Zipper lube - Polaris RZR Forum - RZR Forums.net
 7Likes
post #1 of 17 Old May 20th, 2019, 05:05 PM Thread Starter
machineguy's Avatar
Member #264262
View machineguy's Photo Gallery(0)
Zipper lube
What are you guys using to keep your storage bag zippers lubed that work well with dust? 1 day of riding and my storage bags were impossible to open/close.
2017 XP 1000. All stock
machineguy is offline
post #2 of 17 Old May 20th, 2019, 05:40 PM
RND's Avatar
First Name: Rich
My RZR: 570 EPS
Member #85203
View RND's Photo Gallery(0)
Re: Zipper lube
Vasoline works perfect!
Sent from my SM-G973U using Tapatalk
2012 Polaris Sportsman 500 H.O.
2015 RZR 570 EPS trail LE Black Pearl
*Warn winch 3500 w/Synthetic rope
*Polaris front brush guard
*Polaris rear brush guard
*Richocet 9 piece complete underbody armor
*Polaris Lock-n-Ride Full Windshield
*Polaris Lock-n-Ride Rear Shield
RND is offline
post #3 of 17 Old May 20th, 2019, 06:41 PM
CB-BLR
chris_bullock's Avatar
My RZR: 2018 XP Dynamix
Member #66283
View chris_bullock's Photo Gallery(0)
Re: Zipper lube
I would not recommend anything oily or greasy...it attracts and holds the dirt and dust.
3 in 1 brand garage door dry lube goes on as a spray liquid and dries so that it doesn't attract dirt and dust while still lubricating.
Any spray on dry lube will work...the 3 in 1 stuff is just easy to find and is cheap.
I use this on all of my suspension points before every ride as well.
Chris
Rockwerx likes this.
chris_bullock is offline
post #4 of 17 Old May 20th, 2019, 08:33 PM
Larryg82's Avatar
First Name: Larry
My RZR: 2018 Turbo S
Member #80871
View Larryg82's Photo Gallery(0)
Re: Zipper lube
Chapstick
ocrzrs and GimpyRZR like this.
Larryg82 is offline
post #5 of 17 Old May 20th, 2019, 09:35 PM
Highrider's Avatar
Member #54711
Re: Zipper lube
We use a soap stone- works very well- cheap-and zero mess.
2019 XP 1000 Trails and Rocks
Highrider is offline
post #6 of 17 Old May 21st, 2019, 04:26 AM
Impact344's Avatar
Member #268904
Soapstone
Impact344 is offline
post #7 of 17 Old May 21st, 2019, 05:41 AM
Dwight45's Avatar
Member #753
View Dwight45's Photo Gallery(0)
Re: Zipper lube
Where do you get soapstone?
Dwight
Dwight45 is offline
post #8 of 17 Old May 21st, 2019, 05:45 AM Thread Starter
machineguy's Avatar
Member #264262
Re: Zipper lube
This is the white chalk like marking sticks used by welders and such?
post #9 of 17 Old May 21st, 2019, 06:08 AM
Steamfitters38's Avatar
Member #225146
Yes that’s the stuff. Pretty much any hardware store will carry it.
Steamfitters38 is offline
post #10 of 17 Old May 21st, 2019, 07:23 AM
GimpyRZR's Avatar
Member #208177
View GimpyRZR's Photo Gallery(0)
Re: Zipper lube
chapstick, or bees wax
GimpyRZR is offline
post #11 of 17 Old May 21st, 2019, 09:52 PM
Highrider's Avatar
Member #54711
Re: Zipper lube
Dwight
https://www.amazon.com/Soapstone-Mar.../dp/B000DZFTKI
post #12 of 17 Old May 21st, 2019, 10:39 PM
mikedeezxxx's Avatar
Member #263370
View mikedeezxxx's Photo Gallery(0)
Re: Zipper lube
Originally Posted by Steamfitters38 View Post
Yes thatís the stuff. Pretty much any hardware store will carry it.
Does the soap stone leave behind any coloring?
mikedeezxxx is offline
post #13 of 17 Old May 22nd, 2019, 06:15 AM
Member #225146
Yes it’s white of course, but it washes off with water. With all the dust you say you are encountering, I’m going to guess that there would be no way you’d see any traces of it left after a ride.
I only use these at work to mark steel pipes with. If you aren’t careful you can wipe the marks off by accident with your gloves. $13 bucks is very expensive too, but they do last a long time.
post #14 of 17 Old May 22nd, 2019, 07:16 AM
ZColorado's Avatar
My RZR: 2015 900 Trail
Member #228954
View ZColorado's Photo Gallery(0)
Re: Zipper lube
Beeswax
https://www.amazon.com/s?k=beeswax
GimpyRZR likes this.
ZColorado is offline
post #15 of 17 Old May 28th, 2019, 06:49 PM
Slick Rock Red
SlickRock's Avatar
My RZR: 900 S
Member #268020
View SlickRock's Photo Gallery(0)
Re: Zipper lube
A birthday cake candle works great. Easy to hold also
S.R.
p s could come in handy for fire starting if you're left out in the cold
Paved roads. Another example of wasted tax payer dollars
SlickRock is offline
Question is Lube Cables or not to lube Frost31720 General RZR Discussion 2 January 18th, 2019 08:13 AM
Heim Joint Lube Aaron407 RZR XP 900 13 September 11th, 2018 02:17 PM
Lube points illustration trainman RZR 900 - 50'' Trail Models 23 May 31st, 2015 04:23 AM
To Lube or Not to Lube? rigidone RZR XP Suspension 6 December 19th, 2013 11:15 AM
Propshaft lube locations on '08 800 jengindreams1 RZR 800 Specific Discussion 12 August 28th, 2012 06:19 AM
