)
I don't know about that, I have a 2018 RZR Dynamix Turbo with 500 Miles the front Diff. the left side started to leak and the axle where it goes into the Diff. had a lot of play in it, I sent it to Sandcraft Motor Sport to get it completely rebuilt, so I wont have any more problems with it. the cost was more than $700.
ckr is offline
post #10 of 12 Old June 27th, 2019, 11:49 AM Thread Starter
NPATZKE's Avatar
Member #269588
Ive read replacing the propshaft can help...
I'd love to slap a GoPro down there and check the stock shafts run-out... I really want to blame the the shaft haha
NPATZKE is offline
post #11 of 12 Old June 27th, 2019, 12:26 PM
swamp24's Avatar
Member #265404
Sandcraft can rebuild them for 375 bucks watch there video on what they do to fix the noise
post #12 of 12 Old June 27th, 2019, 01:34 PM Thread Starter
NPATZKE's Avatar
Member #269588
RCR replaces the output bearings (which Polaris already did) and shims the lash out of the ring and pinion. So if the shimming is suppose to help I guess I'll go for it...
NPATZKE is offline
