Razorback average temps and danger zone - Polaris RZR Forum - RZR Forums.net
 3Likes
post #1 of 35 Old May 6th, 2019, 10:31 AM Thread Starter
Steamfitters38's Avatar
Member #225146
First ride over the weekend at Shasta with UTVCrazy group and my new Razorback gauge. I mounted at 3 o’clock and was seeing temps of 200 when climbing fairly regularly. We went from 900’ to 4000’ and I saw 208 at the hottest while moving constantly. Is that normal? I saw averages of 180 the rest of the time.
Also, at WOT in low, I saw my belt temps spike pretty hard on relatively flat roads. What gives? I thought that I’d be moving a ton of air to keep those clutches cool.
Steamfitters38 is offline
post #2 of 35 Old May 6th, 2019, 10:55 AM
Aspiring Perfectionist
RWB713's Avatar
First Name: Richard
My RZR: 2018 XP4 Turbo
Member #70552
Re: Razorback average temps and danger zone
WOT in should be avoided in low really, but WOT will generate heat rapidly no matter the situation, just sometimes worse than others, donít start to worry unless youíre seeing extended periods of 220+.
This topic is a can of worms, but to answer your initial question, 208 as a max is perfectly normal, and I wouldnít worry a bit, 180 as an average is perfect
glamisfan likes this.
2018 XPT4 - Bailey
RWB713 is offline
post #3 of 35 Old May 6th, 2019, 11:57 AM Thread Starter
Member #225146
Shoot that’s great news thanks. I read some other threads from the end of 2018 where people where talking about the gauge turning red around 220, but mine does it at 200. Any idea why they changed it?
And why avoid WOT in low?
post #4 of 35 Old May 6th, 2019, 12:12 PM
RWB713's Avatar
First Name: Richard
Member #70552
220 should be where it goes red. 200 is still plenty normal, cooler is always better, but they generate heat, so in a full throttle or high load scenario, itís normal to see a little hotter temps. Generally speaking, the cooler a belt runs, the longer it lasts, but you can only keep it so cool when thereís a lot of load on it
ďavoid WOT in throttle in low in a high load situationĒ is a better way to put it, itís a lot of torque in the drivetrain, and when couple with a high load... itís tends to break stuff, and generate excessive belt heat... Iím not really saying you canít put the hammer down in low, just know thereís consequences when itís done in a lot of situations... if you need to go that fast in low, itís best to switch to high.
2018 XPT4 - Bailey
RWB713 is offline
post #5 of 35 Old May 6th, 2019, 01:18 PM
Michale's Avatar
My RZR: 17 XPT2
Member #218193
I had the same problem at Walker River. I have never had a problem with belt temps before. I changed the belt on the trail and still had the same problem. The belt that came off had 1500 miles on it and still looked new. I haven't blown the clutch out lately so that might be it. I ordered the CVT Blaster 2 today so that will help keep it cooler, whatever the problem may be.
Michale is offline
post #6 of 35 Old May 6th, 2019, 02:54 PM Thread Starter
Member #225146
Interesting. My gauge def turns red at 200 on the dot. Yeah that is a lot of power, can really feel it in 4wd. I only went wide open on some stretches of logging roads though. I couldn’t imagine a need to do that on a trail!
brbeck13 likes this.
post #7 of 35 Old May 6th, 2019, 06:43 PM
olddog's Avatar
First Name: billy
My RZR: sold 2013 900 xp sold.......2017 turbo
Member #53180
View olddog's Photo Gallery(0)
mine is yellow/orange at 200 and red at 220.....and flashes red at 240
olddog is offline
post #8 of 35 Old May 6th, 2019, 06:50 PM
Burro's Avatar
First Name: William
My RZR: 2018 RZR XP 1000 Trails & Rocks Edition
Member #129921
View Burro's Photo Gallery(0)
Wow, I am really surprised by the high temps everyone is getting. Been running mine here in Moab, UT and in low crawling trails I average 120-130 degrees . When in the sand and running in high wide open I run 145-160 degrees.
Burro is offline
post #9 of 35 Old May 6th, 2019, 07:04 PM
RWB713's Avatar
First Name: Richard
Member #70552
Donít. Touch. It. Ever.
I dunno what kinda magic potion you got going on, but donít ever change it.
Not exactly apples to apples, but I average 160-190 in low speed stuff after I got some issues sorted out, but if I go hard in the wash Iíll see 245 within 5-10 min with a full boat of passengers, hotter than most, but my machine weighs 3000 lbs with 4 people in it, on 32ís, with a tune.
120-130 is damn near too low lol, but Iíd love it!
Max H likes this.
2018 XPT4 - Bailey
RWB713 is offline
post #10 of 35 Old May 7th, 2019, 04:52 AM
Hunterworks's Avatar
First Name: Todd
Member #47437
Feedback Score: 8 reviews
Do you have a Razorback?
www.hunterworks.com
Todd
Office phone: 601-771-0070
Hunterworks is offline
post #11 of 35 Old May 7th, 2019, 04:53 AM
First Name: Todd
Member #47437
My opinion on high temps in low at higher rpm is belt over travel and you are not running that high of rpm in high for long or you would see it there too.
We found belt over travel in some RZR turbo and non turbo and then created a spacer in the primary for those who have this issue and stop it.
Todd
www.hunterworks.com
Todd
post #12 of 35 Old May 7th, 2019, 07:40 AM
Burro's Avatar
First Name: William
Member #129921
Yes. I have had one for almost a year now. Had it installed last year at Rally of the Rocks.
Burro is offline
post #13 of 35 Old May 7th, 2019, 07:45 AM
First Name: Todd
Member #47437
I suspect something is not right with it, normal belt temp is 165, might want to call them.
With temps that low thought you might have one of the gauges that measure air temp in the cover not the belt
www.hunterworks.com
Todd
post #14 of 35 Old May 7th, 2019, 07:54 AM
Roger Lee's Avatar
First Name: Roger
My RZR: 2015 1K
Member #69952
I have a Razorback gauge to. My belt temps are usually 120-145F. The highest I have ever seen is 150F. I just installed a HD belt from Hunterworks, I'm not a speed demon and mostly ride trails. The HD belt seems to run about 12 -15F warmer than my last two Gates belts. All have gotten 3500 miles on them and then I just toss them. They still looked in great shape. I have 12K on my 2015 Rzr 1K. Should be 15K by the end of summer.
One reason I think my belt temps are a lot lower is I run 2 wind wings on each side. These keep all the dust off us, but they also direct air down into both air panels for the air filter and belt housing.
My general average speeds are 10-20 mph on trails and on smooth flat roads 30-40 mph.
Roger Lee is online now
post #15 of 35 Old May 7th, 2019, 08:13 AM
Burro's Avatar
First Name: William
Member #129921
Thanks for the information. Iíll call them and see what they say.
Burro is offline
